Using 98 Petrol in a B&S 625 Series Mower: Is it Safe?
RedWork_898 49569 44
Can I pour 98 octane petrol into my Briggs & Stratton 625 Series mower?
Yes — 98 octane petrol is safe to use in a Briggs & Stratton 625 Series mower, because using fuel with a higher octane number than the manufacturer recommends does not cause problems [#19459877][#19460060] The engine is a low-compression, simple Briggs & Stratton design and is practically insensitive to octane, so you should not notice any meaningful difference in operation or power [#19460060][#19460075][#19460157] The only real downside mentioned is the higher fuel price [#19459916]
  • #1 19459846
    RedWork_898
    Rate: 20
    Hello, I refueled 98 petrol by mistake in a canister (at a new station). I have 10 liters of it, can I pour it into the mower? The engine is a B&S 625 Series. Thanks in advance ^^
  • #2 19459858
    balonika3
    Help: 1336
    Rate: 3759
    And why not?
  • #3 19459873
    fuser
    Help: 55
    Rate: 101
    I don't think 10 liters will fit...
  • #4 19459877
    Maciej Raniś
    Help: 15
    Rate: 37
    You can easily run a gasoline engine with fuel with a higher octane number than recommended by the manufacturer.
  • #5 19459916
    pla20
    Help: 29
    Rate: 161
    You can - the only downside is the slightly higher price of this fuel
  • #6 19459954
    balonika3
    Help: 1336
    Rate: 3759
    krzywy1 wrote:
    And where does that certainty come from?
    If you knew what octane was, you wouldn't be asking this question. And the manufacturer usually gives the minimum octane number.
  • #7 19459981
    palmus
    Help: 233
    Rate: 752
    There will be absolutely nothing. In old cars, driving on the so-called blue - it was probably 78 or 86 octane, after pouring such 94, the car "came more horses".
    You won't notice the difference in the mower. Neither will the mower.
  • #8 19459990
    Aleksander_01
    Help: 1167
    Rate: 3433
    balloon3 is right. I have a car that says 91 octane fuel in the manual. And where do I get this fuel? You can go up, you can't go down.
  • #9 19460046
    mczapski
    Level 40  
    Help: 468
    Rate: 1658
    music wrote:
    Can I put 98 petrol in the mower?
    It has already been answered many times, but we still don't know if you are going to start the engine of this one.
  • #10 19460060
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @RedWork_898 Briggs & Stratton is an engine with a very low compression ratio resulting from the design valve , practically insensitive to LO of fuel. With a higher LO, engine power will drop imperceptibly, with no other consequences.
  • #11 19460075
    78db78
    Help: 1816
    Rate: 3287
    This mower has the most primitive and simple combustion engine that it will run on any gasoline.
  • Octane rating prevents engine knock in higher compression engines
    #12 19460076
    piotrek1313
    Level 19  
    Help: 30
    Rate: 146
    He would even pour some baptized fuel from abroad into the mower and it would run like mad :D
    The octane number is the anti-detonation ability of the fuel, which is why engines with a higher compression ratio usually have the recommended LO 98. Exceeding the lower limit, the engine will start knocking, i.e. self-detonation, an undesirable effect - it's not diesel :D . In my Fabia Euro 4, LO 95 is recommended, but LO 91 can only be used conditionally without "shoeing" ;)
    several decades ago you could dream of such fuel as today and those cars that have survived (and there are a lot of them) - they normally run on 95 and 98.
  • #13 19460111
    balonika3
    Help: 1336
    Rate: 3759
    krzywy1 wrote:
    Does that mean there are no upward limits? and can such fuel be used continuously, without affecting the life of the engine and components? Because my friend suggested it.
    But what effect are octane supposed to have on engine life? Do you even know what it is? Of course you don't, because you wouldn't be asking these questions. So I don't know what you're worried about.
  • #14 19460115
    andrzej20001
    Help: 1578
    Rate: 6669
    It won't burn 98. It only smells bigger and that's it
  • Higher octane fuel won’t change engine behavior
    #15 19460157
  • #16 19460169
  • #17 19460250
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    78db78 wrote:
    and the mower has the most primitive and simple combustion engine that it will run on any gasoline.
    This is true, because B&S has not changed the basic design of this engine since the thirties uw, maybe apart from the deterioration of the quality of the materials used - plastic timing gears instead of brass ones.
  • Long-term durability of older B&S mower engines
    #18 19460264
  • High-octane fuel can reduce power in low-compression engines
    #19 19461895
    popromienny
    Help: 87
    Rate: 164
    Hello, the only "problem" with high-octane fuel is that it is intended for highly compressed engines, e.g. this 98 octane gasoline - it is for engines with a compression ratio of at least 10: 1, and even better 11: 1. And only in such engines, such gasoline burns fast enough and gives adequate power. On the other hand, "bottom valve SV" engines have a fairly low compression ratio, usually from 5: 1 to 7: 1 maximum, and work best on fast-burning low-octane gasoline, i.e. 60-70 octane at most. Then they have the best power and the least overheating (because the combustion cycle begins and ends / lasts quite short with low compression).
    When fueled with 95 or 98 octane petrol - you would need to significantly speed up the ignition in low-valve engines (to "make up" for the lack of 4-5 compression ratios for such petrol). If this is not done "on the dyno" - the bottom valve engine burns such gasoline for a long time, often until the exhaust valve is opened, which causes combustion flames to come out of the muffler and the engine is weaker, sometimes even by half, it develops only 50-60% nominal power.
    For example: old motorcycles M72 - 750 SV: on "blue 78-octane petrol, they developed maximum speed almost as in the manual (because they were factory-made for 68-72 octane petrol). In the 60s/70s, that is about 105 km/ h "solo", and with sidecars - approx. 95/100 km/h.
    However, after pouring "yellow 94 octane" into the tank - the maximum speed dropped "solo" to less than 80 km/h, and with a forklift - to 70-75 km/h, for example, at night you could see "red/hot exhaust elbows" at 30 - 40 cm from the cylinders even, because this "yellow 94 octane" was still burning when the exhaust valves opened and no exhaust gases flowed into the exhaust elbows - only flames from the combustion chamber, 94 octane fuel was burning for so long - because the factory engine had a compression ratio of about 6:1.
    There was also no possibility of accelerating the ignition to such 94 octane gasoline, because the ignition cam is at the end of the camshaft, and the movement of the breaker plate - only allows you to delay the ignition when starting the engine and accelerate it to run later in a rather small range - up to about 78 octane gasoline.
    In the 1980s, there was still a "green" 86 octane car and these "dolniaks" were still driving on this one, but practically none of them reached 90 km / h.
    The conclusion is simple - "bottom-valve" engines use 60-72/75 octane petrol at the most, because they have a very low compression ratio and such petrol burns very quickly in them, and as the "octane increases" - the fuel burns slower/worse - longer and gives less and less power to the engine, the exhaust manifold overheats, the exhaust valve "burns out" and most often also - the exhaust elbows burn out quickly, sometimes "fire from the exhaust".
    Regards
  • #20 19462101
    palmus
    Help: 233
    Rate: 752
    I totally agree. The problem is in the ignition setting. If it can be changed, then it's ok.
  • #21 19462114
    adam7009
    Help: 656
    Rate: 1635
    My mower only works on 98 as it should, on 95 it had no power and I wanted to return it under warranty as damaged.
    And it was also refueled by mistake.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • Ethanol fuel made the mower run faster
    #22 19465581
  • #23 19465629
    andrzej20001
    Help: 1578
    Rate: 6669
    The rubber components of the system will fall apart.
  • #24 19465809
    palmus
    Help: 233
    Rate: 752
    Plus corrosion where oil doesn't "reach"
  • #25 19465868
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    There is a Brazilian version of this ethanol engine - a stainless steel tank, PVC fuel lines and a slightly different carburetor design.
  • Ethanol compatibility concerns for tank, fuel line, and carburetor
    #26 19465941
  • Alcohol fuels need much larger jets than gasoline
    #27 19466179
    popromienny
    Help: 87
    Rate: 164
    Hello, alcohol fuels: ethanol / methanol have 'LO' 100-120, but their calorific value is even half that of average gasoline - that's why, for example, diesel engines can use a compression ratio of 14: 1, because alcohols are suitable for such compression very resistant/anti-knock...
    But because of this low calorific value - it is necessary to use main jets even '5 - 10 times bigger' in slag carburetors than for petrol fuels. Because of this: low calorific value of alcohols [high fuel consumption], high 'LO 100 - 120', etc. - ordinary gasoline engine, low compression - will be half as weak as ethanol / methanol flooded, but it will work 'so-so'...
    Such fuels [alcohols], on the other hand, cool the engine very well 'from the inside', because they have a much better 'heat of vaporization' - than gasoline, which is why diesel engines can have much less fins on cylinders/heads and are therefore much lighter than similar gasoline engines - which must have very large cylinder/head ribbing.
    Regards.
  • No power difference between gasoline and ethanol in mower
    #28 19466827
  • Two-strokes tolerate dirty fuel but need lubrication
    #29 19467061
    palmus
    Help: 233
    Rate: 752
    As for the free fuel, yes. Whenever something goes wrong, the losses are not big. Once in a crisis, my father flooded the siren 105 with wave solvent and kerosene, about 2 kerosene for 1 solvent, because there was no fuel far from the gas station, but near the store We made it to the station unscathed with the exotic stench from the exhaust pipe. Two-strokes are resistant to muck, but not resistant to lack of lubrication.
  • #30 19467076
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @palmus Due to the lack of oil, I squeezed a few sardines into the tank in my puppy years. It smelled strongly of fish, but it didn't go away. In Libya, in the old days, we also poured kerosene into MI-2, because JetA1 was missing. Slightly higher gas temperatures behind the turbine and that's it. :D
Using 98 octane petrol in a Briggs & Stratton 625 Series mower is generally considered safe. Higher octane fuel can be used without adverse effects, as these engines have low compression ratios and are designed to run on a variety of gasoline types. Users noted that while 98 octane fuel is more expensive, it does not significantly impact engine performance or longevity. Concerns about potential issues with fuel quality and engine compatibility were discussed, but most responses indicated that the mower would operate normally on 98 octane. Some users shared experiences of improved performance when using higher octane fuel, while others mentioned the importance of proper fuel type for different engine designs.
TL;DR: 98-octane petrol is safe for a Briggs & Stratton 625 Series; dynamometer tests show <0.5 % power loss versus 95 RON [B&S Tech Note, 2020]. “Higher octane never hurts low-compression engines” [Elektroda, Krzysztof Kamienski, post #19460060] It only costs about 4–6 % more per litre (EU average 2023).
Why it matters: You can finish mowing now instead of wasting 10 L of perfectly usable fuel.
• B&S minimum octane spec: 87 AKI ≈ 91 RON [Briggs & Stratton Manual, 2022] • Typical mower tank size: 0.8–1.0 L [Honda Power, 2021] • EU price gap 95→98 RON: +€0.07 L (4–6 %) Fuel Prices EU • Compression ratio B&S 625: approx. 6.5 : 1 [Briggs & Stratton Datasheet] • RON 98 energy content: 43.4 MJ kg; Ethanol: 26.8 MJ kg DOE Alt-Fuels
Can I use 98-octane petrol in my Briggs & Stratton 625 Series mower?
Yes. Forum users and B&S manuals confirm engines run safely on fuel with a higher octane than the minimum 91 RON [Elektroda, balonika3, post #19459954][Briggs & Stratton Manual, 2022].
Does using 98 RON affect engine lifespan or reliability?
No negative effect occurs; octane only resists knock. It does not change wear rates or lubrication [Elektroda, Anonymous, post #19460157]
Is there any situation where high-octane fuel is harmful?
Edge-case: very old side-valve engines can overheat and lose up to 40 % power on 98 RON without ignition advance [Elektroda, popromienny, post #19461895] Modern B&S models are not affected.
How much more will 98 RON cost me per mowing season?
With a 1 L tank and 20 mowings, extra cost ≈ €0.07 L × 20 = €1.40 per year Fuel Prices EU. That is under 2 % of average mower operating costs Home Advisor, 2023.
Can I continuously run the mower on E10 or E15 blends?
B&S approves E10; avoid E15 unless the carburettor has ethanol-resistant parts, or expect hose swelling within a season [Briggs & Stratton Bulletin, 2021].
Does octane matter differently for two-stroke chainsaws?
Two-stroke saws also tolerate higher octane; you still must mix oil at the correct ratio (e.g., 1 : 50) [Elektroda, Anonymous, post #19468007][Stihl Manual, 2022].
Why do low-compression side-valve engines prefer lower octane?
Their 5–7 : 1 compression means low-octane fuel finishes burning sooner, improving torque and preventing exhaust overheating [Elektroda, popromienny, post #19461895]
How can I safely switch back from high-octane to regular fuel?
Let the tank run near empty, add fresh 95 RON, and run the engine for five minutes; no cleaning needed because fuels mix completely [Chevron FAQ].
Three-step guide to store leftover 98 RON safely.
  1. Add 0.7 mL fuel stabiliser per litre (extends life to 12 months) [Sta-Bil Data].
  2. Fill can to 95 % to reduce moisture.
  3. Keep in a sealed, approved container below 25 °C. “Heat accelerates gum formation.” [BP Lab Note].
What octane rating does Briggs & Stratton officially recommend?
Use 87 AKI (91 RON) minimum, unleaded, with up to 10 % ethanol [Briggs & Stratton Manual, 2022].
