Lenovo ThinkCentre B320 – Error 0135 Fan Failure on startup, what to check?
gulasz96 24552 4
  • #1 13795410
    gulasz96
    During the last boot of the Lenovo ThinkCentre B320, the computer was stuck on the BIOS screen with Error 0135: Fan Failure. After several reboot attempts, the problem persisted. The warranty period has expired, so I would like to know if there is a solution to this problem without having to send it to the service center, because it is my work tool and I really care about time. Below is a photo:
    Pan Szyszka
    Help: 148
    Rate: 95
    The error suggests a fan failure - try to disconnect it, see if it spins.
    Clean or replace the stopped case fan to prevent overheating
    #4 13795441
    safbot1st
    Help: 2719
    Rate: 1585
    The bios stops booting due to the case fan stopping.
    Perhaps enough dust has accumulated to stop the fan, or the fan is simply defective.
    If you can - open the housing and clean the fan and the surrounding area with a dry brush of dust.
    If you don't feel up to it - service.
    Do not use the computer in this state (do not leave it running on this start screen for a long time) - it may end up being damaged by overheating.
  • #5 13795762
    gulasz96
    Vacuuming the fan helped :) Thanks for your help, I'm closing the issue.
