Opel Zafira B 1.9 CDTI 150KM – yellow car with key light, no power?
tomaszwaski1991 97815 14
Why does my Opel Zafira B 1.9 CDTI go into limp mode with the yellow car-with-key light and lose turbo power after a short drive?
The car is most likely going into emergency/limp mode because of a fault in the boost/intake or DPF system, not just the glow-plug code. A first check should be the vacuum lines from the vacuum pump to the turbo control valve, especially the two rubber hoses near the pump under the front right side member, because they often crack [#13867979] The later codes point to this area too: 24520F and 242F75 are DPF-related, and 227956/P2279 indicates a leak in the air intake system [#13870759] Also inspect the intercooler connections, the screwed elbows and rubber gasket under them, and the hoses from the turbo to the manifold for leaks [#17363485] If the fault remains after repairs, the EGR valve should also be checked [#13870759] Simply clearing the errors is not enough; the car needs proper diagnosis with live engine parameters [#13870499]
  • #1 13867419
    tomaszwaski1991
    Rate: 29
    Hello. I have recently Opel Zafire 1.9 CDTI 150KM Diesel. Everything was ok until yesterday when I was driving on the highway and suddenly the CAR WITH A KEY light came on and the car lost power, i.e. it was driving without a turbo. I drove off, turned off the car and turned it on again and the light went out, the car started to drive normally, it was full of power, the turbo was working, but after 2 minutes, the same thing again, i.e. the car lost power. The engine runs smoothly, does not smoke and runs normally. The car accelerates to a maximum of 120 and up to 3 thousand revolutions. And one more important thing that when I go and stop, I turn off the car and turn it on again, the car goes torch better, you can hear the turbo pumping for a while, but after a while it's the same. In general, now the light is on all the time and the car has no power, but as I said, after turning it off for a while, the car drives "relatively" normally, but it's still not what it should be. Can you help something?? :)
  • #2 13867452
    1000godzilla1000
    Help: 10
    Rate: 52
    The engine goes into emergency mode and reduces power, something is out, go to the computer and read the errors, then I will help you.
  • #3 13867464
    tomaszwaski1991
    Rate: 29
    I'm afraid to go myself, but I already have an appointment tomorrow ;) Can I drive normally?
  • #4 13867979
    domex32
    Help: 585
    Rate: 2451
    If you have a DPF, driving like this will kill the filter.
    First, check the vacuum lines from the vacum pump to the turbo control valve under the front right side member.
    There, at the pump, there will be two rubber hoses that often break.
  • #5 13868316
    tomaszwaski1991
    Rate: 29
    I just checked the wires and they are fine. And when the engines are cold now, you can hear that the turbo is pumping, but I would probably drive the car to warm up and lose the night again.
  • #6 13868354
    autoas
    Help: 571
    Rate: 3924
    Cars are not your industry, take them to repair and hello ... no diagnosis, no advice ...
  • #7 13870381
    tomaszwaski1991
    Rate: 29
    I was at the computer today and it showed error P0380, which is Glow plug fault. The error was cleared, the CAR WITH A KEY indicator went out, but the car still did not drive normally. After driving 5 km, the light with the key came on again, but it went out right away, but the yellow engine-shaped light came on. The car began to lose and stopped because it had no strength to go. General now only lights up when I press the gas pedal, it spins only up to 1.5 thousand and has no strength to move at all. I read the errors with the accelerator pedal, brake and ignition switch and I read the following errors 24520F, 227956 and 242F75. Now P0380 no longer appeared. Anyone got an idea? I'm going to take the car to the mechanic, but knowing the mechanics, they will start replacing everything one by one, etc. And I want to direct it myself, more or less, what to do at the beginning.
  • #8 13870499
    domex32
    Help: 585
    Rate: 2451
    It is enough if you find someone who can diagnose the car, just deleting errors is not enough.
    Inform the mechanic that the tester has the function of viewing engine operating parameters, this is enough to focus on the fault.
  • #9 13870759
    leonov
    Help: 1039
    Rate: 2247
    24520F is from the PDF filter, P2279 - Leak detected in the air intake system, 242F75 is also from the DPF, so everything is known, also look at the EGR.
  • #10 13870761
    autoas
    Help: 571
    Rate: 3924
    but knowing the mechanics, they will start to replace everything one by one, etc., and I want to direct him myself, more or less, what to do at the beginning.
    I don't do any diagnostics for such clients, I just do the commissioned work, and when they "soften" then they tell me to find the fault myself...
    Don't write nonsense and don't "drive" any mechanic ... find one at home recommended by drivers ...
  • #11 13883075
    romanpiesc2
    Rate: 13
    I was at the computer today and it showed error P0380, which is Glow plug fault. The error was cleared, the CAR WITH A KEY light went out, but the car still did not drive normally. After driving 5 km, the light with the key came on again, but it went out right away, but the yellow engine-shaped light came on. The car began to lose and stopped because it had no strength to go. General now only lights up when I press the gas pedal, it spins only up to 1.5 thousand and has no strength to move at all. I read the errors with the accelerator pedal, brake and ignition switch and I read the following errors 24520F, 227956 and 242F75. Now P0380 no longer appeared. Anyone got an idea? I'm going to take the car to the mechanic, but knowing the mechanics, they will start replacing everything one by one, etc. And I want to direct it myself, more or less, what to do at the beginning.
    Bring to me, I will exchange everything you want, good for new, old for new, good for broken, whatever you want, our client our lord, you pay and require, 150 zl/h, I cordially invite you.
  • #12 17363485
    marcy80
    Rate: 12
    If anyone has a problem, as in the subject, I already explain: the hoses from the vacuum like to crack, the intercooler has screwed elbows and a rubber gasket under them, it burns out and there is no tightness in the supercharger system, cracking hoses from the turbo to the collector. After fixing the leak, the turbo works, the errors are erased and the Zafira flashes like gold. For deleting, I recommend torqe + adapter for PLN 25 but expensive. Regards
  • #13 17433384
    RAFCIO PSUJ
    Hello. I have the same problem of leaks in the system, the mechanic said that the exhaust manifold and rotating blades are well supposedly broken
  • #14 17433692
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    It is possible that the swirl flaps have large clearances on the pins and there is a leak in the collector - then the collector should be replaced (dentures in welding, plugging do not make sense because after time it will take revenge anyway ...).
  • #15 17433731
    RAFCIO PSUJ
    Thank you, tomorrow I will exchange for a new one, I hope it is because it is a considerable expense
The discussion revolves around an Opel Zafira B 1.9 CDTI experiencing a loss of power and the illumination of the "CAR WITH A KEY" warning light. The user reports that the vehicle operates normally after being turned off and restarted, but the issue recurs after a short period. Responses suggest that the engine may be entering emergency mode due to faults, and recommend checking for vacuum line issues, particularly those connected to the turbo control valve. Error codes P0380 (Glow plug fault), P2279 (Leak detected in the air intake system), and DPF-related codes are mentioned, indicating potential problems with the diesel particulate filter and air intake system. Users emphasize the importance of proper diagnostics rather than merely clearing error codes, and suggest inspecting hoses and the EGR system for leaks.
