Electrolux EWT 1262 - Washing machine problem - Display off, but can hear sound
follownews 2649 3
  • #1 18887827
    follownews
    What could be the reason that display is not working (no light) but when buttons are touched, I can hear sound?
  • #2 19236928
    Tomi51
    Help: 6
    Rate: 11
    Czy sprawdziles polaczenia elektryczne wyswietlacza .Jezeli masz sygnal dotykajac klawiszy to moze byc cos na boardzie lub polaczeniu. Sprawdz>
  • #3 19236963
    stiff12
    Help: 66
    Rate: 450
    More information, does the washing machine start the program cycle?
    Check connections between display and module.
  • #4 19237405
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    Damaged soft power module. Programming module for authorized service.
