How to Verify Proper Earthing Function in Your House Using a Meter: Home Method Guide
Erinome 70080 3
  • #1 14184106
    Erinome
    Hello, is it possible to use some home method (I have a meter) to check if the grounding in the house is working as it should?
  • #2 14184141
    edberg
    Level 30  
    Help: 133
    Rate: 117
    There are dedicated devices for this, e.g. Sonel MPI 520 or 525 or older MPI511 and many others. You can only check where it is connected (to what), but without measuring it, you won't learn anything more. Of course, without going into the layout of the network.
  • #3 14184155
  • #4 14184976
    emigrant
    Help: 107
    Rate: 326
    I was supposed to measure the resistance of my earth electrode in this way. I brought the sum sum to my home by an electrician with Sonel MPI-520 and it was measured using the technical method. The home method not only can be distorted, but also not very safe. Besides, publishing (suggesting) such methods to laymen is not very wise.
    For @Erinome, it's probably more about whether the pin is grounded at all than measuring the resistance. The L / PE meter (pin) is to be 230V. Something more is an electrician with equipment.
