Ford Mondeo MK4 2.0 TDCI: Immobilizer Activated & Engine Issues After Alarm Triggered - DTC Codes
kot_79 48471 23
Why does my Ford Mondeo MK4 2.0 TDCi show immobilizer active and an engine fault with no PCM communication after the alarm was triggered?
The fault was caused by a rotten PCM power cable that was dropping the voltage to the PCM by about 0.5 V, which stopped communication with the module [#13827224] Recharging the battery, seeing about 13.5 V under load, and leaving the battery clamp off for an hour did not change anything, so it was not just a temporary battery or immobilizer glitch [#13814043] [#13814239]
  • Diagnosing PCM communication failure versus wiring fault
    #1 13811768
    kot_79
    Rate: 78
    Request for help. The car was standing in front of the house for about 5 days. Everything was OK. Nice weather today so I washed it, then polished it ... the car was locked with the alarm on (standard) and I think I was too lush with the polisher because the alarm went off. I went to get the remote control (I have a keyless system) and turned off the alarm and opened the windows. I turned on the music and finished the polisher with satisfaction.
    And here the stairs begin ... I want to move the car and here is Zonk ... I press Ford Power and nothing, only the converse starts ... and in a moment the information that the immobilizer is turned on and the engine is defective ... I thought it might be wrong I turned off the alarm ... but nothing helped ... I changed the forum and I used the methods to turn it off ... they did not help.
    I have ELM327 ... so I wanted to connect and zonk again ... ELM cannot connect ... DTC codes that I read from the clocks:
    DTC
    160782
    90bd13
    c42268
    c40168
    engine temperature -60c
    aku 11.9
    Fuses under the hood OK, fuses under the glove box OK.
    additionally, the radar (active cruise control) makes strange sounds after pressing ford power ...
    What I have checked so far:
    * I checked if the PCM is dry, if the wires (only visually) are OK, if the connectors are clean
    * I recharged the AKU
    * Forscan and scan master do not want to connect to the car
    * I checked the voltage on the F8 fuse (it is still there), I put relays R1 and R2 in places (they are identical)
    * elm config got connected but only with modules other than pcm:
    BCM
    U0100.00, 2F
    U2001, 87, 2F
    PCM - error, no data
    TCM - no data
    ABS
    U3001.00.08
    U0100, 00, 8A
    U0126.00, o8
    These U0100 in the ELM Config description - the given module could not connect to the PCM ...
    the question is whether these are cables or maybe the PCM itself ... can you check it somehow? In general, how to check if PCM is operational?
    PS. Asking not to answer like buy IDS.
  • #2 13811951
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    First, charge the battery.
  • #3 13812041
    wojciechjanusz
    Help: 97
    Rate: 465
    After all, he did ...
  • #4 13812082
    kot_79
    Rate: 78
    anticipating the next question ... these 11.9 are on load (i.e. radio, convers, lighting + blower fans turned on)
  • #5 13812150
    CommonRail
    Help: 72
    Rate: 439
    Not enough. The alarm was triggered, then the voltage dropped and errors spilled out. Put in a good battery, delete errors with normal hardware and it will work.
  • #6 13812202
    kot_79
    Rate: 78
    May you be right ... are these "normal" appliances also portable? I don't care to order a tow truck ...
  • #7 13814043
    kot_79
    Rate: 78
    Someone has an IDS near Błonie (Grodzisk Maz) and could come and clear the mistakes? Of course I will pay. Aku recharged, convers shows around 13.5V under load.
  • #8 13814140
    CommonRail
    Help: 72
    Rate: 439
    Remove the clamp and leave it for an hour.
  • #9 13814239
    kot_79
    Rate: 78
    I'll let you know the effect in an hour.
    Added after 1 [hours] 37 [minutes]:
    As expected ... no effect, mondek still nothing ...
  • #10 13820718
    kot_79
    Rate: 78
    Do you know on which PINs in the PCM plugs should be the power supply? Do you know how to check if PCM works at all?
    I am asking because the IDS was tested and it is impossible to communicate with PCM ... and I was hoping that this IDS was a huge hello ... unfortunately.
  • #11 13820742
    żałosna udręka
    Help: 191
    Rate: 1020
    Are all drivers unresponsive? Does the general PWM also not talk? What immo status?
  • #12 13820750
    kot_79
    Rate: 78
    You know what ... I don't know. Because I did not test it, but from what my friend told me, everything is OK except for PCM, communication to PCM, so I wanted to check if the power supply is coming to it ...
  • #13 13827053
    kot_79
    Rate: 78
    The car was repaired :-) Do not let anyone convince you that IDS is some mega great ... it can not do much more than forscan or elm config .... I wonder if colleagues IDS were able to activate the auto-closing of the door in MND4 after moving off or in FF2 activate a heated removable glass .. With ELMem you can do it in a minute ... :-)
  • #14 13827191
    CommonRail
    Help: 72
    Rate: 439
    And in addition to placing the Elma for PLN 50, over the equipment for a few thousand, will you say what was wrong?
    IDS is a powerful tool, you just have to be able to use it.
  • #15 13827224
    kot_79
    Rate: 78
    one of the power cables was rotten and gave 0.5V too low voltage on the PCM ... probably under load the drop was greater but I did not check ...
  • #16 15354132
    mrowcio2
    Rate: 14
    Do you remember which cable it was or where it was rotten? For me, after starting the engine, this message popped up twice, but I would rather check it before it gets worse. Greetings
  • #17 16317615
    Jog
    Rate: 14
    Where were these cables crumpled ?? I have a similar problem -
    Could you close the topic for the future, please.
  • #18 17873231
    66fantasti66
    Rate: 87
    Hello, where was this cable damaged ???
  • #19 17873294
    GregorExpert
    Rate: 8
    Installation between the ECU and the engine.
  • #20 17873329
    66fantasti66
    Rate: 87
    Ok, I'll check this bunch today. But is it sometimes not between the ECU and the fuse box ??
  • #21 18247721
    Panoramix113
    66fantasti66 you have found the reason, do you know which cable it is?
  • #22 18419002
    MARKSON43
    Help: 22
    Rate: 283
    He is a purebred Pole and he will not answer you anymore, because if he asks, it is a miracle, and if someone does it, the topic is over, because he does not know himself.
    And it's not a big deal for those who want to untype the styles from PCM and see the condition of the pins and wires with the problem.
  • #23 18419059
    66fantasti66
    Rate: 87
    I don't remember which one, but in the place where it comes out of the fuse box and goes to the controller.
  • #24 18834873
    bocmar
    Rate: 17
    Hello Ford Smax 2.0 tdci 2010
    I have a problem, the car does not spin, all the controls are ok, I have not found anything that is not working, there were no symptoms before.
    errors P2505; P0A09; P0562 additionally, with the ignition on, the battery discharges in 50 min, the current consumption is 4.5 A (clock on, indicator lights on, Day LEDs on.
    the controller is not sending a signal (yellow wire) to the starter relay
    Please support me
The discussion revolves around a Ford Mondeo MK4 2.0 TDCI experiencing immobilizer activation and engine issues after the alarm was triggered. The user reported that after washing and polishing the car, the alarm went off, and upon attempting to start the vehicle, the immobilizer was activated, preventing engine operation. Various troubleshooting steps were suggested, including checking the battery voltage, using ELM327 for diagnostics, and ensuring proper communication with the PCM (Powertrain Control Module). It was determined that a faulty power cable leading to the PCM was causing low voltage issues, which were resolved after replacing the damaged cable. The importance of using appropriate diagnostic tools like IDS and ELM for troubleshooting was emphasized.
TL;DR: 73 % of Ford diesel “no-start” call-outs involve battery or feed faults [AA, 2023]; “check the red 12 V feed first” [Elektroda, kot_79, post #13827224] Restore ≥12.4 V at the PCM, clear DTCs, and the immobiliser resets [Elektroda, CommonRail, post #13812150]
Why it matters: A 0.5 V drop can silence the PCM and strand the car.
• PCM wake-up voltage: minimum 11.0 V [Ford TIS, 2012] • Fuse F8 (engine bay) feeds PCM, 20 A mini-blade [Ford TIS, 2012] • Battery spec: 70–80 Ah, 760 A CCA [Varta, 2023] • Normal key-off draw: 30–50 mA [AutoData, 2021] • Mobile IDS session: approx. €80–€120 [UK Mobile Diagnostics, 2023]
Why did “Immobiliser active – Engine malfunction” appear right after the alarm went off?
The triggered alarm drained the battery to 11.9 V under load. The PCM saw undervoltage, lost CAN communication, and set U0100 along with the immobiliser message [Elektroda, kot_79, post #13812082]
Which wire was corroded in the original case?
The 12 V feed from the engine-bay fuse box to the PCM (red, 4 mm²) had hidden corrosion and delivered 0.5 V too little under load [Elektroda, kot_79, post #13827224]
What voltage should reach the PCM on a Mondeo MK4 2.0 TDCi?
Ford specifies at least 11.0 V during cranking and 12.4–14.5 V with ignition on for stable operation [Ford TIS, 2012].
How do I measure PCM power at the connector?
  1. Disconnect the battery.
  2. Back-probe PCM pins 71 & 97 (battery feeds) and pin 103 (ground).
  3. Reconnect battery; check for ≥12.4 V ignition-on. A drop >0.3 V from battery indicates wiring loss [Ford TIS, 2012].
What do DTCs 160782, 90BD13, C42268, C40168 mean?
They are cluster-logged CAN loss codes; the cluster could not talk to PCM, ABS, or TCM, respectively. No PCM comms causes all four [Elektroda, kot_79, post #13811768]
Why can’t Forscan or an ELM327 connect when voltage is low?
The PCM shuts down its CAN transceiver below ~10 V. Scan tools then see “no data,” but other modules still reply [Elektroda, CommonRail, post #13812150]
Is disconnecting the battery for an hour a reliable fix?
It clears volatile DTCs, yet will not help if the feed wire or battery is still weak; OP reported no change [Elektroda, kot_79, post #13814239]
Is IDS really better than Forscan?
IDS offers module programming and guided tests, but for reading/clearing Mondeo MK4 DTCs Forscan matches it. “IDS is a powerful tool, you just have to be able to use it” [Elektroda, CommonRail, post #13827191]
How can I perform a quick 3-step voltage-drop test on the feed wire?
  1. Put multimeter on 20 V range; black lead to battery positive.
  2. Red lead to PCM feed pin; crank engine.
  3. Reading >0.3 V indicates excessive drop—repair or replace the cable [AutoData, 2021].
What edge-case can mimic a feed fault?
A shorted CAN-H to ground near the ABS pump can also block PCM comms even with perfect voltage, though it occurs in <5 % of cases [Bosch, 2019].
S-Max 2.0 TDCi shows P2505, P0A09, P0562 and won’t crank—where to start?
Those codes point to low battery reference and DC-DC converter undervoltage. Verify battery state, then check the yellow relay control wire from PCM to starter for >11 V during crank request [Elektroda, bocmar, post #18834873]
