Is a 1:50 Fuel Mix Suitable for the Demon RQ580 Brushcutter?
pawel2212 54192 11
Can I use a 1:50 fuel-oil mix in a Demon RQ580 brushcutter?
Yes, 1:50 can be suitable, but only if the manufacturer’s manual specifies that ratio and you use a proper 2-stroke oil; otherwise follow the recommended mixture to avoid engine damage [#16610856] Good oils such as Stihl, Husqvarna, or similar are reported to work at 1:50, while cheaper oils were suggested at 1:25 [#17363620] One user also recommended Husqvarna blue oil at 100 ml per 3 L of gasoline and said the instructions already state the correct mix [#17364248] Poor oil or the wrong ratio can cause carbon buildup and running problems, so the key is to use quality oil and stick to the manual [#17363605][#17363620]
  • #1 16608263
    pawel2212
    Hello, I would like to ask if if it pours such a mixture is it good or not?
    Please reply.
  • #2 16610843
    szymon122
    Help: 302
    Rate: 762
    The manufacturer will answer all your questions in its manual ;)
  • #3 16610856
    SKM 1964
    Help: 150
    Rate: 660
    Stick to the manufacturer's recommendations. In the instructions, you have written what oil to use, what mixture composition and what gasoline to use. You can't do it because you will damage your engine. One requires 1:30 second 1:40 third producer 1:50. :|
  • #5 16620633
    pawel2212
    Oh, I have to change
  • #6 16644183
    Socha1997
    As for the mixture, everything also depends on oil but also on fuel.
    It is known that this is not a racing engine :P
    It is recommended to use such proportions as recommended by the manufacturer.
  • #7 17363605
    stalker1995
    Help: 54
    Rate: 104
    And here you will be surprised.
    I have such a scythe 1:25 and the mower after 3 months of use has such carbon deposits on the Candle that the engine stopped screwing at full speed, after cleaning the carbon it returned to normal.
    The neighbor also has two no name items, and each one goes on 1:50 carbon zero, the engines are still running today, I think lac 1:25 (for one two mowing) when new and then 1:50 good stihl oil e.g.
    pour only one oil and it will be ok
    Unless you want to remove the cylinder 2 times a year to clean the carbon deposit. Regards.
  • #8 17363620
    mod22
    Help: 130
    Rate: 312
    Stihl oil, husqvarna and similar half 1:50. Other rubbish 1:25. From experience. In addition, the basic property of this oil is not the formation of carbon deposits.
  • #9 17363685
    Socha1997
    The amount of carbon deposits depends on the quality of the oil. Stihla oil is not so good (the cheapest red is mentioned).
    The 1:25 mix is terribly rich for 95/98 octane gasoline.
    His scythe (fs350) has been using the motul 710 for several seasons. The scythe works as it should, zero carbon and the oil price is lower than Stihl oil.
    In general, if oil is taken care of, candle filters and service, then even Chinese people will work for a long time. The most important thing is not to pour the cheapest oil and change even the candles every season, and clean the filter from time to time
    best regards
    Maciej
  • #10 17364054
    SKM 1964
    Help: 150
    Rate: 660
    Candles change every season is a slight exaggeration, unless it is Chinese crap. I have been able to stand for 15 years in Stihlu and I have been working on Stiga since 2002. I have an older mower, a smaller one, and the candle was not replaced. But they are all corporate. Briggs engines.
    Added after 4 [minutes]:
    A 1:25 mix was used for WSKi lux oil with gasoline. After him it was nagaru everywhere even the muffler was clogged. Then they invented the mixol. 1:30. It was a bit better. :D
  • #11 17364106
    Socha1997
    I am talking about regular candle changes, because you never know when they will fall apart, and the cost of PLN 10 with annual use is not a property: p
    As a matter of fact, good oil is the basis. Currently, there are even oils that can be mixed in a ratio of 1: 100.
    Mixture 1:25 I was only doing it to a super card but there was 130 octane fuel.
    Often also in cheap scythes / pilas you can find a strainer that causes a lot of problems. Then it is worth lubricating the filter with oil so that it does not run.
    The above recommendations apply to all saws / scythes that we service together with a colleague for forest use.
    An interesting fact is that one of the stihla blackbirds has never undergone renovation despite being 25 years old, and the only thing that has been done in it is regular services.
  • #12 17364248
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    pawel2212 wrote:
    Hello, I would like to ask if if it pours such a mixture is it good or not? Please answer.
    It's a simple path to replace with a new scythe.
    From many years of experience with these scythes, you can pour Husqvarna blue oil 100ml / 3l of gasoline.
    I don't know why you are assuming a topic, you have everything described in the instructions.
    Husqvarna blue oil is the only one that does not make carbon deposits and does not soak, and is relatively cheap for a professional 2 stroke about PLN 40 / 1l.
The discussion centers around the suitability of a 1:50 fuel mix for the Demon RQ580 brushcutter. Participants emphasize the importance of adhering to the manufacturer's recommendations regarding fuel mixture ratios to avoid engine damage. While some users suggest a 1:25 mix based on personal experiences, others advocate for a 1:50 mix, particularly when using high-quality oils like Stihl or Husqvarna, which reportedly reduce carbon deposits. The quality of oil and fuel is highlighted as critical factors influencing engine performance and maintenance needs. Users share experiences with different oil brands and mixtures, noting that proper maintenance can lead to prolonged engine life without excessive carbon buildup.
