Opel Zafira 2.0dt 2000 Model: Car Light On, Loss of Power During Overtaking, Non-Working Reverse
daria603 90567 9
Why does my 2000 Opel Zafira 2.0 DT lose power and show the car-with-key warning under acceleration, and why do the reverse lights not work?
The car-with-key warning means an engine-management fault, so the first step is computer diagnostics; on this Zafira with a VP44 pump, check the key battery and the fuel system because the power loss is likely fuel-related [#15605600][#15605787] For the reverse-light/reverse-gear problem, check the reverse switch on the gearbox and the wiring/socket after the bulbs and fuses; if diagnostics shows a stop-sensor fault, that switch is at the pedal [#15599918][#15605600][#15600717]
  • Power loss triggers warning light; reverse gear inoperative
    #1 15599864
    daria603
    Rate: 17
    Hello, I bought an Opel Zafira 2.0dt from 2000, the car fires beautifully, the temperature holds, only a problem because when I overtake, the car light comes on with the key and then it dies, I had a disela before, but I can't judge if the light comes on, it loses power more than once you have to wait for a while until the turbine turns on. I also have a problem, the reverse is not working, and the backlight of the bulb and fuses are replaced, what could be the cause?
  • #2 15599918
    nici
    Help: 266
    Rate: 979
    Without a computer diagnosis, you won't do much with this key.
    If something is not lit, the fuses are ok and the bulbs may be a beam, and in the case of reverse, the sensor in the gearbox.
    daria603 wrote:
    I am returning the car to the previous owner.
    Good luck.
  • #3 15600709
    daria603
    Rate: 17
    I was at the diagnostician in the morning, fortunately, nothing serious, it can be a beam or a sensor and an error from the stop sensor pops up, the question is where is it so that I can replace it myself? Will someone help me? :)
  • #4 15600717
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    daria603 wrote:
    where is it located so that i can replace it myself?
    At the pedal.
  • #5 15600739
    daria603
    Rate: 17
    Thank you very much for your help :) and do you know how much this sensor costs from the reverse which is mounted on the box?
  • #6 15605600
    Doradca ProfiAuto.pl
    Rate: 12
    The car's lamp with the key indicates an error in the immobilizer system. You have to verify the battery condition in the key and perform diagnostics of the fuel supply system, because the VP 44 pump, which is in this car, has a built-in immobilizer. The lack of power is likely due to a problem in the fuel system.
    First of all, computer diagnostics is the basis. After diagnosis, the answer will be more precise. When it comes to lighting, a visit to an electrician is necessary, the problem is probably in the installation. Check the reverse gear switch next to the gearbox.
    I believe that the lack of power is a serious matter and comes at a greater expense.
    Regards,
    Łukasz - Advisor to ProfiAuto.pl
  • #7 15605787
    tzok
    Help: 3175
    Rate: 6546
    In Astra 2 / Zafira there is no "key" light, there is (as described in the topic) a car with a key. This is an engine management system fault indicator not related to emissions control (also includes, but is not limited to, the immobilizer fault).
    I propose to google "zafira reverse gear sensor price" and it will be explained ...
  • #8 18109590
    Boogy25
    Rate: 27
    Hello, I was shocked, today I was shocked right away, I say the car was going well all the time until this morning it fired normally, I drove 3km and suddenly the shock of the car went out and I do not want to start the car light with the keys and it is like a radiator with a fan. Now, the question, maybe someone will be able to advise what to do with it because once I read that it may be a fan module, a fuse, and not enough fluid. Anyone had such a case? These 2 lights are on all the time, the car is spinning but does not want to start
  • #9 18109692
    Help: 1405
    Rate: 6430
    Read errors.
  • #10 21615076
    tajpantajpan65
    With regard to the lights on the baseboard, when you remove the bulb socket, you can see the metal plates on both sides of the bulb socket, first check with a test tube that there is current, if there is, then bend the metal plates in the bulb socket, they are visible on both sides of the socket, which should solve the problem.
The discussion concerns an Opel Zafira 2.0 DT from 2000 with intermittent loss of power during overtaking, the car-with-key warning lamp, and a non-working reverse light. Suggested causes include immobilizer or engine management faults, fuel system issues related to the VP44 injection pump, a weak key battery, and the need for computer diagnostics to read error codes. For the reverse light, advice points to checking the reverse gear switch on the gearbox, the stop-light pedal sensor, wiring, bulb sockets, and contacts rather than only fuses and bulbs.
