Extraordinary Case: Removing Stuck Key and Unlocking Closed Door Without Specialist Assistance
Dest3213 79680 6
  • #1 13843404
    Dest3213
    Rate: 12
    Hello, I know there are many such cases, but mine is a bit extraordinary. There is a key in the door that cannot be removed or used to open the door (the door is locked). Can this problem be solved somehow without replacing the door and calling a specialist?
  • #2 13843421
    adam158
    Help: 36
    Rate: 232
    most likely, it will be necessary to replace the insert
  • #3 13843440
    Dest3213
    Rate: 12
    I took out the key, the door is still locked and the lock does not respond to opening. I have a new lock, but how do I remove the old one from a locked door?
  • #4 13843446
    adam158
    Help: 36
    Rate: 232
    Drill the cylinder, open the lock, then open the door and start replacing the lock.
  • #5 13843519
  • #6 13844351
    GT_194
    Help: 6
    Rate: 34
    Of course, drilling the insert will do the trick. We drill below the key so that the locking pins come out through the drilled hole, then the insert can be turned with a screwdriver. I've done this several times myself.
  • #7 13844452
    adam158
    Help: 36
    Rate: 232
    Open the insert.
The discussion revolves around a user facing a unique problem of a stuck key in a locked door, which cannot be removed or used to unlock the door. Various solutions are proposed, including replacing the lock insert, drilling the cylinder to release the locking pins, and breaking out the insert if it is an A2 under-handle type. Some responses suggest using a curved screwdriver to manipulate the lock after breaking the cylinder, while others emphasize the need for careful removal of the insert to avoid further damage. The consensus indicates that drilling the insert is a viable method to unlock the door, allowing for the replacement of the lock afterward.
