Controller for external roller shutters - individual and group control, 16 roller shutters
koalabis 3000 8
  • Clarifying controller requirements for 16 roller shutters
    #1 14353024
    koalabis
    Rate: 22
    I am asking for help in selecting a controller that is proven and trouble free in operation.
    All wires from motors and control buttons brought to the telecommunication switchboard. 16 roller shutters on two floors.
    I need to implement the following functions:
    -individual control of each roller shutter,
    -four group buttons distributed throughout the house,
    -closing and opening of all roller shutters from the alarm.
  • #2 14353157
    azibik
    Level 32  
    Help: 82
    Rate: 324
    You do not need a controller, relays are sufficient.
  • #3 14353541
    koalabis
    Rate: 22
    Anything more?
  • #4 14441426
    jaks1
    However, you will need controllers to realize the function of group control, in my practice the controllers from PROXIMA work well, by the way, using a multi-channel remote control we can realize control of each roller shutter separately and also groups in any (needed) configuration
  • #5 14444456
    koalabis
    Rate: 22
    I have decided on the controllers from F&F. They fully implement the assumed functions. Additionally, it is possible to program the relay operation time, which protects the roller shutter motor in case the limit switch is damaged. Time will show how the devices fail.
  • #6 14464435
    lichy923
    Rate: 11
    Did you choose the knock-in modules or the ones mounted in the switchboard? Regards.
  • #7 14466009
    koalabis
    Rate: 22
    I had all the wiring from the motors and buttons in one place so I chose system bus-mounted controllers.
  • #8 15070451
    axpl
    Rate: 113
    koalabis wrote:
    I had all the wiring from the motors and buttons in one place so I chose system bus mounted controllers.
    Which controller did you choose?
  • #9 15071067
    koalabis
    Rate: 22
    I wrote earlier that I chose F&F for the rail. Everything works without any problems
