Siemens D12-52 washing machine - the subtitles on the display have disappeared
PiotrG. 5985 6
  • #1 13822971
    PiotrG.
    Rate: 47
    There are no subtitles on the display. The washing machine stopped working after turning on it is just an empty display.
  • #2 13825497
    kruszyna 2
    Help: 15
    Rate: 96
    The voltage reaches the washing machine
  • #3 13830928
    PiotrG.
    Rate: 47
    Yes
    the display is lit but Siemens D12-52 washing machine - the subtitles on the display have disappeared is missing
    you can not see that an ankle is detached under the panel
  • #4 14228627
    silnik22
    Rate: 20
    Hello. I have a question, was it possible to solve this problem because it happened to me.
    Greetings.
  • #5 14265864
    silnik22
    Rate: 20
    Piotr G. wrote to me at Warsaw University of Technology that in his case the engine brushes were replaced.
    Indeed, my brushes were heavily worn, but the replacement did not bring any effect.
  • #6 14492606
    focus626
    Rate: 9
    Has something helped? At first, the drum of the washing machine did not move and then the inscriptions disappeared on the display. I've just replaced the brushes and the same effect. No subtitles on the display
  • #7 17636071
    Dishonored2513
    Hello and I hope that the matter has not expired. I would like to ask what to do with this problem? I have the same washer-dryer and it broke down for the first time. Could someone tell me what the problem is in this case and what should be done?
The discussion revolves around a Siemens D12-52 washing machine that has experienced a malfunction where the display shows no subtitles and remains empty after being powered on. Users report that the display is lit but lacks visible information, indicating potential issues with the machine's internal components. Some participants mention that replacing the motor brushes did not resolve the problem, suggesting that the issue may not be solely related to the brushes. There is a call for solutions and insights from others who have faced similar problems with the same model.
