- Is it possible to dim the paint on painted parts of the car?
pl16 12738 15
How can I darken automotive paint that came out too light after spraying so it matches the original car color?
You usually cannot properly darken an aerosol spray to make it match exactly; the sprayed shade is often lighter because the layer is thin and the application method changes the color [#16896567][#16896428] If the paint is in a container, you can darken it a little by adding black paint or by using less thinner, but on a yellow color that may not work well and the pressure must also be adjusted [#16895085][#16895405][#16895299] Before painting the part, make a test spray on a sample strip and judge the shade from that result, not from the can or container [#16896384] For acrylic paint, a spray gun with paint, thinner, and hardener is a better option than an aerosol can if you want a result closer to factory finish [#16896621] Also, if the car's original paint has aged, even a paint selected by code or flap can still look different [#16896170]
  • #1 16895019
    pl16
    I ordered a paint like the original on the car, at least it was supposed to be but after applying it is lighter, in the spray it is much lighter and in the container only a little, it can be darkened somehow so that the color of the painted elements more or less equals the original paint?
    It's just that the paintwork is wrong for me or what could be the problem?
    I tried a part of the wheel arches and I do not know whether to continue painting or order a different varnish or are there any dimmers?
  • #2 16895085
  • #3 16895169
    nanab
    Help: 90
    Rate: 239
    You can adjust the color with the pressure on the reducer.
    Moderated By CameR:
    Spray varnish
    Reg. 3.1.11. Don't post messages that add nothing to the discussion.
  • #4 16895177
    płetwa
    Help: 165
    Rate: 551
    In a spray?
  • #5 16895200
    nanab
    Help: 90
    Rate: 239
    If you paint from a can, you won't do anything, you can only combine it with some inventions for dimming headlights.
  • #6 16895299
    pl16
    eurotips wrote:
    You won't do anything with the spray, but you can add black paint to the container and you will have a darker one.
    But the paint on the car is yellow, it may not work out well: /
    I thought that after applying it would be a bit darker and some clearcoat or something similar would not darken it?
  • #7 16895405
    strucel
    Level 36  
    Help: 271
    Rate: 623
    If you add less thinner, it will be darker, but the air pressure must also be adjusted.
    Moderated By CameR:
    Spray varnish
  • #8 16895857
    wichurewicz
    Help: 7
    Rate: 326
    Interesting spray paints are now selling, immediately with a pressure regulator and the possibility of adding a thinner.
  • #9 16895935
    strucel
    Level 36  
    Help: 271
    Rate: 623
    Mr. moderator, flipper, the wind-storm author wrote
    pl16 wrote:
    in the spray is much brighter and in the container only a little,?
    that is, it has such and such, maybe you could read it with understanding?
  • #10 16896170
    kkknc
    Help: 1915
    Rate: 6700
    You probably took the varnish by number. And you had to show the fuel filler flap. Unfortunately, the paint is getting old and in a summer car the difference will be, if not now, in some time. It's also a matter of shade and branding.
  • #11 16896232
    pl16
    It was the varnish that was chosen after the flap
  • #12 16896384
    milejow
    Help: 1563
    Rate: 5148
    Most mixers, if not all, have a slogan that reads:
    ,, without a test spraying, complaints will not be considered ,,
    Before the actual coating, a test spray should be made on the control strip and on its basis, the accuracy of the shade of the selected paint should be assessed.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #13 16896428
    kkknc
    Help: 1915
    Rate: 6700
    The method of applying it also affects the shade of the varnish.
  • #14 16896440
    pl16
    And you know why the shade in the spray is much lighter than the shade from the container because here and here it is the same and the difference is big?
  • #15 16896567
    milejow
    Help: 1563
    Rate: 5148
    You have a thick layer of paint in the container and hence a different color, spray, you apply a thin layer and the shade will always be different.
    Działalność własna
  • #16 16896621
    strucel
    Level 36  
    Help: 271
    Rate: 623
    There is also the issue of painting, the most common mistake of those who for the first time is applying masking tape and painting to the edge of the tape, then even a perfectly selected varnish will come out without any problems.
    The second thing is the issue of spray versus gun, if it is acrylic, then the gun is a much better option - we buy varnish, thinner and hardener and the varnish is the same as the factory one, in the spray you only have varnish + a lot of thinner (you can ask them to add hardener to the spray, but then you have a certain time, quite short for paint consumption.
The discussion revolves around the challenge of matching the color of a newly applied car paint to the original shade, which appears lighter than expected. Suggestions include adding black paint to the container to darken the color, adjusting the pressure on the reducer, and modifying the thinner ratio to achieve a darker shade. Users note that the method of application affects the final color, with thicker layers in the container resulting in different shades compared to thinner sprays. The importance of conducting a test spray before final application is emphasized, as well as the potential issues with aging paint and color discrepancies due to different application techniques.
TL;DR: One thin spray coat can look lighter than the same paint in bulk; “Before the actual coating, a test spray should be made.” [Elektroda, milejow, post #16896567]
Why it matters: This FAQ helps DIY car painters fix or avoid shade mismatches between aerosol and mixed paint on body panels, fast.
Can I darken mismatched paint after spraying from an aerosol?
From a rattle can, adjustment options are minimal. You can’t reliably darken the shade on-panel. The practical fix is to stop, test-spray, and remix or reapply with corrected parameters. Some “headlight dimmer” tricks exist but aren’t a true color correction. [Elektroda, nanab, post #16895200]
Why does paint look lighter from the spray than from the container?
Color perception depends on film thickness. In the can, paint looks darker because it’s a thick layer. Sprayed as a thin film, it reflects differently and reads lighter. One thin coat especially looks lighter than a pooled layer. Add coverage gradually and compare. [Elektroda, milejow, post #16896567]
Will clearcoat darken a too-light basecoat to match the car?
Do not rely on clearcoat to fix a base color mismatch. Perform a control test-spray first and only proceed once the base is right. This protects your time and avoids rework. “Before the actual coating, a test spray should be made.” [Elektroda, milejow, post #16896384]
How can I darken paint that’s in a mixing container?
You can add a small amount of black to darken. Mix thoroughly and test-spray before touching the car. Note that this changes the hue, which may be unwanted on colors like yellow. Proceed only after a satisfactory test panel. [Elektroda, Anonymous, post #16895085]
Can thinner amount or air pressure change the final shade?
Yes. Using less thinner can darken appearance, and correct air pressure is part of dialing in shade and texture. Adjust in small steps, test-spray, and verify under natural light before coating the panel. [Elektroda, strucel, post #16895405]
Do aerosols with adjustable pressure or added thinner exist?
Yes. There are spray cans sold with a pressure-regulator feature and the option to add thinner. These help fine-tune delivery, but still test-spray to confirm shade before the panel. [Elektroda, wichurewicz, post #16895857]
Why doesn’t flap-matched paint always match the body panel?
Paint ages. Sun and heat shift the car’s color over time, and different brands have slight shade differences. Even with flap-matching, expect variation and plan to blend or adjust technique. [Elektroda, kkknc, post #16896170]
What’s the right way to test color before painting a panel?
Make a control test-spray on a strip, then assess the shade under good light against the car. Proceed only if it matches. Many mixers state complaints require a prior test-spray. [Elektroda, milejow, post #16896384]
What does “reducer” mean here, and how does it affect shade?
Reducer refers to thinner that adjusts viscosity and evaporation. Reducing less can darken appearance, while more reducer can lighten and extend flow. Adjust with air pressure, then test-spray. [Elektroda, strucel, post #16895405]
Should I spray up to the edge of masking tape?
Avoid finishing directly on the tape edge. That novice mistake leaves an obvious line even with a perfect color. Feather and blend off the edge instead. [Elektroda, strucel, post #16896621]
Spray can vs HVLP gun: which is better for acrylic repairs?
A gun with the correct varnish, thinner, and hardener replicates factory results more reliably than a thin, pre-reduced aerosol. Ask your supplier for the right mix. [Elektroda, strucel, post #16896621]
How do I fix a mismatch I’ve already started on a wheel arch?
Stop and perform a control test-spray to validate shade. If off, correct the mix or method before continuing. Skipping the test invites larger rework later. [Elektroda, milejow, post #16896384]
Can I add hardener to a spray can? Any caveats?
Some suppliers can load hardener into a custom aerosol. Once activated, you have a short, fixed window to use the paint. Plan panels and test-sprays first. [Elektroda, strucel, post #16896621]
Quick 3-step how-to: prevent color mismatch on small repairs
  1. Make a control test-spray on a strip. 2. Compare shade against the car under daylight. 3. Only then coat the panel if it matches. [Elektroda, milejow, post #16896384]
