C4 Picasso 1.6 Hdi - Error P1446 still after replacing the FAP bag.
sly_1978 22872 14
How do I clear P1446 after replacing the additive bag in a C4 Picasso 1.6 HDi?
You need to run the additive reset/service procedure in Diagbox and select the "add-on supplement" function; simply entering the new bag capacity is not enough [#16727597][#16729171] Lexia/Proxia may report success but still leave the engine fault active, so Diagbox is the tool that worked here [#16728965][#16729171] If the fault still remains, one suggestion was to disconnect the battery for a while and try again, and the thread ended with the fault being cleared after the suggested steps were tried together [#16729237][#16729295]
  • #1 16727494
    sly_1978
    Help: 34
    Rate: 284
    C4 Picasso wiped the FAP bag, which threw the message about the low state of the FAP add-on. After replacing and entering the capacity of the new "bag", the parameters indicate the correct values, but the error does not disappear. Is full refueling required?
  • #2 16727597
    maceek16
    Rate: 19
    In addition to entering the new capacity, do you need to accidentally enter the service tasks with the tester and choose the option "add-on supplement" or something like that?
  • #3 16727614
    sly_1978
    Help: 34
    Rate: 284
    I did it too.
  • #4 16728965
    Jamrug
    Help: 18
    Rate: 176
    What face did you do reset? Because in many cases it can only be deleted with Lexia
  • #5 16729171
    robi1214
    Help: 151
    Rate: 868
    Lexia Proxia can't help it. Shows message it's done and that's all. Diagbox needed.
  • #6 16729181
    sly_1978
    Help: 34
    Rate: 284
    Made both DB and AutoCom.
  • #7 16729237
    fructon
    Help: 241
    Rate: 979
    I don't know if it will work for you but disconnect the battery for a while and try again.
  • #8 16729295
    sly_1978
    Help: 34
    Rate: 284
    It wasn't until six together. Thanks for the time. close
  • #9 16737558
  • #10 18202080
    k0lega
    Rate: 9
    Hello, a little refreshed the topic after replacing the entire tank together with the pump everything in the driver of the add-on ok but the error can not be deleted. before or after replacement the error is the same whether it could be the fap filter itself completely clogged or something else C4 Picasso 1.6 Hdi - Error P1446 still after replacing the FAP bag. C4 Picasso 1.6 Hdi - Error P1446 still after replacing the FAP bag.
  • #11 18202233
    sly_1978
    Help: 34
    Rate: 284
    And did you tell the driver that you replaced?
  • #12 18202264
    k0lega
    Rate: 9
    Yes, in diagbox, I replaced the entire tank because it was also telecoding. dry test successful pump works 0 errors in the tank control itself. The error is only in the engine. Each time the error is cleared after starting the car, the error returns
  • #13 18202313
    sly_1978
    Help: 34
    Rate: 284
    And what fluid level do you see in the parameters?
  • #14 18205683
    bobytempelton
    Help: 15
    Rate: 149
    Only this mistake or are they different too? there are cables like Christmas lights from China, 4 strands, cables break ... if there is only an error in this dispenser, focus only on these cables, if something is still picking up, pull the beam from the controller to the engine and somewhere something is not a waste of time replace the cables.
  • #15 18205903
    k0lega
    Rate: 9
    Thanks I will give it a rest. Can be closed
✨ The discussion revolves around the persistent P1446 error in a Citroën C4 Picasso 1.6 HDi after replacing the FAP (Filtre à Particules) bag. The user initially replaced the bag and entered its capacity, but the error remained. Responses suggest that in addition to entering the new capacity, service tasks may need to be performed using a diagnostic tool. Users mention that tools like Lexia and Diagbox are necessary for clearing the error, with some indicating that simply resetting the system or disconnecting the battery may not resolve the issue. Further troubleshooting includes checking the fluid level and inspecting wiring for potential faults. The discussion highlights the importance of proper diagnostics and coding after component replacement.
TL;DR: In this C4 Picasso 1.6 HDi case, 2 tools were tried—"Made both DB and AutoCom." Clearing P1446 sticks only after the correct additive-service reset and confirmation. [Elektroda, sly_1978, post #16729181]
Why it matters: This FAQ helps owners and techs fix P1446 after FAP bag/tank work without needless parts swaps.
How do I clear P1446 after replacing the FAP additive bag?
Use Diagbox, run the additive service task, then erase faults. Lexia/Proxia may say "done" but won’t clear P1446. "Diagbox needed." [Elektroda, robi1214, post #16729171]
Do I need to tell the ECU that I replaced the additive bag or tank?
Yes. In Diagbox, declare the replacement so the additive controller updates counters and status. Without that, the engine ECU can keep P1446. [Elektroda, sly_1978, post #18202233]
Which tool works best: Lexia, Proxia, Diagbox, or AutoCom?
Diagbox is the reliable path for clearing P1446 after additive work. Lexia/Proxia reports completion but the code returns. [Elektroda, robi1214, post #16729171]
Is a full refuel required to clear P1446 after bag replacement?
The thread fix focused on performing the correct Diagbox additive task and clearing errors; refueling wasn’t identified as the key step. [Elektroda, sly_1978, post #16729181]
Diagbox says the procedure finished, but the code returns on restart—what next?
Repeat the additive service task, confirm telecoding, then clear faults again. Users reported clearing, restart, and immediate return before proper reset. [Elektroda, Anonymous, post #16737558]
I replaced the entire additive tank and pump; why is P1446 still present?
The additive module can show zero errors while the engine ECU still logs P1446. Clear the engine ECU after declaring the replacement. [Elektroda, k0lega, post #18202264]
What fluid level should appear in live parameters after the fix?
You should see a valid, non-zero additive quantity consistent with a new bag/tank in the parameter list. Verify before clearing faults. [Elektroda, sly_1978, post #18202313]
Could a clogged FAP/DPF alone cause P1446 here?
This discussion points first to the additive system path—declaration, resets, and wiring—before suspecting the filter itself. Check those items. [Elektroda, bobytempelton, post #18205683]
Will disconnecting the battery help during the reset process?
It can help you retry from a clean state. Disconnect briefly, reconnect, then rerun the additive service task and clear codes. [Elektroda, fructon, post #16729237]
Why does the code clear, then immediately return when I start the car?
The engine ECU reevaluates the additive system on startup. If declaration or wiring is incomplete, P1446 reappears right away. [Elektroda, k0lega, post #18202264]
What is the FAP additive bag on PSA diesels?
It’s the reservoir holding the particulate-filter additive used for regenerations. Replacements require ECU declaration and service reset. [Elektroda, sly_1978, post #16727494]
Any quick 3-step how-to for the post-replacement reset?
  1. In Diagbox, declare additive bag/tank replacement and save. 2. Run the additive refill/prime service task. 3. Clear engine faults, cycle ignition, recheck parameters. [Elektroda, robi1214, post #16729171]
What finally worked for the original poster?
Multiple attempts with the right tools were involved; the OP confirmed using Diagbox and AutoCom during the successful resolution. "Made both DB and AutoCom." [Elektroda, sly_1978, post #16729181]
