MSI Radeon HD7970OC TwinFrozr Overheating Issue at 80 Degrees: Core Clock & Memory Clock Settings
ThePatrolPL 39513 10
Why does my MSI Radeon HD7970 Twin Frozr reach about 80°C in games, and how do I interpret the 1050 MHz core clock and 1375/5500 MHz memory clock shown in Afterburner?
Your card is not overheating because of the 1375/5500 MHz memory reading: 1375 MHz is the reference clock and 5500 MHz is the effective clock, so 1375×4 = 5500 [#14032857] 80°C is considered normal for this class of GPU, and one reply notes that graphics chips usually only start throttling around 95°C [#14032857] [#14035501] If you want lower temperatures, raise the GPU fan speed; one suggestion was to set Power Target to maximum and manually set the fan to at least 45% [#14033563] Another suggestion was to replace the thermal paste and increase fan speed by 10–15% [#14130366]
  • #1 14032834
    ThePatrolPL
    Hello. I have this graphic card: http://www.morele.net/karta-graficzna-msi-rad...-pci-e-384bit-dvi-hdmi-2mdp-box-r7970-tf-3gd5 -oc-be-573495 / and I have a problem. The graphics card overheats quickly around 80 degrees. (during e.g. bf4 after 20 minutes of playing) I have an additional housing fan for extracting warm air. But it overheats anyway. I think it's the fault of the wrong configuration. In MSI, afterburner writes that I have a core clock at 1050 MHZ and in the description of my graph cards I write that I have 1000 Mhz, and in the program I also write a memorial clock that I have a mouth at 1375 Mhz and in the description I have 5500. And it could be this fault? the card is just full but it is limited and cannot use its full power and is overheating? How so how to set these 5500 MHz? in Msi I can only go to 2000 but I'm afraid ... I'm green in these matters.
    pawelr98
    Help: 413
    Rate: 1155
    80 ° C is the normal temperature for graphics chips.
    These 5500mhz is the effective clock, 1375mhz is the reference clock.
    1375x4 = 5500
    There's nothing to worry about.
    If you want to have a bit cooler, increase the fan speed of the graphics card.
  • #3 14032887
    ThePatrolPL
    That's good: / But the computer is going terribly loud as the fan turns up: / then it stays so 70 degrees ... And what are the maximum temperatures for given components?
  • #4 14032985
    pawelr98
    Help: 413
    Rate: 1155
    Graphics cards are ~ 90 ° C (although it is better to keep them lower), processors, depending on the architecture, can be very different, but universally accepted as 65-70 ° C (excluding old procks (e.g. ATHLON XP) and mobile processors. temperature varies because some OC processors need lower temperatures (e.g. Phenom II requires temperatures below 60 ° C for OC)).
    The bridges on the board are ~ 75 ° C and the power section depends on how heavily it is loaded.
  • #5 14033563
    gabkabaltazar
    80 degrees is not normal temperature and it's no wonder, even for 7970. My 7850, underlined, never comes close to 70 degrees. "the card is just full but it is limited and cannot use full power and is overheating?" not sure if troll ... In MSI afterburner, set the power target to the maximum, manually turn up the fan to a minimum of 45% and the rest of the settings to default, i.e. timing, etc., and see if it will heat up
  • #6 14035501
    pawelr98
    Help: 413
    Rate: 1155
    gabkabaltazar wrote:
    80 degrees is not normal temperature and there is nothing to be charmed about, even for 7970. My 7850, underlined, never comes close to 70 degrees
    The fact that your card does not reach these temperatures is only because it generates less heat and has a different cooling system.
    For almost 2 years I used hd6990 with air cooling where temperatures of 85-90 ° C were the norm and nothing happened. Now the card is water-based so the maximum temperature is usually 50-60 ° C (in summer at 35 ° C air temperature and fans at low speed, it will be exceptionally high under 70 ° C).
    A colleague deigns to read the tests of many reference card models and observe that such temperatures are not surprising.
    Graphics chips usually only slow down after reaching 95 ° C, so don't worry about the author.
  • #7 14130319
    rafal_rx
    Help: 56
    Rate: 108
    Another example: the new R7 250X from Sapphire Flex (HD7770), tiny cooling, only two heatpipes and 73 ° C and the fan at 20%. When I tire a little more with, for example, a benchmark, the temperature increases even more and only the fan accelerates.
    Except that two slots lower, another card is inserted, which increases the temperature on the first one by a few ° C. So, the fan on the side of the casing blowing on the graphics is important.
  • #8 14130366
    wariato
    Help: 1213
    Rate: 840
    Replace her thermo paste with a new one, turn up the fans by 10-15% and she has to run. What is your casing and how many fans are there?
    80 degrees for this class of cards is nothing extraordinary.
  • #9 14197767
    borzo_xx
    This type is like that, I wouldn't care.
  • #10 14240301
    ThePatrolPL
    Nothing happened so far. The temperature stayed around 70-80 during intense gaming. But recently something has flickered again and the upper casing heats up (the most where the power supply is), I suspect that the heating of the computer is the fault of the power supply. Is it possible? The power supply is not some noname, but CrossAir 650V so I am surprised; (but it's already a year old so it could .. How do you think? Because it becomes unbearable, the computer heats up quickly! It works loud. And I also had problems with the front USB input when I tried to connect something it pops up with too high voltage Maybe it's this fault?
    also when I disconnected the computer, a spark popped out and the TV turned off in the room xD Myszka and the key still shines after turning off the computer. Maybe it's the fault of the bios setting?
  • #11 14240471
    borzo_xx
    I'll start at the back. The fact that the mouse and the choke are glowing is an option in the bios. Therefore, it is possible that the mobo is crazy, maybe some capacitor has swollen, I shoot.
    Check the power supply with a voltage test, you will see if there is any stability or a monte carlo.
    Too high voltage is a curiosity, usually it is too low for the front of the panel.
    I cannot give you clear advice. Do these tests, show what happened, maybe we can eliminate something.
The discussion revolves around the overheating issue of the MSI Radeon HD7970OC TwinFrozr graphics card, which reaches temperatures around 80 degrees Celsius during gaming sessions. Users clarify that 80 degrees is within the normal operating range for graphics chips, although some suggest that it is preferable to keep temperatures lower. The effective memory clock is noted to be 5500 MHz, derived from the reference clock of 1375 MHz, which is correctly interpreted. Recommendations include increasing the fan speed to manage temperatures better, replacing thermal paste, and ensuring proper airflow within the case. Concerns about the power supply's performance and potential overheating are also raised, with suggestions to test the power supply for stability.
