IVECO DAILY 3.0 EURO 5 Bi Turbo 170HP - Issues with Turbine Replacement, Emergency Mode
dworak1989 18045 5
  • #1 16422486
    dworak1989
    Hello, I have a problem with iveco daily 3.0 euro 5 bi turbo 170 horses, namely the problem started with theoretically damaged turbine, the car kicked like hell, drank oil, regenerated turbo car still drank oil and thrown oil on the exhaust, I replaced everything went back to normal but now I am struggling with the car falling into emergency mode, the car falls into a breakdown between 1600 and 1900 revolutions when it slows down on the run and tries to accelerate in the range of 1600 and 1900 automatically breakdown, between 2000 - 3500 everything ok the car has 2 errors that do not delete and the one that appears when the car goes down I will add that before the whole situation such things did not take place, so error codes
    -P0404 - FIXED
    -P0046 - FIXED
    -P0299 - CLEARS, APPEARS WHEN AUTO IS FAILED IVECO DAILY 3.0 EURO 5 Bi Turbo 170HP - Issues with Turbine Replacement, Emergency Mode
  • #2 16422587
    andrzej20001
    Help: 1578
    Rate: 6669
    Recently there was a similar topic. Look for throttle there
  • #3 16422608
    dworak1989
    I read that thread but there was a completely different story :) , but thanks for your interest
  • #4 16422632
    andrzej20001
    Help: 1578
    Rate: 6669
    If you drank oil with liters, think what you have in collectors.egr. and dpf
  • #5 16422643
    dworak1989
    I burned dpf, I didn't move the collectors and egr I did not move, tomorrow I put the car on the route about 300 km such a route can help or harm?
    Added after 20 [minutes]:
    I will add that when it turns above 2000 revolutions it flies like an arrow, the worst is how slow it down and I want to accelerate from too high a gear such as slow down and I want to accelerate from 1500 revolutions then the car is as if it is "choking" and falls into trouble it happens between 1600 and 1900 revolutions
  • #6 16422942
    szymitsu21
    Help: 343
    Rate: 1300
    Such a route will certainly not help, especially if there is oil in the intake and it will go to the engine.
    Come with your computer and see how the boost pressure works.
