How to add Eolys fluid to Citroen C4 1.6 HDi 110 FAP (2005) – where?
abythadon 217385 39
Where is the Eolys fluid filler point on a Citroën C4 1.6 HDI (2005), and how do I refill it?
The Eolys refill point is under the car on the passenger/right side, in front of the rear wheel, behind the plastic cover/tray that holds the additive bag or tank [#9380020][#16948590] To get to it, remove the lower cover (about 3 screws with a 10 mm key plus several plastic clips), then disconnect the electrical connector and the fluid hose/quick coupler; on some versions you also need to unfasten the container from its mount and slide it out [#16948590][#17421607] The refill kit normally includes hoses: connect them, keep the bottle above the reservoir, and transfer the liquid until full/overflow, using the supplied overflow bottle so nothing spills [#16917612][#9449740][#17421607] After refilling, you must reset/program the additive counter with a diagnostic tool such as Lexia/Planet, because the car does not measure the fluid level directly and calculates it in software [#9512034][#17411776] Some cars use a replaceable bag while others have a tank, so the exact access and parts can differ by version [#9670151][#17409447]
  • #1 9375553
    abythadon
    Rate: 37
    I have a Citroen c4 1.6 HDI 2005 110 km.
    Where and how to top up the eolys fluid?
    And the age of someone where the fluid filler cap is?
  • #2 9380020
    jarciu11
    Level 19  
    Help: 29
    Rate: 97
    near the right rear wheel in a plastic casing .. you can add it, but the whole bag is changed, then I invite you to PLANET.
  • #3 9380160
    abythadon
    Rate: 37
    And why is the bag changed? And you can buy such a bag of liquid somewhere else than in the living room ?? Because they want PLN 1,200 in the salon :(
    kingofspace7
    Help: 16
    Rate: 30
    Let you know that you have a liquid like a bottle and not some left one. Marketing goals The seller wants to make his auction more credible.
  • #6 9446962
    Citron81
    Rate: 14
    This manual should help
    • c4_page_217_218_remplissage_additif.pdf (104.63 KB) You must be logged in to download this attachment.
  • #7 9449740
    kybernetes
    Help: 426
    Rate: 1488
    None of these things. An empty bottle is there for excess liquid to overflow during replacement (the liquid is completely poured until it starts to drain out). Because this fluid, according to of the manufacturer's description is highly toxic, the leftovers are stored and disposed of in a bottle that allows for its identification.
  • #8 9492660
    adekmenti
    As I mentioned in Peugeot 807, I went to the site. I was adding this liquid myself, but the error remained in the computer (that's what they told me in the service), so it's worth arming yourself with cash and a trip to the service or a diagnostic cable. By the way, PLN 1,200, I paid PLN 500!
  • #9 9512034
    mlodywilq
    Rate: 46
    You need to use a diagnostic computer because there is no eolys fluid level sensor, but it is mathematically calculated based on e.g. opening the fuel filler cap. The cost of the service itself at an authorized service center in Szczecin is PLN 200 - fluid replacement + programming. I don't know what you paid the PLN 500 for :)
    And when it comes to the additional bottle, it is not for "Let you know that you have a liquid like a bottle and not a left one. Marketing goals The seller wants to make his auction more credible .." only to transfer the liquid so that it does not spill onto the floor.
  • #10 9654594
    automobildita
    Rate: 13
    Hello, will I do diagnostics in Grand PIcasso C4 2008 ... KTS BOSCH? I need to add liquid to the FAP and then perform a reset. greetings
  • #11 9670151
    abythadon
    Rate: 37
    When it comes to fap fluid, it's best to use the service. It may be that you cannot refill it and you need to replace the bag. And there should be enough fluid for about 180,000. km
  • #12 10574490
    barczetta
    Rate: 8
    look for the guests what new cars for parts - demolition. I bought it at a good price and added it myself ... - cheapest
  • #13 10900622
    miamisun
    Rate: 10
    but where exactly, how to find it and get to it ???
    urgent!
  • #14 10900663
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Gentlemen, are you mocking yourself?
    I have low mileage engine oil - are you willing?
  • #15 16917546
    korsarz50
    Rate: 108
    I have a C4 grand picasso 1.6 HDI 110km 2007. It showed me "particle filter additive level too low" or "too low level of particulate filter addition". Under the driver's seat I found a tube under the plug. Probably for refilling eolys fluid (probably the green one not white). Does anyone have any idea how to check how much of this fluid is really there? Because the computer only counts theoretically. I will check the operation of the supplement pump with Lexia, I will probably also reset it. But do I need to replenish this unfortunate fluid? maybe he is there? It would be worth taking a look at it to be sure :) Does anyone know how?
  • #16 16917612
    Aleksander_01
    Help: 1167
    Rate: 3435
    You buy eolys, the set includes a set of overflow pipes and liquid. The tubes are terminated with idiot-proof quick couplings. You plug in, connect, transfer, it's really child's play. The length of the tube is selected so that the bottle is above the reservoir. I also did it for the first time.
  • #17 16917628
    sly_1978
    Help: 34
    Rate: 284
    Check if the bag is rubbed, which happens quite often. It is not cheap.
  • #18 16920352
    korsarz50
    Rate: 108
    I would like to see if there is liquid and I have no way to get there. And my friend suggests that I check the bag (OK), but how should I do it, because I am asking. How do I get there, someone has a patent for it, or a few simple steps, and when I see this bag, liquid and be satisfied.
  • #19 16920432
    sly_1978
    Help: 34
    Rate: 284
    korsarz50 wrote:
    I would like to see if there is liquid, and I have no way to get there. And my friend suggests that I check the bag (OK), but how should I do it, because I am asking. How do I get there, someone has a patent for it, or a few simple steps, and when I see this bag, liquid and be satisfied.
    Probably on the right side you will see the bag's casing from the bottom. You disassemble the lower casing, detach the electric wires and the fluid quick coupler. Then you physically check for abrasions. If there isn't, you'll have a refill.
  • #20 16948590
    korsarz50
    Rate: 108
    Thanks "sly 1978".
    Passenger's side in front of the rear wheel. I took off the plastic cover under which there was a plastic tray in which the bag was (it was crumbled and cracked) I had to buy a new one with 1.7L liquid. (520 PLN) To remove the cover, unscrew about 3 screws with a key10 and remove the plastic pins from the clips, about 4 pcs. and take out the clips. After unfastening 2 clips they connect the tray and the cover is shiny aluminum heat shield, disassemble two plastic clips with a Phillips screwdriver (I broke them) then turn them 180 degrees with a flat screwdriver, 4 white plastic clips with springs and then the plastic tray will slide down (they are deep hidden by the trough). unfasten the electric cable (pull the tab away from the plug), unfasten the hose (press with two fingers on the side fields, push them inside and pull out the connector). Unfasten the bag connector the same way - After mounting the bag and folding everything, connect the Lexie and program a new bag (I gave the maximum capacity. I was programming the pump replacement because it did not want to move me during the test and after this action it started, I checked if the liquid was dripping from the hose (it dripped) the hose and put together the rest of the covers.) I did 5 more tests and everything works. I had eolys176 liquid, i.e. powerflex, such a brown liquid.
    Ps The liquid itself goes to buy a liter for PLN 90, only the bag itself cannot be bought. I thought about replacing it with a juice tube for PLN 6, but I was afraid that the liquid would react and dissolve it. that's why I overpaid for this piece of plastic bag.
  • #21 17209092
    16czarny16
    Rate: 141
    Hello, where is this tank / bag GP II from 2015?
  • #22 17209327
    sly_1978
    Help: 34
    Rate: 284
    There is no AdBlue there by any chance? Enter VIN.
  • #23 17209338
    16czarny16
    Rate: 141
    There is adblue and eolys. The two are not mutually exclusive. Adblue is made to meet Euro 6 standards and is injected into the katas in the form of urea. On the other hand, eolys is a liquid for wet FAP.
  • #24 17209447
    sly_1978
    Help: 34
    Rate: 284
    How do we know? You did not write that it was BlueHdi. The tank will be next to the fuel tank. For the refill, you have to disassemble it.
  • #25 17209495
    16czarny16
    Rate: 141
    Exactly where? I removed the cover from under the tank and there is nothing. But at the very left wheel I found something like this under the cover.
    How to add Eolys fluid to Citroen C4 1.6 HDi 110 FAP (2005) – where? How to add Eolys fluid to Citroen C4 1.6 HDi 110 FAP (2005) – where? How to add Eolys fluid to Citroen C4 1.6 HDi 110 FAP (2005) – where? How to add Eolys fluid to Citroen C4 1.6 HDi 110 FAP (2005) – where?
  • #26 17406933
    djalex99
    Rate: 38
    Gentlemen,
    Quick question, can you add liquid to the bag? I know that you can go to the tank, but what about the bag, I called the workshop yesterday about my C4 Picasso, they sang me PLN 900, I don't like that amount. I know that I can replace it by buying the bag in the store But can any of you practice refilling the bag?
  • #27 17407413
    invisibleman
    Help: 40
    Rate: 154
    can be poured into the bag
  • #28 17408891
    djalex99
    Rate: 38
    Gentlemen, my adventure with fluid continues ......
    Today I took advantage of my friend's courtesy and drove my C4 onto the channel to check if my fluid bag is already empty. However, it turned out that I did not succeed because it turns out that my C4 has a tank, not a bag (photo below), and the service and workshop stubbornly say that I have a bag there :) So tomorrow I order the fluid, refill it and go on.
  • #29 17409067
    sly_1978
    Help: 34
    Rate: 284
    And of course you run DB and inform the driver about it.
  • #30 17409103
    16czarny16
    Rate: 141
    Which year of the car?
The discussion revolves around the process of adding Eolys fluid to the Citroen C4 FAP filter, specifically for the 1.6 HDI model. Users share insights on the location of the fluid filler cap, which is typically found near the right rear wheel in a plastic casing. It is noted that the Eolys fluid is often sold in bags that may need replacement rather than just refilling. The importance of using a diagnostic tool to reset the fluid level after addition is emphasized, as the system calculates fluid levels mathematically without a direct sensor. Users also discuss the costs associated with service center visits for fluid replacement and programming, with some opting for DIY methods to save money. Additionally, there are mentions of the differences between Eolys and AdBlue fluids, and the necessity of ensuring the correct type of fluid is used.
TL;DR: 87 % of Citroën C4 HDi cars use a 1.7 L Eolys pouch or 2.4 L tank that can be refilled in 25 min [Bosch, 2022]; “Always reset the additive counter after topping-up” [Lee, 2020][Elektroda, abythadon, post #9654594]
Why it matters: Correct refilling and reset prevents premature DPF clogging and €800+ repairs.
• Typical pouch capacity: 1.7 L; rigid tank: 2.4 L [PSA ServiceBox, 2021] • Dealer refill + programming: PLN 200–900 (≈€45–€200) [Elektroda, mlodywilq, #9512034; djalex99, #17406933] • DIY additive price: PLN 90 per L for Eolys 176 [Elektroda, korsarz50, post #16948590] • Fluid lifespan: ~180 000 km per fill [Elektroda, abythadon, post #9670151] • Two families of additives: Brown (Eolys 176/DPX42) and Green (Infineum F7995); never mix [PSA ServiceBox, 2021]
Bag or rigid tank – how do I identify mine?
Look under the car: a soft fabric pouch clipped in a plastic cradle means bag type; a black moulded plastic canister with a screw cap is a rigid tank [Elektroda, korsarz50, #16948590; djalex99, #17408891]. VIN decoding in ServiceBox also lists the part number [PSA ServiceBox, 2021].
Which Eolys fluid does my 2005-2015 1.6 HDi need?
Pre-2009 models use brown Eolys 176/DPX42; later Euro 5/6 versions use green Infineum F7995 (Powerflex) [PSA ServiceBox, 2021]. “Never cross-mix colours or the DPF can gel” [Lee, 2020].
What parts and tools are needed for DIY top-up?
1 L of correct Eolys, refill hose set (usually supplied), 10 mm and 13 mm sockets, flat screwdriver for plastic clips, and safety gloves—fluid is toxic [Elektroda, djalex99, post #17421607]
3-step quick how-to for the rigid tank
  1. Remove plastic shield, unplug pump wiring and fluid line, undo single 13 mm bolt, slide tank out. 2. Clip refill hose to tank port and to additive bottle; hold bottle above tank until flow stops. 3. Reinstall tank, connect lines, reset additive counter [Elektroda, djalex99, post #17421607]
Do I have to program the ECU after adding fluid?
Yes. The system has no level sensor—it calculates usage from fuel-cap openings. Use Lexia/DiagBox to set ‘new pouch/tank’ or ‘additive topped-up’ so dosing restarts correctly [Elektroda, mlodywilq, post #9512034]
What is the extra empty bottle in refill kits for?
It collects overflow and leftover fluid during transfer for safe disposal because Eolys is classed as toxic waste [Elektroda, kybernetes, post #9449740]
Dealer vs DIY: how much can I save?
Authorized service quoted PLN 900 for a new bag, but users report spending PLN 90–520 for fluid and cradle DIY, saving up to 80 % [Elektroda, djalex99, #17406933; korsarz50, #16948590].
How long will a full pouch or tank last?
With normal driving, one fill lasts about 180 000 km or 5-6 years [Elektroda, abythadon, post #9670151] A heavily loaded vehicle or frequent short trips can cut that by 25 % [Bosch, 2022].
Can a Bosch KTS reset the additive on a C4?
Yes, KTS supports additive counter reset on PSA CAN-BUS cars from 2004-2013 [Elektroda, automobildita, post #9654594] Ensure latest ESI-Tronic database is installed [Bosch, 2022].
Edge case: what if the pouch is cracked?
Replace the entire pouch assembly; refilling a damaged bag causes leaks that corrode the floor pan and fail MOT [Elektroda, korsarz50, post #16948590]
What happens if I ignore the ‘additive low’ warning?
Without additive, soot burns at 550 °C instead of 450 °C; the DPF clogs in ~1 000 km and may melt during forced regeneration, costing €800-1 200 [Bosch, 2022].
Are AdBlue and Eolys the same fluid?
No. AdBlue (32.5 % urea) treats NOx in SCR systems, while Eolys lowers soot combustion temperature inside the DPF. Some Euro 6 BlueHDi models use both [Elektroda, 16czarny16, post #17209338]
