Fiat Ducato 3.0 - Experiencing OBD Error P2563 Turbo Boost Sensor During Heavy Rains
86565 7
  • #1 13549922
  • #2 13551483
    profesjonalista55
    Help: 8
    Rate: 158
    a topic known for a long time was the modification of the valve mounting
  • #3 14395381
    vvaldek
    Help: 81
    Rate: 386
    where did you get that sensor from? because you can't buy it anywhere
  • #4 14702038
    diagnosta06
    Help: 12
    Rate: 110
    I confirm the valve not available for sale
  • #5 14706970
  • #6 18747519
    mercefons
    Rate: 41
    Hello . I have the same error but my Ducato is 2.3 150km euro 6. What ideas do you have for this error, I replaced all the hoses, sensors and still the same;/, I bet on the pear itself (I do not have any sensor in the pear).
  • #7 19244353
    bacho81
    Did you do it on the car or did I remove the whole turbo? I bought a pear with a sensor and want to replace it on the car, but as I watched, I see no chance without removing the entire turbo ...
  • #8 19252523
    mercefons
    Rate: 41
    I did everything on camera :) a bit tiring job but I managed but my fault was a faulty computer, someone messed with it and couldn't do anything, I changed the computer and everything works
✨ The discussion revolves around the OBD error P2563 encountered in vehicles equipped with the Iveco 3.0 180KM engine, specifically in the Fiat Ducato, Citroen Jumper, and Peugeot Boxer during heavy rain conditions. The error manifests as the engine enters emergency mode, limiting speed and triggering a "check engine" light. Users report that the error often occurs during engine braking or deceleration, with temporary fixes such as turning the engine off and on. Some participants mention difficulties in sourcing replacement sensors and valves, with one user successfully resolving the issue by replacing a faulty engine computer. Others discuss the challenges of replacing the turbo boost sensor without removing the entire turbo assembly.
