HP Compaq nx6110: Enabling Boot Menu for Formatting & Laptop Recovery
zox15 21372 6
  • #1 13695869
    zox15
    Rate: 20
    siemka,
    I have a problem with this laptop.
    I do not know how to enter the Boot Menu to make a format because the whole laptop broke down for me, please help me.
  • #2 13695925
    Dj Haker
    Help: 322
    Rate: 99
    F2, F12 or Del does not work?
    In bios, there is definitely a choice of booting, you do not need the Boot Menu.
    Have you looked into the instructions?
    Odzyskajdane.info
    Aleja Kijowska 24, Kraków, 30-079 | Company Website: https://odzyskajdane.info
  • #3 13695965
    zox15
    Rate: 20
    It means an old friend's laptop so I do not know. F10 is entering the BIOS, it will show the screen:
  • #4 13695982
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    After all, the screen is like a bull boot menu. So what's the problem?
  • #5 13695985
    zox15
    Rate: 20
    And what should I set up there to boot from the external disk drive? I have a USB disk drive.
  • #6 13695994
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    Set the USB CD-ROM to "First".
  • #7 13696107
    zox15
    Rate: 20
    miecho18 wrote:
    USB CD-ROM set to "First".
    Thanks, it works
The discussion revolves around accessing the Boot Menu on an HP Compaq nx6110 laptop for formatting and recovery purposes. The user initially struggles to enter the Boot Menu, with suggestions to use keys like F2, F12, or Del, and to check BIOS settings. It is clarified that F10 can be used to enter BIOS, where the user can configure boot options. The final solution involves setting the USB CD-ROM as the first boot device to enable recovery from an external USB disk drive, which successfully resolves the user's issue.
