[Solved] Siemens SN236I02KE dishwasher - Error E19 at the beginning of washing
Manfredo89 32622 4
  • #1 18748362
    Manfredo89
    Rate: 20
    Hello all forum members,
    I have a problem with a Siemens dishwasher. After three years of use, error E19 appeared.
    After reading several posts, everything indicates that it is about the solenoid valve.
    I found information that an element on the board may have burned out.
    My question is, if I replace the entire solenoid valve, will the problem be solved?
    Can anyone suggest a solution?
    Regards
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3826
    So maybe start there and have a good photo report...
  • #3 18749233
    Manfredo89
    Rate: 20
    I started with this.
    I cleaned it and put it back, the effect was only temporary.
    I measured the wires. It reached 230 VDC and error E19 occurred.
    Is it worth replacing the solenoid valve or blaming the module?
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6953
    Are we fairies?
    If you prefer to fix things with YouTube, then fix them with him, if you expect help from us, do what you were asked to do...
  • #5 18761958
    Manfredo89
    Rate: 20
    the dishwasher was able to start.
    I don't know how much I removed the effect and how much the cause.
    I'm not comfortable with electronics, so I started with the easier part.
    I ordered and replaced the solenoid valve.
    The dishwasher has been cleaned and washed twice and the error does not appear.
    Thank you very much for your help.
