Fans in the GTX 1050 t and gaming x graphics card - working at full
AceKST 6714 9
Why do the fans on my MSI GTX 1050 Ti Gaming X run at 100% even at 32°C with Zero Frozr enabled, and how can I fix it?
If the fans still run at 100% after removing the MSI utilities and doing a clean driver reinstall, and the same behavior appears under Linux, the card likely has a hardware fault rather than a Windows/software problem [#16801634] [#16801934] [#16802570] Test the card in Linux without installing the MSI Windows tools; if the fans behave the same there, software can be ruled out [#16801634] [#16801934] One reply notes that a broken RPM controller on the GTX 10xx series can cause this symptom, with fans stuck at full speed even when the card cools down [#16801934] In that case, the practical fix is to return the card or send it back for service [#16802570]
  • #1 16800008
    AceKST
    Hello. I have a problem with my MSI GTX 1050Tii gaming X graphics card. The problem is that the fans on the graphics card work 100% of their capabilities even when the temperature is 32 degrees and the zero frozr function is activated.
    (drivers are up to date), and additional MSI programs installed: msi after burner, msi gaming app and rivatuner statistics server.
  • #2 16801190
    310artur
    Help: 980
    Rate: 670
    It dump all these programs, uninstall the driver using DDU, reinstall the driver and let me know if it helped.
  • #3 16801338
    adam998
    Rate: 187
    The fans in this card should only switch on at 60 degrees
  • #4 16801448
    AceKST
    The fan starts at 55 degrees and works at 100% and even if the temperature drops to 20 it still works. As for the drivers, I uninstalled them and reinstalled the same thing. And I tried each of the MSI programs one by one and the same thing happened.
  • #5 16801508
    310artur
    Help: 980
    Rate: 670
    Somehow I did not clearly write or what? Uninstall all programs. Then uninstall the driver using DDU. Only then install the driver. Test.
  • #6 16801552
    AceKST
    I did the same before you wrote.
  • #8 16801907
    AceKST
    And on this linux, once I run it, install the card drivers and these programs from msi or not?
    safbot1st
    Help: 2719
    Rate: 1585
    Maestro, Windows software will not work for you under Linux.
    310artur wrote:
    I don't know how to fire up a cart, but you can do it ;)
    E.g. with the command:
    sudo apt-get install
    There can be any GPU test like this:
    https://www.howtoforge.com/tutorial/linux-gpu-benchmark/
    Added after 5 [minutes]:
    For example, in Puppy linux Tahr I have in the Glmark package manager in the list of installation programs.
    You should not have installation problems.
    Added after 6 [minutes]:
    310artur wrote:
    It's the same with the card.
    This would not be the first case of a broken RPM controller on the 10xx series, but I have recently seen a case where the card turned the fans 100% under windows and on Linux the problem disappeared.
  • #10 16802570
    AceKST
    A good card on Linux behaves exactly the same, so I pack it in a box and send it back. Thank you for your help.
The discussion revolves around an issue with the MSI GTX 1050 Ti Gaming X graphics card, where the fans operate at full speed (100%) even at low temperatures (32 degrees) despite the Zero Frozr function being activated. Users suggest uninstalling all MSI software and drivers using DDU, then reinstalling the drivers to troubleshoot the problem. It is noted that the fans should typically activate at around 55-60 degrees. One user proposes testing the card under Linux to rule out software issues, as similar problems have been reported where fan speed issues were resolved in a Linux environment. Ultimately, the original poster concludes that the card behaves the same under Linux and decides to return it.
