Alternatives for Replacing Damaged MINI ONE 2006 Key - Options and DIY Programming
cenzo 31026 16
How can I replace a damaged 2006 MINI ONE key more cheaply, and can I program a used key myself?
You generally cannot recode a used MINI/BMW key yourself, and the thread suggests that the cheapest practical option is usually an independent service or a replacement key from classifieds rather than the dealer price plus coding fee [#14027986] In this model the key uses a rechargeable battery charged in the ignition, so if the remote stopped working after opening the key, first check the solder joints and the connection between the battery and the PCB [#14028002][#14029050] To verify and re-sync the remote, sit in the car, turn the ignition on and off, hold the unlock button, then press the lock button three times within 10 seconds; if the key is OK, the central locking should lock and unlock automatically [#14028002] The battery identified in the thread is Panasonic VL2020 / VL2020-1VCE, and some versions need careful bending of the tabs to fit [#14029650][#14030035][#14030040]
  • #1 14027894
    cenzo
    The key for MINI ONE 2006 does not work. No. key according to BMW: 66126931748. I probably damaged the board when trying to open it to replace the battery. Price in BMW PLN 650 + mandatory coding PLN 350.
    Question:
    1) where can you buy such a key cheaper?
    2) If I buy a used key and replace the plate, will I be able to program it myself?
    Alternatives for Replacing Damaged MINI ONE 2006 Key - Options and DIY Programming Alternatives for Replacing Damaged MINI ONE 2006 Key - Options and DIY Programming Alternatives for Replacing Damaged MINI ONE 2006 Key - Options and DIY Programming Alternatives for Replacing Damaged MINI ONE 2006 Key - Options and DIY Programming Alternatives for Replacing Damaged MINI ONE 2006 Key - Options and DIY Programming
  • #2 14027977
    pietia86
    Help: 69
    Rate: 91
    cenzo wrote:
    [...] I probably damaged the board when trying to open it to replace the battery.[...]
    What makes you think you damaged it? After replacing the battery, it still doesn`t work?
  • #3 14027986
    Futuree
    Rate: 41
    Ad2 It is not possible to recode a used key
    Ad1 Unfortunately, you won`t save much. I think that the complete service outside the dealership will cost about PLN 700. Look for advertisements on well-known portals.
    Btw. Describe what is wrong with the central locking or lack of response when trying to start the car
    Regards
  • #4 14027987
    cenzo
    I opened the key just to check what battery model it was, then closed it and since then the central locking has not worked.
    1) How to check if the key is sending a signal?
    2) Recommended specialists from the Wrocław area?
  • #5 14028002
    Futuree
    Rate: 41
    In this model, you do not have a regular battery, but a rechargeable battery that charges when you insert the key into the ignition. If it stopped working earlier, it means it`s already dead. After replacement, you need to code the central remote control. If the remote control does not work after your intervention, check whether you have accidentally interrupted the connections between the battery and the board.
    As for checking, try to synchronize the central locking remote control
    Get in the car, close the door
    Turn the ignition on and off
    Press and hold the car unlock button
    While holding the unlock button, press the door lock button three times within 10 seconds (on the remote control, of course)
    After this, the car should lock and unlock automatically.
    If everything is OK with the remote control, you should go through this procedure without any problems
    Regards
  • #6 14028833
    cenzo
    I located the cold solder joint after the last battery replacement. I hope this is the main cause of the remote not working. I`ll let you know next week. best regards and thanks for your support Alternatives for Replacing Damaged MINI ONE 2006 Key - Options and DIY Programming
  • #7 14029050
    tzok
    Help: 3175
    Rate: 6533
    It`s not only cold solder but also thermally damaged insulation... the battery probably has a short circuit. This is a THT assembly, soldering should be done on the opposite side of the board. These plates are bent so as not to overheat the battery during soldering, but it can be seen that the person who soldered it is not skilled in using a soldering iron and/or did not have a good soldering iron.
  • #8 14029460
    Futuree
    Rate: 41
    I`m just curious why someone would push the soldering iron in this place when the battery has plates prepared for assembly and soldering from the other side.
  • #9 14029650
    cenzo
    Does anyone of you know where I can buy? exactly the same new battery?
    Panasonic VL2020
  • #10 14029927
    Pawel wawa
    Help: 1262
    Rate: 4430
    The height of laziness, there is plenty of it on a well-known auction website. Is it difficult to enter the name in the search engine?
  • #11 14029963
    cenzo
    can you read? I asked about exactly the same battery as in the photo. All the VL2020s I find have the boards in different places.
  • #12 14029984
    Pawel wawa
    Help: 1262
    Rate: 4430
    Master, do you even know what you`re writing? I promise you they will be good. I use these. So I guess I know better.
  • #13 14029992
    cenzo
    They will be good after adding more wire. and I would prefer to exclude reproduction and buy the original one.
  • #14 14030010
    Pawel wawa
    Help: 1262
    Rate: 4430
    No pieces, just look carefully, you have two types of plates. Some fit without any wire.
  • #15 14030035
    cenzo
    Do you mean Panasonic VL2020-1VCE?
  • #16 14030040
    Pawel wawa
    Help: 1262
    Rate: 4430
    :) Yes, after bending it will fit. I use a slightly different version of these batteries, but they fit. Just bend carefully, these plates can only be bent once.
  • #17 14030057
    cenzo
    Thanks for the tip!
    Added after 27 [minutes]:
    I measured the voltage and it shows 3.137 V. What values are optimal?
✨ The discussion revolves around the issues faced with a damaged key for a MINI ONE 2006 model, specifically the BMW part number 66126931748. The user inquired about affordable alternatives for purchasing a replacement key and the feasibility of programming a used key after replacing its internal components. Responses highlighted that the key uses a rechargeable battery, which may have been damaged during a battery replacement attempt. Suggestions included checking for signal transmission from the key and potential DIY fixes for cold solder joints on the circuit board. Users also discussed sourcing the specific Panasonic VL2020 battery and the challenges of finding an exact match. The conversation emphasized the importance of proper soldering techniques and the potential costs involved in professional repairs.
