Amount of Real Data Transmitted at 512 Kbps: Synchronous Link & 64kB/sec without Compression
kalkowska 15624 12
How much actual data can be transmitted in one second over a 512 kbps synchronous link without compression, and why is it not simply 64 kB?
At 512 kbps, the theoretical one-way rate is 512,000 bits/s ÷ 8 = 64,000 bytes/s, or 62.5 KiB/s when bytes are expressed with 1024-based units [#14311778][#14312437] You should not divide by 2 just because the link is synchronous; synchronous is not the same as symmetrical, so the 512 kbps figure applies to the link rate itself, not half of it [#14313813] If you mean usable payload rather than raw line rate, checksums, control packets, and other protocol overhead reduce it further, which explains lower figures such as “over 55 kB” [#14311783]
  • #1 14311535
    kalkowska
    How much real data can be sent in 1 s over a synchronous link with a bandwidth of 512 kbps, without hardware and software compression?
    I've seen a question on the forum before, the answer is over 55 kB.
    Why? Please give me a precise explanation.
    Since 1B=8b, then 512kb/8=64kB
  • #2 14311625
    McMarycha
    Help: 114
    Rate: 198
    512kbps : 2 = 256kbps because it's synchronous
    256kbps : 8 = 32kBps it can send in 1 second
    I hope its good.
  • #4 14311778
    Jones_
    I think I will surprise you, I get 62.5KB of data :D
  • #5 14311783
    excray
    Help: 739
    Rate: 657
    There are also checksums, control packages and other things that make life difficult for programmers, so it will be even less.
  • #6 14311805
    McMarycha
    Help: 114
    Rate: 198
    Jones how did it go?
  • #7 14311824
    Jones_
    apart from other matters, only theoretically the bandwidth of the connection
    512/8/1.024=62.5
    throughput is wka data is in K
  • #8 14312379
    McMarycha
    Help: 114
    Rate: 198
    I thought the author meant how much he could send. But unless I understood.
  • #9 14312437
    Jones_
    In my opinion, that's how a kilogram is not equal to a kilogram
    speed small k = kilo, decimal 10 to 3 = 1000B
    big data K = Kilo, binary 2 to 10 = 1024B
    I don't understand why I have to divide it by 2
    After all, the type of connection does not matter, only what speed we have assigned
    it doesn't even matter if we receive or transmit in a given direction, we have 512 kilos
  • #10 14312867
    McMarycha
    Help: 114
    Rate: 198
    I meant that if the link is 512kbps and it is synchronous, the upload and download are equal. So we divide by 2
  • #11 14313813
    rwisniewski1
    Help: 40
    Rate: 39
    Does your colleague distinguish between the terms: synchronous - asynchronous link from symmetrical - unsymmetrical?
    With a 512kbps synchronous link, division by 2 makes no sense.
  • #12 14314174
    McMarycha
    Help: 114
    Rate: 198
    And I actually got those ideas wrong.
The discussion centers on the amount of real data that can be transmitted over a synchronous link with a bandwidth of 512 kbps without compression. Various participants provide calculations and insights, with some suggesting that the effective throughput is around 62.5 kB/s, while others argue that factors like checksums and control packets reduce this figure further. The debate includes clarifications on the distinction between synchronous and asynchronous links, with some participants mistakenly dividing the bandwidth by two, assuming equal upload and download speeds. Ultimately, the consensus leans towards a theoretical maximum of 64 kB/s, but practical considerations suggest lower actual throughput.
