In total, he will throw out the standard 4-digit OBD codes, the letter P, B at the beginning.
What you want to read is I really do not know, especially Restraint Control Module
Have you found a description of the error codes in Polish?
Because I have a problem with the engine, the glow plug indicator blinks, I read error 2336 and I do not have a Polish description of errors and I do not know in English.
The lamp was on all the time, the injector test showed that the injector was damaged on the 4th cylinder so I replaced it with a new one. I do not know why the driver lost the injector codes for 2, 3, and 4 cylinders / in the service have been coded /. Knowed that you can inject injections with formidable 2.03, but you have to code them individually.
The discussion revolves around the need for descriptions of error codes for the 2003 Ford Mondeo 2.0 TDCi 130 PS, particularly focusing on engine and airbag-related issues. Participants mention that the vehicle generates standard 4-digit OBD codes, starting with the letters P and B. One user inquires about a specific error code (2336) related to the engine, indicating a problem with the glow plug indicator. Another user suggests checking the fuel injectors, as a damaged injector was identified in a previous case, leading to the need for coding replacements for multiple cylinders. The conversation highlights the challenges in finding error code descriptions, especially in Polish. AI summary based on the discussion. May contain errors.
