Citroen Berlingo 1.6HDI 2013 - Supplement FAP EOLYS Damaged tank controller
pisior1987 66738 2
  • #1 14314365
    pisior1987
    Help: 12
    Rate: 351
    Car as in the subject. The tank was damaged and the controller was flooded:
    I replaced the entire bubble, poured a new liquid.
    You definitely need to reset the counters, I already know. I don't have LEXI (yet) and unfortunately my mega macs can't handle it.
    I still have a problem whether this driver on the bubble must have power ??
    It's about these three wires:
    Is it ground power and middle diagnostic ??
    I have no schema.
    The car goes into emergency mode.
    I have errors on the engine controller:
    p1435 and p1434
    At BSI:
    Unfortunately, no code. Appendix FAP -pump malfunction.
    There is also some error in the pump driver, but unfortunately I cannot read it.
    In the parameters, the level of the FAP 100% supplement.
    Is it just enough to reset the counters or is something else wrong?
  • #2 14314714
    kybernetes
    Help: 426
    Rate: 1488
    There is a parts replacement procedure, you enter "eolys reservoir replacement" and it guides you by itself.
  • #3 14317029
    pisior1987
    Help: 12
    Rate: 351
    It was enough to reset the counters in the engine controller and the add-on controller. Unfortunately, the universal equipment does not cope yet.
