Combining 2x2GB DDR3 1066MHz RAM with Asus B85M-G & Corsair DDR3 4GB: Compatibility & Profitability
Matt1314 31983 13
Can I combine 2×2 GB DDR3-1066 modules with a Corsair 4 GB DDR3 module in an Asus B85M-G, and will the mixed RAM run properly?
Yes, you can use the 2×2 GB DDR3-1066 modules together with the Corsair 4 GB module on the Asus B85M-G, and the whole set will run at 1066 MHz, limited by the slowest memory [#14061754] If the controller does not like the mix, the usual signs would be instability such as resets or BSODs, but with 3 slots filled nothing bad should normally happen [#14061822] One reply notes that filling more slots puts a greater load on the memory controller, so problems can sometimes appear, though the combination itself is still possible [#14061786] Whether it is worth doing depends on whether you need the extra capacity more than higher speed [#14061754]
  • Assessing mixed DDR3 RAM compatibility on Asus B85M-G
    #1 14061701
    Matt1314
    Rate: 8
    Hello. I currently have 2x 2GB DDR3 1066MHz RAM.
    I put together a new computer and buy a motherboard Asus B85M-G and memory for her Corsair DDR3 4GB
    Is it possible to insert these memories from the previous computer into this motherboard with this RAM memory without any problems? I read that only the timing will decrease. Is it profitable? :) Greetings.
    Wafer
    Help: 29
    Rate: 59
    It is possible without any problems, just the whole memory will work at 1066MHz, is it worth it? It probably depends on the application, one will need more space, and the other will need more space.
  • #3 14061786
    Leon165
    Rate: 9
    It is possible, but allocating all 4 slots on the board places a greater load on the controller and sometimes problems arise. You can manually increase the timings - your memory my low latency "CL7" should go to 1333MHz with increasing latency to CL9.
  • Mixed RAM speeds may require relaxed timings
    #4 14061799
    Matt1314
    Rate: 8
    There will be 3 memory slots. 1x4GB RAM 1333MHz and 2x2GB RAM 1066MHz.
    Rather, I will not increase to 1333MHz, let it be 1066. What problems may occur?
    Leon165
    Rate: 9
    With 3 slots filled, nothing bad should happen.
    If the controller does not make, the signs are like with damaged memories - resets, bsods, etc.
  • Mixing 3000 and 3200 MHz RAM with OC
    #6 19165819
    Kuku1985
    Rate: 10
    Hi, I have a question, it's been a while since the last post on this topic. I have 8GB DDR4 3000Mhz at home, as far as I know, you can do OC for 3200 and I would like to buy another 8GB, but already 3200. How is it with OC RAM ?! if I do not do OC, I understand that I will have 16GB 3000Mhz if I do OC 3200Mhz, then those with 3000Mhz will have OC 3200Mhz and those will work without OC? Or maybe it all argues with the OC of course ?!
  • Mixed RAM will run at the weakest module’s settings
    #7 19167090
    Leon165
    Rate: 9
    Kuku1985 wrote:
    Hi, I have a question, it's been a while since the last post on this topic. I have 8GB DDR4 3000Mhz at home, as far as I know, you can do OC for 3200 and I would like to buy another 8GB, but already 3200. How is it with OC RAM ?! if I do not do OC, I understand that I will have 16GB 3000Mhz if I do OC 3200Mhz, then those with 3000Mhz will have OC 3200Mhz and those will work without OC? Or maybe it all argues with the OC, of course ?!
    Different memories turn up differently. With two memories, the OC will depend on the weaker one - the memory always works with the same parameters for both.
    It's best if you enter exactly what memory you have and what you want to buy.
  • #8 19167148
    Kuku1985
    Rate: 10
    I have 8GB XPG D41 3000Mhz and want to buy 8GB XPG D41 3200Mhz
  • #9 19168542
    Leon165
    Rate: 9
    Quite a few different D41's are
    Link
    In general, they will work together - the weaker will simply limit the better.
  • #10 19168701
    Kuku1985
    Rate: 10
    I know that much, I mean what in the case of OC ...?
  • #11 19168734
    Leon165
    Rate: 9
    It can also be done.
    Get yourself Thaiphoon Link , take a screenshot (there will be a button at the bottom of the window) and throw it here - we'll see what exactly is sitting there.
    Also put a link to the ones you want to buy.
  • Mixed ECC DDR4 modules running at 2666 MHz
    #12 19180545
    solantis
    I will write with the question :)
    I have originally
    SAMSUNG 16GB DDR4-2400 UDIMM ECC Unbuffered CL17 Dual Rank
    and I bought it
    SAMSUNG 32GB Samsung ECC UNBUFFERED DDR4 2Rx8 2666MHz PC4-21300 UDIMM
    I checked, and they both work on 2666 - does this mean that the system turned the 16 to 2666 and won't it affect errors?
    I work in graphics and I wouldn't want bluescreen screens :)
    configuration: Asus workstation WS C246 PRO, PNY Quadro P2000 5GB, Intel Xeon E-2136 TRAY
    thanks
  • 2666 cl19 vs 2400 cl17 latency comparison
    #13 19180770
    Leon165
    Rate: 9
    I have originally
    and I bought it
    I work in graphics and I would hate to bluescreen :)
    thanks
    Probably these 2666 have CL19, which is basically the same as the 2400 CL17. If the album set it up that way, I wouldn't expect any trouble.
    Edit
    It is even possible that one of the 16GB JEDEC profiles has the 2666 CL19 saved - if there are more profiles (the popular CPU-Z shows only the last 4), you can view them all in the free Thaiphoon Link (for example - my memories have 16 JEDEC profiles saved).
    In theory, the 2400 CL17s are slightly faster than the 2666 CL19s
    2666 CL19 = 14.25ns
    2400 CL17 = 14.16ns
  • #14 19182359
    solantis
    Cool. thanks for the info.
The discussion revolves around the compatibility of combining 2x2GB DDR3 1066MHz RAM with a Corsair DDR3 4GB module on an Asus B85M-G motherboard. Users confirm that it is possible to use these memory modules together, but the overall memory speed will default to 1066MHz due to the slower RAM. Concerns are raised about potential issues when all memory slots are filled, such as increased load on the memory controller, which could lead to system instability, including resets and BSODs. However, it is generally agreed that using three slots should not cause significant problems, and users suggest that the system will operate without major issues if the memory is properly configured.
