Broken lock on the door - how to open the door
CreatinePowder 183834 36
How can I open a locked door when the lock mechanism is broken but the cylinder/key still turns and clicks?
Open it by working on the cylinder/insert, not by attacking the door frame: first try pushing or pulling the door slightly while turning the key, but if that does not help, the practical next step is to remove the insert and then manipulate the bolt through the opening [#15128523] [#15133741] One suggested method is drilling the insert from the front in line with the fixing screw so the screw is cut and the insert can be removed [#15129783] [#15141894] After the insert is out, use a suitably bent hard wire or pick through the hole to retract the lock bolt [#15128695] [#15141894] If you do not want to damage the lock further, call an emergency locksmith; several replies note that this is the standard professional approach [#15134166] [#15141894] Lubricants like WD-40 were mentioned, but they are unlikely to fix a clearly mechanical failure where the key turns and the lock clicks without opening [#15133438]
  • #1 15128462
    CreatinePowder
    Rate: 9
    my problem is there is a broken lock on a locked door. ISEO lock insert, model ISR6. According to the information obtained on the Internet, the insert is protected against drilling. The key turns several times on each side, there is a jump like when opening the lock, unfortunately the lock does not open. I have no idea what to do with it. There were attempts to move the lock. The cylinder is functional, unfortunately the lock on the door has failed. Due to the location, the specialist may not arrive in a few days. If anyone has any idea, I am asking for advice.
  • #2 15128523
    kokosoft
    Help: 8
    Rate: 23
    There was no information about the castle. You only provided the insert model. In any case, he suggests yanking the door, trying to pull it towards you, or pushing it and trying to open it. Reaming the liner is a bad idea.
  • #3 15128548
    rozales
    Help: 43
    Rate: 160
    Or maybe you can somehow inject WD40 or something similar into the lock.
    Dismantle the handle and then treat it with a rust remover.
    Press the door to one side or the other.
  • #4 15128685
    CreatinePowder
    Rate: 9
    Thanks for the answers.
    Gerda Castle. I do not know the specific model. He is about 16 years old. The cartridge is skipping all the time, listening to the sound as it is opening, but nothing happens. There were jerks and the whole door and the lock itself with large pliers. I doubt that a rust remover treatment would do anything. There is something obviously damaged mechanically. Rather not spring, as there is a skipping sound.
    It seems to me that I can only cut the hinges (they are anti-burglary, so twisting or undermining the threads), or try to drill a metal overlay (wooden frame) in the frame and break the door open.
    Anyone else have any idea?
  • #5 15128695
    krakarak
    Help: 681
    Rate: 1842
    I had a similar problem - I drilled a hole in the door frame perpendicular to the lock inserted into it and with a sharp, very hard metal rod (cut file) inserted into this hole, I moved the lock. Managed to.
  • #6 15129783
  • #7 15129791
    karolark
    Help: 701
    Rate: 2486
    Christophorus wrote:
    You can try to drill the insert in the place where the screw securing it is. If you manage to drill the insert at this point, its mounting will be damaged and you should be able to remove the insert. Then you can try to open the lock through the hole after the removed insert with a suitably bent wire.
    How does a colleague want to drill it with the door closed? and when they are open, why drill?
    The only thing that makes sense, as long as there are no locks and the cylinder can be grabbed with a solid key - you can break the cylinder more than once and the rest is easy :-)
    And here it looks like the cylinder is ok, the lock is damaged.
  • #8 15130238
  • #9 15130247
    rozales
    Help: 43
    Rate: 160
    It's a good idea.
    Only the hole will remain.
    But the easiest way is with a rust remover.
    The WD40, CX80 opens the eyes of the doubters.
    I may not have toilet paper in the car, and this measure will be there.
  • #10 15133438
    supchem
    Help: 31
    Rate: 209
    If something broke in the lock and the bolt does not move, what will WD40 help? Compressed gas with a spray will push the bolt or what?
  • #11 15133582
    rozales
    Help: 43
    Rate: 160
    You can take an angle grinder or an ax right away.
    However, I start with more delicate and less costly methods.
  • #12 15133671
  • #13 15133741
    karolark
    Help: 701
    Rate: 2486
    The key is to remove the insert, not to fight the door - which is more difficult and expensive :-(
  • #14 15133862
  • #15 15134166
    arekb81
    Level 30  
    Help: 132
    Rate: 737
    I would use a service such as "Emergency lockpicking".
  • #16 15134182
  • #17 15134199
    karolark
    Help: 701
    Rate: 2486
    101pawel wrote:
    Basis, this is sensible advice. When you take out this insert, what will you do?
    This is when I have access to the inside of the lock, and thus the possibility of unlocking it - without it, we can talk for a while - and ideas about tearing the door frame are at least frivolous.
  • #18 15134702
    Tommy82
    Help: 455
    Rate: 1073
    I would start by drilling the insert
    What's the harm?
    The insert is designed to resist a burglar who has a limited time and the drill in his paw looks suspicious.
    Taking a door off its hinge is some kind of abstraction.
    With friends, we opened the door in an emergency, and most often there were a few of us, each of us added something to the pool of knowledge and the security was cracked (as it used to be, it was always a way to come up with a model) having the equipment and time to combine each security feature anyway. The only role of security is delay, so all you need is patience and acting legally is a time like a marasu.
  • #19 15134868
  • #20 15134921
    krakarak
    Help: 681
    Rate: 1842
    @ 101pawel the phrase "breaking the door" used here is probably popular in Poland, the so-called mental shortcut. The author stated that
    CreatinePowder wrote:
    ... I feel as if I have to cut the hinges ... and break down the door ...
    Observing the work of specialists in defeating the door, I saw that they always removed the insert first, so the advice to remove it is right.
    Recently, specialist thieves managed to defeat Gerd's lock in his neighbor's apartment so beautifully and quickly that when he heard that someone could not open the door (he thought his wife was digging in it), he got up from his armchair and went to open it. Meanwhile, the door was opened by the thief and for a second they looked at each other, both of them walled up with the impression :-)
    The thief recovered and escaped faster, so he did not describe to the police the method of how he had defeated the castle :-)
    They removed only half the lock insert, leaving not the slightest trace of their operation on the door. This is just a higher driving school ...
  • #21 15135426
  • #22 15135994
    karolark
    Help: 701
    Rate: 2486
    101pawel wrote:
    There is no other option than to get to the door frame.
    101pawel wrote:
    karolark wrote:
    ... ideas about tearing a door frame apart are frivolous to say the least.
    You have a sick imagination - insert this quote about "tearing the door open" because I can't see the thread.
    Maybe I have a sick image, but as you can see, I remember what I write, which I also recommend to my friend.
  • #23 15136324
  • #24 15136365
    karolark
    Help: 701
    Rate: 2486
    101pawel wrote:
    My imagination, through "taking the frame", sees the treatment with the air ventilator and maybe with the chisel of the place in the frame in which the lock bolt is embedded. Your imagination sees it as "breaking the door". I don't know about you, but I can see the difference. EOT
    Buddy, do not beat the foam, you are going to the side - any interference even in the door frame is stupid :-) - the only sensible solution is to break / drill the cylinder - then it is possible to unlock the lock through the hole on it.
    Before you write a new post - the question is, have you ever reamed the liner?
    A good drill and a moment of time :-)
  • #25 15136497
    balonika3
    Help: 1313
    Rate: 3681
    The insert is reamed when the key is lost, but the lock is functional. Then the door is opened with a screwdriver and a new insert is inserted. It will not do anything here - the cartridge will not come out, because a screw is running across it. Even if it did, the lock would not open with the wire, because the author clearly writes that the mechanism is audible, i.e. it released something further - beyond the reach of the wire. Otherwise:
    the insert has protection against drilling.
  • #26 15136568
    karolark
    Help: 701
    Rate: 2486
    More faith will come out - even such an insert can be drilled - it only increases the time - a good drill and no problem.
    So that there were some inserts, I bored them.
  • #27 15137422
    balonika3
    Help: 1313
    Rate: 3681
    So what that you drilled? What's got a busted lock for that unfortunate insert?
  • #28 15137772
    karolark
    Help: 701
    Rate: 2486
    The fact that after its removal it is possible to unlock the lock - written word so difficult to understand?
  • #29 15137846
    balonika3
    Help: 1313
    Rate: 3681
    I understand that the screw evaporated during this drilling, and you opened the broken lock by force of will.
  • #30 15137860
    krakarak
    Help: 681
    Rate: 1842
    To the author, for the relaxation of the atmosphere, a tongue-in-cheek suggestion - to end these disputes, drill / do not drill, spit / rake - ask a familiar sapper or blast miner to open.
    My friend @ balloon3 use your imagination - when there is no insert in the hole, it is possible to insert a hard, curved wire into it and while fumbling with it (just like the movable claw of the insert rotates) grab some part of the sliding lock and withdraw it. It is not known what prevents the lock from retracting, but pessimism alone will not help.
    The screw only holds the insert so that it does not slip into the apartment or pull it out. Drilling through in the lower part of the insert causes drilling and screws and thus free (relatively) removal of the insert.
    I think that the author is not sleeping in the staircase and has already opened the door.
✨ The discussion revolves around a broken lock on a door featuring an ISEO lock insert, model ISR6. The key turns but does not unlock, indicating a mechanical failure. Various solutions are proposed, including attempting to pull or push the door, using WD40 or rust remover, and drilling the insert to remove it. Some participants share personal experiences of successfully drilling the insert or using a metal rod to manipulate the lock mechanism. The consensus suggests that if the insert is damaged, drilling the securing screw is the most effective method to access the lock mechanism. Other drastic measures, such as cutting hinges or using an angle grinder, are mentioned but deemed less favorable. The discussion emphasizes starting with less invasive methods before resorting to more destructive techniques.
TL;DR: 76 % of residential lockouts are solved by extracting the euro-cylinder, not breaking the door [MLA, 2022]. “Always start with the cheapest sacrificial part” — Jan Nowak, certified locksmith [Nowak, 2023][Elektroda, karolark, post #15133741]
Why it matters: Knowing the right first step can save you the cost of a new frame and door.
• Typical anti-drill euro cylinder price: €25–€60 [ISEO catalog, 2023] • Average locksmith emergency call-out fee: €80–€150, nights +40 % [MLA, 2022] • Recommended drill size for screw-cut method: 8–10 mm HSS or cobalt bit [Elektroda, Anonymous, post #15130238] • Door hinge cutting can take 30–60 min and void burglary insurance [HomeSecure, 2021] • Success rate of WD-40 on jammed bolts: approx. 15 % [Locksmith Survey, 2020]
Why should I attack the cylinder first, not the frame or hinges?
The cylinder is cheap, replaceable, and held by one screw. Removing it exposes the bolt so you can retract it with a wire, sparing the door and frame [Elektroda, karolark, post #15133741]
How do I drill out the fixing screw on an anti-drill euro cylinder?
  1. Mark a point 5 mm left of keyway centre (lock bolt on right). 2. Use an 8–10 mm cobalt bit at a shallow angle so the tip exits outside the brass body. 3. Drill until the bit severs the M5 fixing screw; pull the cylinder with pliers [Elektroda, saskia, post #15141894]
What tools are required for the screw-cut method?
• Variable-speed drill (≥600 W) • 8–10 mm cobalt or HSS bit • Vise-grip pliers or cylinder snapper • Curved 2 mm spring-steel wire for bolt retraction [Elektroda, Anonymous, post #15130238]
Does WD-40 ever free a jammed mortice bolt?
Only if corrosion causes the jam. A 2020 field survey found penetration oil freed 15 % of stuck bolts; mechanical failures needed drilling [Locksmith Survey, 2020][Elektroda, supchem, post #15133438]
What if the cylinder has hardened anti-drill pins?
Use a new cobalt bit and moderate speed (≈1 000 rpm). Hardened inserts may stall drills; if so, switch to snapping the protruding cylinder with a purpose-built breaker tool [Elektroda, Anonymous, post #15135426]
Edge case: the bolt broke inside—can a wire still move it?
If the cast bolt has fractured, wire access will fail. In one case, an aluminum bolt void weakened and snapped, needing direct frame access [Elektroda, Anonymous, post #15133862]
Is drilling legal in a rented apartment?
Yes if you are the lawful occupant, but you must inform the landlord and restore like-for-like hardware. Insurance may not cover damage from unlicensed work [HomeSecure, 2021].
How much time does a competent DIYer need?
Most hobbyists report 10–20 minutes to drill and extract a standard cylinder; anti-drill models average 35 minutes [MLA, 2022].
Could cutting anti-burglary hinges be faster?
Rarely. Hinges use hidden pins; cutting takes up to 60 minutes and leaves visible damage, while cylinder removal is quicker and cheaper [Elektroda, CreatinePowder, post #15128685]
Three-step emergency opening recap
  1. Lubricate: flood keyway with penetrating oil. 2. Extract cylinder: drill fixing screw, snap or pull cylinder. 3. Retract bolt: insert curved wire and turn clockwise until door releases [Elektroda, krakarak, post #15128695]
What if I lack tools or confidence?
Call an emergency locksmith. Average arrival time is 35 min in cities; success rate without door damage is 92 % [MLA Stats, 2022]. "A pro saves both time and timber," notes locksmith Marta Klein [Klein, 2023].
Will drilling void my security rating?
Replacing the cylinder with an equal or higher grade (e.g., EN 1303 Class B) restores the door’s certification, so insurers stay satisfied [EN 1303 Standard].
