Filling 12L DHW Expansion Vessel with Air Connected to 150L Hot Water Tank: Overcoming Challenges
Tomi_ 98334 9
How do I properly fill a 12 L domestic hot water expansion vessel with air when the Schrader valve shows zero pressure and pumping seems impossible?
To precharge the vessel, first close the water supply to the tank and relieve the water side by opening a nearby hot tap, then pump air into the expansion vessel with a tap left open so the water side cannot build pressure against you [#13611479] For a domestic hot water vessel, the precharge should be about 4 bar, not a very low pressure [#13612279] In this case, the original poster reported that it only worked after also opening the cold-water tap; with only the hot tap open, the vessel would not take air [#13614413] If the vessel still will not accept air after depressurizing the water side, the diaphragm may be faulty [#13611295]
  • #1 13611258
    Tomi_
    Rate: 49
    I have a question, how to fill the expansion vessel with air?
    I have a 12l expansion vessel connected to a 150l hot water tank.
    I noticed that the vessel tank is empty (the pressure is 0, when I press the valve there is no air hissing).
    I tried to pump up the air with a pump, but it cannot be done. I feel resistance pumping air, I have no feeling that wherever the air is escaping and the tank is not filling up. The pressure is zero all the time. I also replaced the air valve insert.
    What am I doing wrong?
    Can the vessel be damaged? (he is already 9 years old but what can he get damaged in?)
  • #2 13611295
    jasiuma
    Hello friend. I guess it's the diaphragm's fault. Try to fill with pressurized water or it won't flow out through the air valve.
  • #3 13611397
    Tomi_
    Rate: 49
    And the vessel is not under water pressure all the time?
    It is mounted on a pipe that supplies cold water to the domestic hot water tank
    Should I disassemble it and connect pressurized water to it?
    I attach a picture of the vessel
    https://obrazki.elektroda.pl/8422634300_1400359445.jpg
    I think I must have emptied the diaphragm vessel myself. A few months ago, I replaced the magnesium anode in the tank. When I unscrewed the screws from the tank lid to get to the anode, there was a hiss of air for a long time.
    Do I need to refill the expansion vessel after installing the anode?
  • #4 13611479
    piotr_boncza
    Help: 135
    Rate: 338
    The anode has nothing to do with the vessel. Except for the water, of course.
    If you want to pump up effectively, you need to close the water supply to the tank and release (remove the pressure) the water by turning on the nearest tap. The warm one, of course. Then you connect the pump and blow until it works, necessarily with the tap open. The water is stiff and the pressure will build up quickly making it difficult to pump. Inflate to ~ 0.15mPa.
  • #5 13612279
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    It is a domestic hot water vessel, not what, so you need to pump it up to about 4 bars.
  • #6 13612519
    piotr_boncza
    Help: 135
    Rate: 338
    Magister_123 wrote:
    It is a domestic hot water vessel, not what, which means that you need to pump it up to about 4 bars.
    Thanks, I was late unconscious.
  • #7 13614413
    Tomi_
    Rate: 49
    Thank you for all your help.
    It worked.
    I will only add that I also had to turn on the cold water tap to fill the expansion vessel. With only the hot water tap turned on, there was no pressure in the vessel.
  • #8 13614781
    piotr_boncza
    Help: 135
    Rate: 338
    This thing is bunched. Check whether the check valve is in front of or behind the vessel. And the best way is to draw an installation or take a photo with a description.
  • #9 13617989
    Tomi_
    Rate: 49
    Well, the problem turns out to be more complex than I thought because in the installation (it is 9 years old and there have been no problems so far) miracles are happening to me.
    I became interested in the DHW expansion vessel because one evening in a single-function gas furnace (Vaillant VU PL 202 / 2-5 R3) with a reservoir, the pressure rose to over 3 bar and the safety valve was activated.
    I drained the excess water to the sewage system using a hose connected to the valve and checked the pressure in the diaphragm tank in the furnace (it was OK) and in the diaphragm DHW tank (it was zero). It may not be logical, but I found that the lack of air in the domestic hot water vessel may increase the water pressure in the stove.
    I pumped the tank up to 4 bar following your advice and after a while the problem with too high pressure reappears and the pressure in the furnace keeps rising. What I discharge them by draining the water with the safety valve, after some time the pressure increases again.
    And now for the best. The stove is off power. The main water valve is closed, the hot water in the hot water tank (Galmet Rondo 150l) is 52 degrees Celsius, the pressure in the furnace is set to 1 bar (I drained the water through the valve until 1 bar was left) and it is slowly rising all the time.
    When I turned off both valves (inlet and outlet) of the water from the furnace to the coil, the pressure does not increase.
    As soon as I unscrew one valve (it does not matter whether the inflow or outflow) that supplies hot water from the furnace to the coil, I hear a gentle noise as if liquid was flowing (the furnace is turned off, the main water valve is closed) and the pressure on the pressure gauge in the furnace increases until it finally stabilizes but at a fairly high level. When I open the main water valve, there is a lot of flow - you can see that the water loss is being replenished.
    It looks as if the coil has a hole and the water from the domestic hot water tank is being pumped into the furnace installation. Is it physically possible?
    The stove works normally, heats the water, the water (hot and cold) flows without problems.
    Is the domestic hot water tank to be replaced?
  • #10 14120005
    deejay602
    Rate: 27
    Tomi_ wrote:
    Thanks to everyone for your help.
    It worked.
    What if I have a hot water expansion vessel? how to inflate, turn on the hot tap and wait for the pressure to go down and pump? My plumber said that he had bought a vessel that can be used with warm water, and that the stove was tightly placed around it, so he installed it on a warm one. Until now, it worked as it should, but after a year I see a slight increase in pressure when heating the tap water.
The discussion revolves around the challenges of filling a 12L domestic hot water (DHW) expansion vessel connected to a 150L hot water tank. The user initially faced difficulties as the vessel was empty and showed no pressure. Responses suggested that the diaphragm might be faulty and recommended closing the water supply to the tank, releasing pressure by opening a hot water tap, and then using a pump to inflate the vessel to approximately 4 bars. The user later discovered that turning on the cold water tap was also necessary for proper filling. Additional concerns were raised about rising pressure in the system, potentially linked to the lack of air in the expansion vessel, which could affect the pressure in the gas furnace (Vaillant VU PL 202 / 2-5 R3). The discussion highlighted the importance of checking the installation and the position of the check valve.
