Siemens SE65M352EU dishwasher - E24 error and lack of water, tap light
AsiaM1 27099 7
  • #1 18265287
    AsiaM1
    My E24 error code comes on and there is no water (faucet light) and what should I do, and unfortunately it is in the building? :(
  • #2 18266158
    Piotr2608
    Help: 851
    Rate: 4487
    Ulala, that`s not good.
    If everything is OK with the drain, the washing pump most likely needs to be replaced.
    ZimTech Piotr Zimny
  • #3 18266251
    qwazarpl
    Help: 37
    Rate: 270
    Is there water in the dishwasher?
  • #4 18266445
    pawlik722
    Help: 99
    Rate: 357
    Does the dishwasher use water? If it takes in, does it start washing or does it make a humming sound and release the water after a while? Pour about 5 liters of water manually, then start the dishwasher and tell whether it has drained the water.
    I suspect a blocked pump impeller.
  • #5 18299762
    AsiaM1
    I poured water into the dishwasher and it actually drained.
  • #7 18301883
    freetz_master
    Help: 117
    Rate: 156
    Just replace the motor in the heating pump. This is what it looks like in the photo. For an efficient technician, it takes 30 minutes of work. It may also happen that something is "screwed" into the pump and blocking the impeller. Some piece of glass. I once had a situation where a piece of plastic softened so much during washing that it got stuck between the rotor blades and then stiffened, blocking the rotor.
  • #8 18715507
    AsiaM1
    However, this didn`t solve my problem and now it`s on fire error E25 .
The Siemens SE65M352EU dishwasher is experiencing an E24 error code, indicating a lack of water, as evidenced by the faucet light being on. Users suggest checking the drain and the washing pump, as a blocked pump impeller may be the cause. One user successfully poured water into the dishwasher, which then drained, indicating a potential blockage. Another user recommended replacing the motor in the heating pump, noting that foreign objects could obstruct the impeller. The issue escalated for one user to an E25 error, indicating further complications.
