MAN TGX 2011: GDK/PDF Error 05531-01, Engine Light Blinking, Adblue Downloading Issue
wit-trans 26991 9
What should I check on a 2011 MAN TGX when fault 05531-01 lights the engine lamp and the AdBlue system shows a download/filling issue?
This fault points to a NOx/emissions problem, so you should look first at the AdBlue system, exhaust tightness, and the NOx sensor rather than just deleting the lamp. The code can stay stored for up to 400 days or 9600 hours, so clearing the MIL may turn off the warning but will not fix the underlying cause and the fault can return [#16281999][#16282678] Suggested checks were the AdBlue filters, the dispenser and injector, and leaks in the exhaust, especially the flexible connector (“harmonica”) [#16303563] Another likely cause is incorrect NOx readings from a fault in the AdBlue system, EGR, a clogged or leaking exhaust, or less commonly the sensor itself [#16282981] If those checks do not solve it, the NOx probe/sensor may need replacement [#16303563]
  • #1 16280617
    wit-trans
    Rate: 68
    TGX 2011, this error lit + the engine light is blinking, adblue is downloading.
    I am asking for a hint where to look for the fault.
  • #2 16281999
    klika60
    Help: 20
    Rate: 278
    Level 2 concentration of nitrogen oxides NOx, this error cannot be deleted, it remains in the memory for 400 days or 9600 hours. If you do not have any other active faults in memory, clear the lamp.
    MIL
  • #3 16282354
    wit-trans
    Rate: 68
    Ok, thank you for the hint!
  • #4 16282678
    svavecone
    Help: 73
    Rate: 456
    I presume erasing the MIL will not rectify the cause of the failure. Expect a repeat.
  • #5 16282954
    wit-trans
    Rate: 68
    Ie. that NOx to be replaced?
  • #6 16282981
    svavecone
    Help: 73
    Rate: 456
    Rather, it is something else that causes incorrect readings from the sensor, e.g. a fault in the AdBlue system, EGR, clogged / leaky exhaust, etc.
    Something that causes the NOx limits in the exhalation to be exceeded, which also does not rule out a fault in the sensor itself, but is less likely to fail.
  • #7 16303563
    sebotrucker
    Rate: 85
    There is no EGR in the first 5 euros.
    I would start by replacing the filters. Then cleaning the dispenser and injector. Another is checking the tightness of the exhaust, I would focus here on the harmonica - the flexible connector. If there was still a problem, I would use a different NOx for the replacement. It can even be from a passenger car, everything fits ;)
  • #8 16303693
    wit-trans
    Rate: 68
    I deleted the computer error. and has not yet occurred, he has covered 500 km.
  • #9 17725145
    sebotrucker
    Rate: 85
    I have had the same error for several days. In addition, I sometimes feel the NOx compliance error. I put the probe from the passenger car, I'm talking about the very end. From that moment, i.e. about half a year, it showed me a compatibility error, and recently 5531. Look for the problem in the converter or in the very tip of the probe? I also have a second car in which I did the same procedure, i.e. I inserted the Golf VII probe and it works flawlessly for the third year, it has already done 200,000. km and flies without any errors. Thank you in advance for your help.
  • #10 20034185
    gumka18
    Hello, where can I find the repair kit or the membrane itself?
The discussion revolves around a MAN TGX 2011 experiencing a GDK/PDF Error 05531-01, indicated by a blinking engine light and issues with AdBlue downloading. Participants suggest that the error relates to nitrogen oxides (NOx) levels, which cannot be cleared from memory easily. Potential causes include faults in the AdBlue system, EGR, or exhaust issues. Recommendations include replacing filters, cleaning the dispenser and injector, and checking exhaust tightness. One user mentions success in resolving similar issues by using a NOx probe from a passenger car. The conversation highlights the importance of addressing the root cause rather than merely clearing error codes.
