Fiat Doblo 1.6 Multijet 105km 2012: Flickering Oil Lamp and Engine Noise Concerns
fiacik217 41838 7
  • #1 16261322
    fiacik217
    Good morning
    Problem fiat doblo 1.6 multijet 105km 2012
    I hope someone can help me because I'm doing really a lot of kilometers a day and from yesterday I started to blink the oil lamp and the message replace the engine oil, which I exchanged about 7 thousand ago. I checked the condition of the oil on a warm engine and I'm sure there is no shortage of it. Although one mechanic tells me that I should check the oil on a warm engine and another one on the cold ... So I'm stupid myself. I would not like to worsen the situation, therefore I am asking you for help. I still have a separate question because I noticed that from time to time it sounds as if the car sounds louder than the engine work, usually for a short time. Can it be a fan which sometimes just louder can walk? -Most km I make on highways, i.e. quite high speed. GREETINGS
  • #2 16261330
    Michal_WWL
    Help: 76
    Rate: 284
    Operating instructions, page 41 Instruction
    Used engine oil. You have a viscosity sensor that generates this signal.
    The reason may be just overworked oil which caused the used engine or was wrongly selected. There may also be a faulty sensor. The mechanic will check it out.
  • #3 16261335
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    fiacik217 wrote:
    a message is displayed, replace the engine oil that I exchanged about 7,000 a year ago
    You must tell the engine driver that you changed the oil. He does not know it.
    Use a diagnostic tester.
  • #4 16261343
    Michal_WWL
    Help: 76
    Rate: 284
    Fiat diesel controls the control based on two parameters:
    a) analysis of the oil condition shows that it is "worn"
    b) counting the number of burnings occurring in the particulate filter, after exceeding a certain value, it is assumed that the oil should be changed
    Quote from the Delphi sensor instructions:
    The oil condition sensor in Delphi diesel engines monitors the condition
    oil inside the engine. The sensor precisely detects the soot that absorbs
    oil additives and contributes to the wear of the engine. The sensor works on
    principle of measuring the conductivity of alternating current with frequencies 2-5
    MHz. It also measures dielectric constant and viscosity (only in oil
    stationary) and can detect the dilution with fuel - all in
    a small, integrated housing. In addition, the engine oil level sensor
    Delphi diesel can be configured to measure the oil level, depending
    from the needs of individual clients.
  • #5 19611895
    Airpoland
    Hello, I have the same problem but 4 years later with the same note !! What was the fault ?????? Why did he show oil changes ?? Thank you for the hint ?
    Moderated By CameR:
    Ask the author on PW
    Reg. 3.1.11. Don't post messages that add nothing to the discussion.
    Reg. 3.1.19. Do not send messages on archival topics if this is another question, in particular other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
  • #6 19611915
  • #7 19612085
    Airpoland
    Which post is 4th?
  • #8 19612109
The discussion revolves around a 2012 Fiat Doblo 1.6 Multijet experiencing a flickering oil lamp and an engine noise issue. The user reports that the oil lamp began blinking and a message to replace the engine oil appeared, despite having changed the oil 7,000 kilometers ago. Confusion arises regarding the correct method to check oil levels, with differing advice from mechanics about checking oil on warm versus cold engines. Responses suggest that the flickering oil lamp may be due to a viscosity sensor indicating worn oil or a faulty sensor. Additionally, it is noted that Fiat diesel engines monitor oil condition and particulate filter burnings to determine oil change intervals. One user shares a similar experience from four years later, seeking insights into the cause of the oil change alert.
