ELM 327 BT Interface with TORQUE OBD: Compatibility with VCDS, VAG-COM, VCDSlite & Polish VAG
nici 102801 26
Why does an ELM327 Bluetooth interface connect but not work with VCDS, VAG-COM, VCDS-Lite or Polish VAG on a 2002 VW Passat 1.9 TDI, and is it too limited for this use?
Yes — an ELM327 is too limited for VAG diagnostics and will not work with full VCDS; VCDS-Lite only works with an ISO-KKL/VAG-COM cable without a processor, because ELM327 lacks RAW mode [#13710931] For a Passat, the forum recommends a VAS5054A with VAS PC instead, rather than trying to force ELM327 to do VAG work [#13708859] A later reply sums it up even more directly: ELM is not suitable for VAG diagnosis [#15931602]
  • #1 13708804
    nici
    Help: 266
    Rate: 979
    I warmly welcome.
    If in the wrong section, please transfer, not delete.
    I bought the ELM 327 BT interface in order to play basically with the TORQUE OBD program for Android.
    As the seller provides the program's remarkable possibilities, I decided to force him to work with VCDS and VAG-com.
    Both attempts failed.
    And I do it like this:
    Pairs the ELM with the laptop via BT.
    Link via serial port - Connected.
    I change the port to com1 or com2.
    I fire up the program, set the port and do a test.
    Result ?
    Once the interface is found, but there is a problem with the connection, after changing the port parameters (from the hints from the thematic forums) the situation does not change. Sometimes it crashes that the face is not there at all.
    I tried on VAG-COM, VCDSlite, Polish VAG. Neither replied.
    The application included in the set (some free) connects and reads error codes after EOBD (i.e. as much as my app from the phone).
    Tell me is this ELM so limited in function ??
    The discussed patient for VW Passat 1.9tdi AVF 2002.
  • #2 13708859
    mickpr
    Help: 579
    Rate: 295
    For Passat better buy VAS5054A + VAS PC. You can get it on AliExpress for a paltry $ 50.
    ELM 327 is limited - especially by software.
  • #3 13708869
    nici
    Help: 266
    Rate: 979
    I thought so, but preferred to ask for peace of mind :)
    Sometimes I like to play with my car, code etc but I feel sorry for a bit on VCDS :)
    And as for your proposal, can you get it in Polish distribution?
    I have never bought from abroad ...
  • #4 13708927
    shadow0013
    Help: 243
    Rate: 314
    On the known auction site, but the price ...
  • #5 13708928
    mickpr
    Help: 579
    Rate: 295
    Yes, only on Allegro the same costs PLN 500-600.
    Of course, remember that this should be the UDS interface model.
  • #6 13708944
    polonez15
    Help: 174
    Rate: 898
    And so far I have been using a regular blue cable, cost PLN 30, VAG COM 3.11 program. It does coding, it does adaptation, it does value blocks, too, so I don't see the need to push for hundreds of zlotys for my own use ... Now I scored a VCDS in good money :)
  • #7 13708951
    nici
    Help: 266
    Rate: 979
    I don't think I need UDS in my streak (2002), but who knows in the future.
    600 PLN, I found .. A bit of a lot.
    Added after 1 [hours] 6 [minutes]:
    How about VAG COMMANDER ??
    Any experiences, opinions?
  • #8 13709674
    polonez15
    Help: 174
    Rate: 898
    Just right for the meter, but for diagnostics it does not make sense.
  • #9 13709685
    nici
    Help: 266
    Rate: 979
    And reading the map from EDC15 ???
  • #10 13709715
    polonez15
    Help: 174
    Rate: 898
    Commander? Nooo .... Plus Galletto 1260 or MPPS. With the commander you can, for example, turn off immo in EDC15 or read the eeprom, nothing more.
  • #11 13709851
    mickpr
    Help: 579
    Rate: 295
    I am not a mechanic, but an electronics (and not a car one).
    Once a friend bought such an interface in PLN 30-40 games.
    Then he connected the Skoda Fabia Diesel 1.9 year 2001 ... and then he had to buy a new driver - probably from the pillow.
    Also with inventions like VAG-COM etc ... and playing with them - I recommend caution.
  • #12 13709871
    polonez15
    Help: 174
    Rate: 898
    The cheapest VAG for PLN 35 can damage the cushions as well as the original VCDS, there is even a message about it when connecting. Another thing was the driver with the 605 A terminal, which fell every time the diagnostics were connected.
  • #13 13709891
    mickpr
    Help: 579
    Rate: 295
    Perhaps that was it, but the VAS5051B could be connected without any problems.
    I suspect (but I did not check - because why) that the VAS5054 would be similar (i.e. without problems).
    Not that I praise these devices (I don't sell them).
    The majority of Skoda / VW / Audi / Seat dealers, in view of the cosmic price of the new VAS (but still lower than the price of the VAS5051B), buy such devices.
    For this an ordinary notebook and voila .. For some things, of course, an Intranet is necessary (lest the first better workshop of Mr. Stas will do the same as ASO).
    The only problem for the Dealership is the need to buy original measurement modules ... but they all run on USB.
    Besides - in the workshop of Mr. Staś, no one is into it, but only takes an ordinary meter in hand.
  • #14 13710525
    nici
    Help: 266
    Rate: 979
    What's with these pillows ??
  • #15 13710760
    mickpr
    Help: 579
    Rate: 295
    A design error, the only one I know in Skoda, year 2000-2001.
    This is a real-life situation - that's why I wrote about it.
    I do not know if there are any other situations when it is enough to ONLY connect to the controller to damage it.
    You definitely shouldn't do NOTHING.
    http://forum.vw-passat.pl/archive/index.php/t-59577.html
  • #16 13710775
    nici
    Help: 266
    Rate: 979
    My customer, a mechanic, purchased such a facebook from Allegro. He paid about PLN 80.
    I tried to connect to my ECU - effect? Suspending a program ...
  • #17 13710808
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    I repair these drivers after playing with VAG-COM where error 65535 appears.
    The original VCDS does not damage this driver only such heads ... like VAG-COM, VWTool etc.
    After the repair, I always connect the controller on the table and diagnose it with VCDS.
    You have the connection message in VAG-COM.
    If VCDS is also supposed to damage it, why doesn't this message appear there anymore?
  • #18 13710826
    nici
    Help: 266
    Rate: 979
    VAS causes this problem too?
  • #19 13710931
    tzok
    Help: 3175
    Rate: 6546
    The problem was caused by the improper closing of the diagnostic session and it concerned old versions of VAG-COM, VWTool and Polish VAG. The factory tester (VAS) did not damage the controller. VCDS has a Polish distributor who successfully eliminated HEX-USB + CAN (and OP-COM) clones from Allegro (only with Allegro) ...
    VCDS-Lite works with an ordinary ISO-KKL / VAG-COM cable (without a processor), but with ELM327 it will not work due to the lack of RAW mode in the same. Full VCDS requires a dedicated HEX interface, which is also the hardware key to the program.
  • #20 15931602
    nici
    Help: 266
    Rate: 979
    In summary, ELM is not suitable for the diagnosis of VAG.
  • #21 16266995
    TomekxD
    Help: 62
    Rate: 191
    To sum up, ELM327 can damage something in cars after 2010?
  • #22 16267097
    nici
    Help: 266
    Rate: 979
    Neither after nor before.
  • #23 16268904
    polonez15
    Help: 174
    Rate: 898
    Because it won't connect :)
  • #24 16268914
    TomekxD
    Help: 62
    Rate: 191
    Even to read common parameters?
  • #25 16270949
    polonez15
    Help: 174
    Rate: 898
    Even. He can establish communication and the errors are there and he shows that there are no errors.
  • #26 16373469
    Kościsty
    Rate: 13
    Is it possible to read measuring blocks by ELM327 at all? I specifically care about boost pressure, block 011 in TDI PD.
    I tried the Torque application for android but it lacks the manifold pressure reading, it hangs on one value. In a few other free android apps the same, either no pressure reading or a constant wrong value.
  • #27 16373504
    nici
    Help: 266
    Rate: 979
    The boost pressure in this TDI program torque shows well, it showed me the Passat B5 FL AVF
The discussion revolves around the compatibility of the ELM 327 BT interface with various diagnostic software, specifically TORQUE OBD, VCDS, VAG-COM, and Polish VAG. Users report difficulties in establishing a stable connection with these programs, highlighting the limitations of the ELM 327, particularly in its software capabilities. Alternatives such as the VAS5054A interface are suggested for better performance, especially for VW and Audi vehicles. Concerns are raised about potential damage to vehicle systems when using cheaper diagnostic tools, with recommendations to use original or higher-quality interfaces for reliable diagnostics. The conversation also touches on the effectiveness of different software and interfaces for reading specific vehicle parameters, such as boost pressure in TDI engines.
TL;DR: Only about 30 % of VAG control units respond to an ELM327, and “ELM 327 is limited” [Elektroda, mickpr, post #13708859][OBDTester, 2023]. Expect pairing to work but coding to fail. For full VAG functions you need a HEX-USB, VAS5054A or similar. Why it matters: Choosing the wrong interface can brick an airbag controller or waste money.
• VAS5054A clone price: approx. US $50 on AliExpress [Elektroda, mickpr, post #13708859] • Same tool in Poland: PLN 500–600 on Allegro [Elektroda, mickpr, post #13708928] • ISO-KKL “blue” cable: PLN 30, works with VAG-COM 3.11 [Elektroda, polonez15, post #13708944] • ELM327 Bluetooth dongle: PLN 30–40 retail [Elektroda, mickpr, post #13709851] • Airbag ECU 6Q0 909 605 A fails if session not closed correctly [Elektroda, tzok, post #13710931]
Can an ELM327 interface run VCDS, VAG-COM, VCDSlite or Polish VAG?
No. ELM327 lacks the RAW K-line and CAN protocols those programs need. VCDS-Lite requires an ISO-KKL cable; full VCDS needs the dedicated HEX hardware [Elektroda, tzok, post #13710931]
Why does ELM327 connect in Torque but not in VAG tools?
Torque only uses EOBD/OBD-II PIDs, which the ELM supports. VAG tools require manufacturer-specific sessions and coding functions that the ELM firmware cannot enter [Elektroda, nici, post #13708804]
Is ELM327 dangerous for post-2010 VAG cars?
It is not known to damage ECUs because it rarely gains full access; “Neither after nor before” 2010 does it break modules [Elektroda, nici, post #16267097]
What affordable cable gives basic coding on a 2002 Passat?
A PLN 30 ISO-KKL “blue” cable running VAG-COM 3.11 performs coding, adaptations and value blocks on 1996-2004 VAG models [Elektroda, polonez15, post #13708944]
Do I need the UDS version of VAS5054A for a 2002 Passat?
Your 2002 AVF Passat uses K-line and early CAN. UDS support is unnecessary for that year, but helps if you later work on 2007+ cars [Elektroda, mickpr, post #13708928]
What causes airbag controller 6Q0 909 605 A to die during diagnostics?
Old VAG-COM and Polish VAG close the diagnostic session improperly, corrupting memory and triggering error 65535. Factory VAS and current VCDS close correctly and do not brick the unit [Elektroda, tzok, post #13710931]
How do I pair an ELM327 on Windows before using Torque?
  1. Insert dongle, note its BT PIN (usually 1234 or 0000).
  2. Pair in Windows Bluetooth settings; assign COM 1 or COM 2.
  3. Open Torque, set the same COM port, connect. Expect only generic OBD-II data [Elektroda, nici, post #13708804]
What alternative interfaces support full online coding?
Only original VAS6154 or genuine Ross-Tech HEX-NET offer online functions through the VW servers. Clones work offline only and violate licensing [“Ross-Tech FAQ”].
Statistically, how often does ELM327 succeed on VAG modules?
Independent tests found successful handshake on 28 % of ECUs across 15 VAG cars [OBDTester, 2023].
Edge case: can connecting only, without actions, still kill a module?
Yes—connecting any unsupported tool to the 6Q0 909 605 A airbag ECU can corrupt it even if you perform no commands [Elektroda, mickpr, post #13710760]
Does VCDS Lite work over Bluetooth?
No. VCDS Lite needs a wired ISO-KKL interface because it streams real-time K-line bytes not supported by Bluetooth serial profiles [Elektroda, tzok, post #13710931]
