Fiat 126p Oil Change: Engine Wear, Selecting Oil under PLN 100, 180,000km Mileage & Selektol 15W40
matys296r 48915 15
What oil should I use in a Fiat 126p engine with about 180,000 km and an oil-pressure warning light, on a budget of up to PLN 100?
Use a cheap mineral oil, preferably 15W40, and do not switch to a thinner grade; some users also suggested 20W50 or 15W50 only as an alternative for a tired engine or summer use [#13604380][#13604270][#13604943][#13605713] Replace the oil filter and, in the Fiat 126p, also open the centrifugal filter and clean it; fit a new O-ring when reassembling [#13604380] Check the oil level first, because the red oil-can lamp indicates loss of oil pressure in the lubrication system, not just a low level [#13604646][#13605158] If the lamp still flashes after the oil change and the level is correct, inspect the oil pan and the crankshaft plugs, which can come loose and drop oil pressure [#13605599]
  • #1 13604224
    matys296r
    Hello, it's me again.
    I am thinking of changing the oil in my Fiat engine because it has not been changed for 4 years (it has done somewhere around 15,000 km).
    The current mileage of the car is less than 180,000 km (for a toddler it is a lot)
    Previously ridden on selektol 15w40.
    What do you advise me regarding engine wear?
    one at an average price of up to PLN 100
    Recently, I have noticed the oil indicator light up for 1 minute.
    Please do not write that I am waiting for a renovation because the only question is what oil?
  • #2 13604233
    dedito
    Help: 527
    Rate: 595
    I do not remember what it was like in a toddler, but in other cars such lighting means a low oil level and in such a case it would be advisable to stop and refill the oil. All in all, I remember that I had it once and somehow I had to get to the gas station at least, then I was driving slowly and gently.
    As for the question itself, from what the mechanic once advised me, you can change 15 to 10 in the case of older engines, but treat it in my case as a layman's statement.
  • #3 13604270
    balonika3
    Help: 1336
    Rate: 3759
    Don't be silly, just buy the cheapest mineral oil and wio.
  • #4 13604293
    adam158
    Help: 36
    Rate: 232
    do not replace it with a thinner one because the engine will skew, give me the lowest mineral 15w40, it will be ok, and of course the filter will be new
    Moderated By manta:
    I mean the pulley has to be replaced? For spelling + nonsense warning advice.
    3.1.13. It is forbidden to publish entries that violate the spelling rules of the Polish language, careless and incomprehensible.
    3.1.11. It is forbidden to publish entries that do not contain substantive content, contain harmful advice, advice that is not an attempt to solve the problem, and the publication of identical entries consecutive or repeating information from the discussion.
  • #5 13604322
  • #6 13604375
    matys296r
    what do you think about the lotus?
    I will not pour this for PLN 10 per liter because the engine has a good mileage and I want to drive
    and maybe some 20w 50
  • #7 13604380
  • #8 13604646
    bruns
    Level 30  
    Help: 101
    Rate: 303
    Oh no buddy. This is an oil pressure light, not a low oil pressure light. Driving with the red pressure light means driving with the engine without lubrication.
  • #9 13604798
    dabu
    Level 32  
    Help: 190
    Rate: 695
    bruns wrote:
    Oh no buddy. This is an oil pressure light and not a low oil pressure light. Driving with the red pressure light means driving with the engine without lubrication.
    And many people think so, the red watering can needs to be refilled with oil, and then it can be swept away. Often punches come to the site where we pour a liter of oil :lol:
  • #10 13604943
    esteban123
    Help: 21
    Rate: 281
    And I would pour Lubro 20W50, to those older, slightly tired bikes as much as possible and the price is decent :)
  • #11 13604953
    dedito
    Help: 527
    Rate: 595
    It depends on what symbols we write, because I am writing about the symbol of the red watering can.
  • #12 13605158
    bruns
    Level 30  
    Help: 101
    Rate: 303
    It is the symbol of the oil can, not the watering can, and it signals the lack of pressure in the engine lubrication system.
  • #13 13605362
    mczapski
    Level 40  
    Help: 468
    Rate: 1658
    As you can see, my colleague is optimistic and hopes that the engine will run hundreds of thousands of kilometers on the replacement oil. Meanwhile, we did not even know the oil level in the engine. Under what circumstances did this illumination of the control lamp occur? The engine seems to be simple, but it has its requirements. As for the current state of discussion, the answer will be "use engine oil".
    Code: Bash
    And that's what I like
  • #14 13605599
    Waldemar z Kaszub
    Help: 111
    Rate: 469
    If, after replacement and with the correct oil level, this light continues to flash, first remove the oil pan and inspect the crankshaft. This shaft has two round (2-sided) metal plugs that sometimes come loose, causing the oil pressure to drop. It is enough to place this plug in the right place with a hammer and mark it around with a punch. I did it several times in these engines and the task is not difficult.
  • #15 13605713
    Javoreczek
    Help: 53
    Rate: 114
    Maybe for the summer as he found. Only when you leave him for the winter, watch how he behaves. Years ago, I poured such oil into a passing toddler and in the summer it was ok, the light came on only on a very hot engine, but in the cold it had the consistency of honey.
    Once Elf introduced an oil dedicated to Toddler with a viscosity of 15W50 to our market and it was probably the optimal viscosity for this engine.
  • #16 13605776
    matys296r
    oil level between min. and max.
    it will pour some 15w40
    when replacing, check the shaft plugs
The discussion revolves around changing the oil in a Fiat 126p, which has not been changed for four years and has a mileage of approximately 180,000 km. The user is concerned about engine wear and seeks advice on selecting oil under PLN 100. Responses suggest using mineral oil, specifically 15W40, to avoid thinning the oil, which could lead to engine issues. Some participants recommend checking the oil level and inspecting the crankshaft plugs if the oil pressure light remains illuminated after the change. The importance of using the correct oil viscosity and maintaining proper oil levels is emphasized to ensure engine longevity.
