Bosch PIE611F17E Induction Hob 7kW: Upgrading Connection Capacity from 5kW, 1-Phase to 3-Phase
fixer45 56322 33
Can I use a 7 kW Bosch induction hob in a flat that currently has a 1-phase 5 kW connection, and does the AC400V marking mean I can switch to 3-phase?
No, not at full power: with a 1-phase 5 kW connection and B16 cooker protection, a 7 kW hob will be at or beyond the limits of the installation, so you need to increase the connection capacity and, in practice, get a 3-phase supply if you want to use it normally [#14135404][#14135648] The AC400V marking on the switchboard only means the board is adapted to work with 400 V; it does not prove that your apartment already has 3 phases [#14135404] According to the assembly instructions cited in the thread, this Bosch hob can be connected either to one phase (L+N) or to two phases (L1+L2+N), and the latter requires a three-phase supply [#14135657] If you keep it on one phase, the hob can be power-limited in its settings, but the total power of the zones will not exceed the set limit, so you may only be able to use one zone at maximum while the others stay low [#14135657][#14135648] Before applying, have an electrician check the cable from the meter to the apartment, because in a new building there may already be a route for three-phase wiring, or there may only be a 3-wire feed that would need replacing [#14135580][#14135610]
  • #1 14135306
    fixer45
    Rate: 8
    I am getting ready to buy a Bosch PIE 611F17E induction hob with a power of 7 kW.
    I was looking at my tauron contract and it says:
    Connection group - V
    Pre-meter protection 25 A.
    Measuring system - 1-phase
    Total connected load 5 kW
    My switchboard is ETI IP40 AC400V
    There are 5 current rose protections, 25 A each
    Fuses:
    Gn PI B16
    Gn P.II B16
    Gn Kuch B16
    Gn Łaz B16
    Washing machine B16
    Cooker B16
    P CO B16
    Dishwasher B10
    Ośw I and Oświęcim II on B10
    At the bottom, next to the main switch, I write 63A
    It is a new building from 2013.
    Now my question is it enough that I submit an application for increasing the connection capacity to be able to use the induction hob without any problems? The contract shows that I have a 1-phase system, come on the switchboard I write AC400V, it would follow that it is possible to switch to a 3-phase system?
    On Monday I will call the electrician who dealt with electrics here, thank you in advance for your help.
  • #2 14135404
    bearq
    Help: 414
    Rate: 1612
    You need a 3-phase system to power this board, 1 phase won't drag you to treasures.
    The fact that I write this on the switchboard only means that it is adapted to work with a voltage of 400V. You need to increase the connection power and specially pull up the 3 phases to your home.
    Then, separate everything and make a separate circuit only for the induction plate with a 5x4mm or 5x6mm cable and protect with a 25A fuse
  • #3 14135491
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    The board specification states that the board is 220-240V.
  • #4 14135536
  • #5 14135541
    fixer45
    Rate: 8
    Thank you for your answer.
    I am weak from electricity, I understand that it is possible to connect to 1 phase?
    When does the board consume 7kW? It is enough that all 4 fields will be turned on, or when I will only set all fields to maximum power?
  • #6 14135555
  • #7 14135559
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4290
    Why are you giving up and confusing the user who asks the question, since the power supply voltage is the only parameter for you?
    You behave like vendors in well-known supermarkets, telling people to buy farmazons - that the board is suitable for 230V installations. Yes, it is suitable, but not in Polish conditions. Nobody mentions it ...
  • #8 14135562
    pol102
    Help: 163
    Rate: 369
    Currently not. The miniature circuit breaker B16 has a nominal operating current of 16A, which is approximately 3600 watts of power. Approximately because: POWER = voltage * current. The value of the mains voltage varies with time. Overcurrent protection, popular circuit breakers, so-called "esy" has two triggers - short circuit and overload. In this particular single-phase case, we are interested in the overload release, which has a standard value of k = 1.13 ... 1.45. The trigger curve is not flat :) The closer to the limit value, the faster the protection will work. You can easily find such a characteristic.
    Returning to the merits, for a short while the protection will withstand a power of about 5350 watts.
    In all this, other devices in the installation and cables that have been used in the installation should be taken into account. It comes out without much counting that the current at the protection limit can reach about 25A. And where next?
  • #9 14135571
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    Colleague Łukasz-O, no one makes water from the brain to anyone, since the specification clearly states the voltage of 220-240V, on what basis can we conclude that the board can work at 400V. The nameplate would dispel any doubts.
  • #10 14135577
    fixer45
    Rate: 8
    What does it mean, a block or a single-family house
    It is a block.
    What steps should I take in order to connect this disc? What does the labor look like in order to have 3 phases, there is a lot of forging in the apartment? I have a switchboard with fuses in my apartment and there is a whole installation downstairs in the cage from which I can read the electricity consumption.
  • #11 14135580
    pol102
    Help: 163
    Rate: 369
    Without a site visit? It depends on what is connected (what wire) to the measuring system (meter) and what wire is connected from the measuring system to the switchgear in the apartment.
  • #12 14135585
    marek majchrzak
    Help: 25
    Rate: 117
    A: 1 There is a possibility.
    A: 2 According to the specification, this is "Connected load (total) 7200 W", ie at maximum load.
    However, in your single-phase home, cooking dinner is the same as candlelight.
  • #13 14135590
    Łukasz-O
    Help: 654
    Rate: 4290
    niewolno2 wrote:
    Colleague Łukasz-O, no one makes brain water, since the specification clearly states the voltage of 220-240V, on what basis can we conclude that the board can work at 400V. The nameplate would dispel any doubts.
    What specification? You mean the seller, what does the seller write on the website? Paste the link to the manufacturer's instructions. Then we can talk.
  • #14 14135595
    fixer45
    Rate: 8
    Tomorrow I will call the electrician who dealt with it and I will ask about these wires and what he will say about connecting the induction hob.
  • #15 14135602
  • #17 14135609
    fixer45
    Rate: 8
    I have one more question 5kW is the maximum power that can be obtained on 1 phase?
  • #18 14135610
  • #20 14135623
    fixer45
    Rate: 8
    On Monday, I call an electrician and I will make sure that it is a 3-wire cable.
    And a hob with a power of about 3.7 kW would be able to connect to the 1st phase without any problems? The only question is whether such an album will not be too weak?
    On the euro agd website, they write such stupid things:
    "The voltage value in the electrical installation required for connection and proper operation of a given device - given in volts (V). Depending on the type of household appliances, they can be powered by alternating current with a voltage of 230 V or 400 V. The device with a supply voltage of 230 V can be connected to standard electrical socket, no special, durable installation is required The supply voltage of 400 V means that the device must be connected to a suitable, separate electrical system, so-called three-phase. "
    One of the other things is important, according to them, the hob with a power of 7 kW and a voltage of 230 v can be connected to 1 phase, since you can have a maximum of 5 kW per phase ... In total, you can connect but use one field ..
  • #21 14135624
  • #22 14135629
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    My friend Bronek22 what's the problem?
  • #23 14135634
    Łukasz-O
    Help: 654
    Rate: 4290
    The problem is that you can forget about cooking. It's like that in a nutshell, without delving into the technical aspects of the installation.
  • #24 14135637
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    It is logical that you do not connect a 7kW board to a 5kW installation and I do not know on what basis my colleague Bronek22 accuses me of saying that you can connect a 7kW board to a 5kW installation. It is known that if the disc will not be used with full power, one phase will handle this disc, but if we turn on all the fields, it may not be interesting.
  • #25 14135639
  • #26 14135645
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    My friend Luke-O In such a system, lead me out of the mistake and indicate where, as you say, "I cover my tracks".
  • #27 14135648
  • #28 14135657
    freebsd
    Help: 766
    Rate: 2033
    Buddy Fixer45, according to the assembly instructions of your plate, you can connect it to one phase (L + N) or to two phases (L1 + L2 + N). For the latter option, you need a three-phase power supply. In the new block, the cables from the box with a meter to your home probably run along a technical plumb line, so any forging could be limited to the walls of your home. It is also possible that someone thought before and you have laid the cables for three-phase installation.
    When you connect the hob to one phase, you can set the hob's maximum power (basic settings, parameter c7). Then the total power of the cooking zones will not exceed the set limit. This may mean that e.g. only one field will be able to work with maximum power (e.g. boiling a pot of water), and other fields at the same time will be able to work with low power (e.g. supporting cooking).
  • #29 14135733
    marek majchrzak
    Help: 25
    Rate: 117
    The only thing left is signing a new contract, allocating power, replacing the meter ... a bit of breaking up and modernizing the network at home and then it will go downhill.
  • #30 14136561
    Gregory_bg
    Help: 55
    Rate: 80
    Looking at the manufacturer's description, the device is powered by 230V and, as it happens in marketing manuals, nothing about the power scheme. Make sure about the power supply for this board or if necessary change the disc, the choice is yours
The discussion revolves around the installation of the Bosch PIE611F17E induction hob, which has a power rating of 7 kW. The user is currently on a 1-phase electrical system with a total connected load of 5 kW and is seeking advice on upgrading to a 3-phase system to accommodate the hob's power requirements. Responses indicate that a 3-phase system is necessary for optimal performance, as a 1-phase connection may not support the full load, especially when all cooking zones are in use. Suggestions include applying for an increase in connection capacity and ensuring proper wiring and circuit protection, with recommendations for a dedicated circuit for the induction hob. The conversation highlights the importance of understanding electrical specifications and the implications of connecting high-power appliances to existing systems.
TL;DR: A 7 kW hob draws about 30 A on 230 V, and “You need a 3-phase system” [Elektroda, bearq, #14135404; #14135536]. Without a supply upgrade, breakers will trip. Why it matters: Cooking on full power becomes impossible and warranty can be voided.
• Bosch PIE611F17E total load: 7.2 kW (spec) [Bosch Manual] • Current on single phase: ≈31 A @ 230 V [Elektroda, 14135536] • Typical Polish single-phase contract: 5 kW / 25 A max [Elektroda, post #14135306] • Recommended hob circuit: 5×4–6 mm² cable + 25 A breaker [Elektroda, 14135404] • Tauron capacity-upgrade fee: 113 PLN per added kW [Tauron Tariff 2024]
Can the PIE611F17E run on a single-phase supply?
Yes, but only if the line can deliver ≥31 A. Most flats have 25 A limits, so the hob will trip protection or dim lights [Elektroda, #14135536; #14135562].
Why do experts recommend three phases for this hob?
Distributing 7 kW over two or three phases cuts current per conductor to ≤16 A, fitting standard breakers and avoiding voltage drop [Elektroda, bearq, post #14135404]
What happens if I connect it to 1 × 25 A anyway?
Running all zones at max will exceed the 25 A main fuse; the supply disconnects, leaving you without power mid-cooking [Elektroda, 14135562]
How much current does 7 kW draw at 230 V?
Power ÷ voltage = current: 7200 W / 230 V ≈ 31 A [Elektroda, 14135536]
My block was built in 2013—are three phases already in the riser?
Modern Polish blocks usually run five-core cables in shafts, but many flats still receive only three cores; verify at the meter cabinet before planning [Elektroda, 14135610]
Which cable size and breaker should feed the hob?
Use 5×4 mm² Cu (min.) with a 3-pole 25 A C-curve breaker; 5×6 mm² gives extra margin for long runs [Elektroda, 14135404]
Can I limit hob power instead of rewiring?
Yes. In settings menu (parameter c7) you can cap total load in 1 kW steps, e.g., 3.5 kW, but cooking speed drops noticeably [Elektroda, 14135657]
Is there an edge case where even three phases fail?
If phases are badly balanced—e.g., oven + hob on same phase—one conductor can still over-load and trip; keep loads spread evenly [Elektroda, 14135555]
How much does increasing contracted power cost?
Tauron charges 113 PLN per additional kW plus a new three-phase meter (~200 PLN installation) [Tauron Tariff 2024].
Three-step: filing a power-upgrade request
  1. Download “Wniosek o Zwiększenie Mocy” from your DSO site.
  2. Fill desired power (e.g., 3 × 16 A = 11 kW) and attach property title.
  3. Submit online or at customer centre; expect a revised contract and meter swap within 30 days [“Tauron Process Guide”].
Does 400 V on the switchboard mean I already have 400 V supply?
No. The board marking only states insulation rating; actual supply can still be single phase [Elektroda, 14135404]
Are lower-power induction hobs (≈3.7 kW) usable on 16 A circuits?
Yes; 3.7 kW equals 16 A at 230 V, matching a B16 breaker. You’ll have ~2 kW left for other loads [Elektroda, 14135648]
