STIHL 23-jka Chainsaw: Optimal Octane Level for Fuel - 95, 98 or 100?
66060 5
  • #1 13939247
  • #2 13939561
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    I normally put 95 and as the instruction says a mixture with red oil stihl 1:50. If I can't buy stihl oil, the mixture says 1:25.
  • #3 13939574
  • #4 13939604
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    gibons1992 wrote:
    the logging guys told me that they were pouring 100 octane from Shell and that she was going like crazy :wink:
    Yeeeeeeeeeeeeeeee! Two and a half horses make four. Seriously, there is a difference there, but is it worth buying a miracle saw fuel .....
  • #5 13939685
  • Octane rating affects detonation, not engine lubrication
    #6 13939734
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    Where does this conversion come from? Who's pushing you ... nonsense about the dryness of high-octane fuel? Gasoline is all dry and has no use for lubricating the engine - the engine lubricates itself with oil and its quality is important. Octane is a fuel parameter that describes the resistance of the fuel to detonation combustion, not its lubricating properties.
    Most Stihl's manual says 1:50 stihl oil, 1:25 other oil, and that's it.
    As a curiosity, I will say that the stihla saw fed with orlen 1:50 oil gave up the ghost after 3 months of work in the forest. But there is something about their oil.
