Opening Keyed Lock from Inside: Exterior Door, Small Knob, Tips & Techniques
xbartekzx 11028 6
  • #1 17425385
    xbartekzx
    Hello, does anyone know how to open a door lock in an exterior door with a key for this lock, if the lock is closed from the inside with such a small knob? The castle looks something like this:
  • #2 17425459
    marekhab
    Help: 251
    Rate: 267
    You cannot open it with the key, because it is a separate mechanism with a separate bolt.
  • #3 17425469
    xbartekzx
    I felt something like that. Thanks for the quick reply.
  • #4 17426768
    jarekstryszawa
    Help: 49
    Rate: 482
    I detached the slide from the knob at home, and I replaced the insert with a model with a knob - there is no possibility that you will not enter when someone inside, for example, is bathing.
  • #5 17427242
    zimny8
    Help: 26
    Rate: 504
    If our access to the hinges then cut them off, the cost of the hinges is small compared to demolishing the door.
  • #6 17427341
    jarekstryszawa
    Help: 49
    Rate: 482
    In this type, there is no access to the hinges - all that remains is to remove the escutcheon (the easiest way is to drill the two fixing screws).
  • #7 17427883
    raudek
    Help: 30
    Rate: 162
    Removal = destruction. The disassembly is blocked by the handle.
The discussion revolves around the challenge of opening a keyed lock on an exterior door that is secured from the inside with a small knob. It is clarified that the key cannot operate the lock due to a separate mechanism and bolt. Suggestions include detaching the slide from the knob and replacing it with a model that allows entry even when someone is inside. If access to the hinges is possible, cutting them off is recommended as a last resort, but in cases where hinges are inaccessible, removing the escutcheon by drilling the fixing screws is advised. However, disassembly is complicated by the handle's design, which may block removal.
