Lenovo IdeaPad 320-15ISK - Loud Laptop Operation, i3-6006U, 4GB RAM, 1TB Disk, GF920MX, Win10
Dreams_1290 6225 14
How can I determine what is causing my Lenovo IdeaPad 320-15ISK to run loudly, and what can I do about it?
The noise is most likely coming from the 1 TB hard drive, and if you want the laptop to be quiet the practical fix is to replace it with an SSD. To verify the source, run HWiNFO64 in sensors-only mode and attach a screenshot, and also provide a CrystalDiskInfo screenshot [#17048931] The noise can come from the fan, the disk, the drive, or even board components such as coils, so it is worth checking all of them [#17049021] After hearing the recording, the discussion concluded that it was evidently the hard disk [#17052848] A 1 TB HDD can work like that, while an SSD is quieter but costs extra, so replacing the disk would be at your own expense [#17052877][#17053089]
  • #1 17048897
    Dreams_1290
    Last Saturday I bought a Lenovo laptop, IdeaPad 320-15ISK model (15.6 ", Intel? Core? I3-6006U, 4GB RAM, 1TB Disk, GF920MX graphics, Windows 10). The problem is louder computer work, probably not this is the noise from the fans. I have to guarantee it, is there any other way out?
    Kasek21
    Help: 4981
    Rate: 3547
    Download and run HWiNFO64 (sensors only) -> include screen in this topic.
    By the way, screen from CrystalDiskInfo.
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. Post this noise? If you say it's not from the fan?
    Mac!
    Help: 19
    Rate: 27
    Noise may come from
    1> fan
    2> disk
    3> drive
    4> some electronic components on the board, e.g. coils
  • #5 17049095
    Dreams_1290
    If I want to add an attachment, I get the following message: sound.m4a - Extension not allowed. What should I do ?
    Pedros050
    Help: 2471
    Rate: 3926
    Post to YT and paste the link.
    RADU23
    Help: 2428
    Rate: 1732
    Package the file with Winrar and upload via "Add attachment".
    https://www.winrar.pl/winrar/pobierz
  • #8 17052033
    Dreams_1290
    Good evening,
    Sorry for the break, but I am sending a disturbing sound:
    EDIT
    I'm sorry but I missed one important thing, yesterday I gave my laptop to the store to advertise a loud job and I was immediately given a new model that has the same ailment.
    I merged. RADU23
    • Dżwięk.rar (114 KB) You must be logged in to download this attachment.
    Mac!
    Help: 19
    Rate: 27
    Evidently a hard disk for me
    Pedros050
    Help: 2471
    Rate: 3926
    There is this 1TGB HDD drive sure that it goes like that? And how @ Dreams_1290 wants to be quiet, let them change the disk to SSD and there will be silence.
  • #11 17053057
    Dreams_1290
    So this hard disk normally works with this sound? When it comes to replacing the disk, at my expense?
  • #12 17053089
    Pedros050
    Help: 2471
    Rate: 3926
    Obvious SSDs are more expensive and you have to pay extra.
  • #13 17053130
    Dreams_1290
    OK, but this loud operation is normal with a 1TB HDD?
  • #14 17053142
    Pedros050
    Help: 2471
    Rate: 3926
    After all, everything is humming a fan on the processor HDD is normal? But if it is so bothersome for you, replace the disk and you will have silence how much it bothers you in your new laptop?
  • #15 17053155
    Dreams_1290
    Thank you for your help, I consider the topic closed.
The discussion revolves around a Lenovo IdeaPad 320-15ISK laptop experiencing loud operational noise, which the user suspects is not solely from the fans. Various potential sources of the noise are identified, including the hard disk drive (HDD), optical drive, and electronic components. Suggestions for diagnosing the issue include using software like HWiNFO64 and CrystalDiskInfo. The conversation highlights that the noise may be typical for a 1TB HDD, and replacing it with a solid-state drive (SSD) could significantly reduce noise levels, albeit at an additional cost. The user ultimately decides to close the topic after receiving assistance.
TL;DR: 2 out of 2 swapped Lenovo IdeaPad 320-15ISK units showed the same noise; "Evidently a hard disk for me." Confirm with HWiNFO64 and CrystalDiskInfo, then consider an SSD upgrade for silence. [Elektroda, Mac!, post #17052848]
Why it matters: This helps Lenovo 320-15ISK owners quickly pinpoint loudness causes and choose a fix or upgrade path.
Why is my Lenovo IdeaPad 320-15ISK loud when new?
The noise most often comes from mechanical parts. "Noise may come from fan, disk, drive, or coils." HDD hum or seek sounds are common. Fans spin up under load. An optical disc can spin intermittently. Coil whine can be tonal or chirpy. [Elektroda, Mac!, post #17049021]
Is the loud hum or clicking normal for the 1TB HDD in this laptop?
Yes, mechanical HDDs produce audible hum and seek sounds, especially in quiet rooms. The forum guidance here treats that as normal behavior. If it bothers you, the practical remedy is swapping the HDD for an SSD for quiet operation. [Elektroda, Pedros050, post #17053142]
Should I return it or is this expected behavior?
In this thread, a store swap yielded the same noise on a second unit. That is 2 of 2 units, suggesting the sound is characteristic of the HDD-equipped configuration, not a one-off defect. An SSD upgrade is the reliable way to eliminate it. [Elektroda, Dreams_1290, post #17052033]
How can I check if the sound is from the HDD or the fan?
Use the requested diagnostics and correlate activity with noise.
  1. Install and run HWiNFO64 (sensors only) to view system activity.
  2. Open CrystalDiskInfo to read the HDD’s SMART status.
  3. Capture screenshots and share them for review. These help separate disk and thermal behavior. [Elektroda, Kasek21, post #17048931]
What do HWiNFO64 and CrystalDiskInfo tell me?
HWiNFO64 shows sensor data that hints at fan activity and system load. CrystalDiskInfo shows HDD health via SMART status. Together, screenshots provide enough context for the forum to confirm whether the HDD is the noise source and if it’s healthy. [Elektroda, Kasek21, post #17048931]
Will switching to an SSD make the laptop quiet?
Yes. SSDs have no moving parts and operate silently, removing HDD hum and seek sounds. As one expert advised, replace the HDD with an SSD and "there will be silence." Expect a quieter laptop and faster responsiveness after the upgrade. [Elektroda, Pedros050, post #17052877]
Do I have to pay for the SSD upgrade?
Yes. The SSD is an optional, user-paid upgrade. It is not a warranty replacement for normal HDD noise. Plan for the SSD cost and possible migration or installation service if you do not handle the swap yourself. [Elektroda, Pedros050, post #17053089]
Could the noise be the optical drive or coil whine instead?
Yes. The thread identifies the optical drive and motherboard coils as potential noise sources. Optical drives can spin when accessed. Coils can produce high-pitched tones. Confirm with diagnostics and by listening near the drive bay versus the exhaust. [Elektroda, Mac!, post #17049021]
How do I share an audio sample if .m4a is blocked by the forum?
Compress the audio file into a .rar archive and use Add attachment to upload it. This method bypasses the filetype restriction so others can hear the noise and help diagnose it effectively. [Elektroda, RADU23, post #17050120]
Can I upload the sound to YouTube instead?
Yes. Upload the recording to YouTube and paste the link into your post. This provides easy playback for helpers and avoids forum attachment limits on certain file extensions. [Elektroda, Pedros050, post #17049112]
What’s the quickest fix if the HDD noise annoys me?
Replace the mechanical 1TB HDD with an SSD. This removes mechanical noise and improves responsiveness. It is the forum’s recommended resolution for a quiet experience on this model when noise is traced to the hard drive. [Elektroda, Pedros050, post #17052877]
What exact configuration was discussed in this thread?
Lenovo IdeaPad 320-15ISK, 15.6-inch display, Intel Core i3-6006U, 4GB RAM, 1TB hard disk, GeForce 920MX, Windows 10. Knowing this helps others match behaviors and fixes to a comparable hardware setup. [Elektroda, Dreams_1290, post #17048897]
