VW Passat B7 2012: Can I Program a New Keyless Key using ADAKO's Original VCDS?
woycik 22224 6
  • Can VCDS program replacement keyless keys?
    #1 16372687
    woycik
    Recently, my wife made a surprise and she lost my car key. The problem is that it is a keyless key. There are two options - VW service - the cost is about 820 PLN, or try to deal with the topic yourself. If I have an original VCDS from ADAKO, can I program the key so that all functions (immobilizer, central locking, Keyless entry) work? For sure I would first have to organize a clean key - if I could not get a keyless just plain - can I add it instead of that lost one (one original with keyless and an additional one would remain without KL).
    And by the way - on the Allegro is full of keys from used cars - you can do something about them, are they only suitable for parts (housing etc ...)?
  • #2 16376177
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    woycik wrote:
    If I have an original VCDS from ADAKO, I can program the key
    No
    No
    Yes
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 16376248
    yogi009
    Help: 848
    Rate: 2655
    In summary, you have trouble and expense. The key in VW has always been expensive.
  • #4 16381783
    woycik
    Thanks for the help, it's hard - let a man in life have only such problems :) I did not want to push myself into unnecessary costs when buying and attempting to program keys from one source or another - if this is not possible, the topic is settled.
    And what are the programming options for Vcds in the "immobilizer" group?
  • #5 16384264
    miler80
    Help: 272
    Rate: 1395
    If you had this key properly prepared for vin cars and for this access code then VCDSem will be added.
  • #6 16384403
    yogi009
    Help: 848
    Rate: 2655
    I have to ... Who will add? Minimum care for language.
  • #7 16565838
    woycik
    Ok thanks for the hints,
    Finally, a visit to the site ended - cost: key + insert + programming: about PLN 1250.00
The discussion revolves around programming a new keyless key for a 2012 VW Passat B7 using ADAKO's original VCDS after the original key was lost. The user considers two options: going to VW service, which costs approximately 820 PLN, or attempting to program the key themselves. Responses indicate that while programming is possible with a properly prepared key, it may involve additional costs and complexities. The user also inquires about the feasibility of using keys from used cars available online, which are generally deemed suitable only for parts. Ultimately, the user estimates the total cost for a new key, insert, and programming to be around 1250 PLN.
