What is progISP? Comprehensive Guide: Features, AVR Chips, USBASP, High-Voltage Programming
vermes 15267 0
  • #1 14024186
    vermes
    Rate: 8
    If you need to install progISP software (ISP programmer), you can easily download it as well as the driver you need, from the Internet. Then you may be sure you will find the latest version. Some of its features are listed below:
    - Can be used for programming all AVR chips
    - Provides support for custom parallel download programming
    - Suitable for USBASP programmer
    - Custom programming chip, programming fuse information message
    - For high-voltage programming
    - Possible offline download
    During configuration, you can manage and adjust the size of the progISP window by dragging its borders to the desired size. The main interface was designed to save automatically changes you made, so after closing and restarting the programmer, the last changes will be visible.
    As it was mentioned before, progISP can be used for programming AVR chips. Due to the fact that all the configuration and programming data can be put in a package of a single file, the software can be used for managing a project. progISP operation is rather intuitive and there should be no difficulties while using it. Remember to select the type of chip you want to program before starting the process (list of the chips is in a drop-down box).
