[Solved] GA-P31-DS3L - selection of RAM memory.
Sorna 6300 16
How much RAM does the GA-P31-DS3L motherboard support in total, and what DDR2 modules should I buy?
The board supports 4 GB of RAM total across all slots, not 4 GB per slot, and the officially supported memory is DDR2-667 or DDR2-800; modules up to 2 GB were tested. [#16173827] A good choice is 2x2 GB DDR2-800, which should work on this platform. [#16173896] Do not use ECC/Registered memory. [#16173896] If you use a 32-bit Windows installation, it will not be able to use the full 4 GB, so 3 GB (for example 2 GB + 1 GB) may be enough. [#16173896]
  • #2 16173827
    dt1
    Admin of Computers group
    Help: 7320
    Rate: 8306
    Welcome. The specification says that the board supports a total of 4GB for all slots. Modules up to 2GB are tested, the board officially supports DDR2-667 and DDR2-800. In the manual you can read that you should avoid mounting two double-sided memories on a single channel (if you are going to fill only two memory slots, 2 GB each, it does not matter whether they are single-sided or double-sided, but if you want to buy 4x1GB, they should not they are only double-sided bones).
  • #3 16173835
    Sorna
    Double-sided single what is the difference.
    DDR2 1066 (OC) / 800/667 memory support, but here it follows that 3 types of memory can be used.
  • #4 16173859
    dt1
    Help: 7320
    Rate: 8306
    Two-sided have systems on both sides of the module. One-sided layouts only have one side, the other side is blank.
    One type (DDR2), different speeds. Pay attention to the note OC. In the official specification the max is DDR2-800, the DDR2-1066 memory will be released from the machine to DDR2-800, you can overclock it to the DDR2-1066 level if you want (OC).
    The manual only mentions DDR2-667 / 800 memory, not mentioning the 1066.
  • #5 16173869
    Sorna
    Give me something from the Allegro to match the record.
    And how to overclock the ddr because higher frequency is probably better work?
  • #6 16173896
    dt1
    Help: 7320
    Rate: 8306
    With this platform, you won't notice much of a difference, it's not the RAM that will be limiting the hardware speed, but most likely the CPU from the last decade. Find any DDR2-800 2x2GB and it should work. Memories cannot be of ECC type (sometimes labeled Registered). If you find something interesting, you can add it to the evaluation. If you have a 32 bit Windows version then you may as well buy 3GB RAM (2 + 1GB), the 32bit system won't be able to use the full 4GB.
  • #7 16173915
    Sorna
    Well, I have what Xp Professional but I would change to 7 because I have a laptop.
    And no updates to xp.
    So I'd rather fill Max's memory.
  • #8 16173932
    Robert B
    Help: 2027
    Rate: 1412
    Sorna wrote:
    I bought a new giant album
    The construction is old from 10 years ago, therefore absolutely not "giant" :) I guess if you bought a new one, you overpaid heavily comparing much newer boards to the old socket 775.
    http://www.pcworld.pl/testy/Gigabyte.EP.31.DS3L,343413.html
    The chipset has huge limitations in terms of module stocking and I doubt that you will manage to overclock the memory sensibly, because even faster, the board will downgrade to 800 anyway. Forcing will most likely end in a series of bluescreen screens.
  • #11 16173949
    Sorna
    Hehe mine were carrion, compared to this record and parts, it's epilepsy. Old computer AMD 3500 processor.
    Asus a8 sli se motherboard.
    6600GT graphics card.
    Now I have replaced it with intel core 2 duo E8400
    And graphics for 9600GT
    Added after 8 [minutes]:
    Why are these DDR better? I can see that they probably have additional cooling.
  • #12 16173959
    Robert B
    Help: 2027
    Rate: 1412
    And the brand and model of the power supply?
  • #13 16173971
    dt1
    Help: 7320
    Rate: 8306
    Sorna wrote:
    Why are these ddr better? I can see that they probably have additional cooling.
    And lower latency (CL), memories from your link have CL6 if I checked correctly.
  • #14 16187429
    Sorna
    450W power supply, I don't remember the model.
  • #15 16187461
    dt1
    Help: 7320
    Rate: 8306
    Then check the computer.
  • #17 17072623
    Sorna
    Closing topic
The GA-P31-DS3L motherboard supports a maximum of 4GB of RAM across all slots, with individual modules up to 2GB being tested. It officially supports DDR2-667 and DDR2-800 memory, while DDR2-1066 can be used but will be downclocked to DDR2-800. Users are advised to avoid using two double-sided memory modules on a single channel. For optimal performance, it is recommended to use DDR2-800 2x2GB configurations, and ECC memory types should be avoided. The discussion also touches on the limitations of older hardware, suggesting that the CPU may be the bottleneck rather than RAM speed. Users considering upgrades should be aware that a 32-bit operating system will not utilize the full 4GB of RAM.
