Unable to Insert Key into Door Lock: Solutions & Advice for Stuck or Misaligned Locks
aerox96 26775 6
  • #1 17704946
    aerox96
    Hello. I have such a problem with the insert in the door, I do not know what company. Normally I locked it all at once, and something touched me and I turned it halfway with the key taken out half more .. I pulled the key further in this position and now I can not do anything because the key does not want to enter the whole .. I am asking for advice whether to force it in or HOW? ?? I can't enter the apartment ..
  • #2 17704953
    DriverMSG
    Help: 3984
    Rate: 4883
    Take a picture of the lock and show it.
  • #3 17704965
    aerox96
    Unfortunately I'm not there anymore .. I had to go to work .. It is such a door that inside it is a door handle on the outside only a ball
  • #4 17704972
    DriverMSG
    Help: 3984
    Rate: 4883
    It won't tell us anything.
    Search the internet for photos with such a lock and show it on the pattern.
    Show the photo of the key.
  • #5 17704983
    akytam
    Help: 14
    Rate: 62
    Absolutely not by force yet. There will always be time for that - (hammer, drill). Try with a SMALL metal object (size, weight of a teaspoon) to knock sideways on the key, try to insert and remove it. Tap on it and LIGHTLY try to insert it, twist it - in a word: it can move something inside. Once, I fixed the padlock into which I pressed the key with a bit too much force. Fact, I was tapping for 20 minutes. and only then did I use isopropanol and olive oil. You have to feel whether the key is dry or "tar".
    Because "as in tar" it may be a solvent at once.
  • #6 17704984
    arturlom
    Help: 48
    Rate: 86
    If it is an ordinary insert, use the tip of the key or a screwdriver to turn it back to its initial position. Then you can insert the key.
  • #7 17705245
    aerox96
    Ok, thank you in advance .. And if, in the end, it did not work, what tools would I need, I would like to know earlier so that I could take it from work .. I would not want to call a specialist because I will add that I am abroad and the costs can be very high
The discussion revolves around a user experiencing difficulty inserting a key into a door lock after it was turned halfway with the key removed. Various solutions are proposed, including taking a picture of the lock for better identification, using a small metal object to gently tap and manipulate the key, and attempting to turn the lock back to its original position with a screwdriver or the key itself. The user expresses concern about potentially needing tools for further attempts and the high costs of hiring a specialist while abroad.
