[Solved] How to Drill Open a Lock: Urgent Help Needed with Techniques & Ideas for Lock Opening
luzik11 13161 8
  • #1 17185537
    luzik11
    Need an idea to help open such a lock any ideas?
    Quite urgent matter
  • #2 17185569
    badyl00
    Level 30  
    Help: 221
    Rate: 300
    Take a picture without the cover on the top.
  • #3 17185584
    luzik11
    Unfortunately, I can not take a picture without the cover, because I have a few kilometers to the house and I will be on picnic and I have to enter without keys somehow :(
  • #4 17185669
    Rezystor240
    Help: 689
    Rate: 1650
    I have a question, the key from this lock is not a 'Christmas tree' with 4 teeth?
  • #5 17185747
    luzik11
    Yes
  • #6 17185757
    Rezystor240
    Help: 689
    Rate: 1650
    This is something like this:
  • #7 17185789
    luzik11
    exactly that
  • #8 17186155
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1006
    Already this topic was changed when the lock was stuck and the key was sitting in the lock but the key was the same as in the photo only the lock housing was convex so with an angle saw I cut the protruding lock housing and turned the bolt latch with a screwdriver. In your case because the lock is simple and does not go above the door, I suggest to drill the lock at the place of insertion of the key with a battery drill and then in place of the fin insert a flat screwdriver and turn the latch that will hide the lock bolt.
  • #9 17211846
    luzik11
    Boring the insert helped open.
    Thanks for the help
✨ The discussion revolves around techniques for opening a lock without keys, prompted by an urgent need. The user initially seeks ideas for lock opening, revealing they cannot access their home due to being away. Responses include inquiries about the lock type, confirming it is a simple lock with a 'Christmas tree' key design. A suggested method involves drilling the lock at the key insertion point using a battery drill, followed by using a flat screwdriver to turn the latch and unlock it. The user later confirms that drilling the insert successfully opened the lock.
