How to build an automatic arm to extend a TV from inside a wall?
panm 3609 10
How can I build an automatic mechanism that slides a TV out from inside a wall?
Use a linear electric actuator such as an FDI-series unit to move the TV out, and handle the wiring with cable guides made for CNC machines [#14582927] Do not choose a self-locking actuator, because in a failure the mechanism should still be movable by hand [#14583114] Add a manual emergency release for one fixing point, such as a pull pin or key lock, so the TV can be disconnected if power fails [#14709491] Gas springs like those used in car boots can also help support the TV’s weight and reduce the load on the actuator during each cycle [#14709491]
  • #1 14432393
    panm
    I am looking for a solution for something like this:
    Do any of you have any ideas on how to build this? From where and what materials to use?
    Thank you very much for any advice and suggestions
  • #2 14432447
    maurycy123
    Conditionally unlocked
    Help: 226
    Rate: 745
    And where do you see the television there? There's some kind of sticker plate that slides out. Doing such a thing is not a problem. The problem will be with the TV. Or more precisely with all kinds of cables.
  • #3 14432478
    brofran
    Help: 651
    Rate: 1409
    You won't be able to do it yourself at home - at most a hand-opened door made of plasterboard . :D So you would have to contract a specialist company to make . The cost of the mechanism will far exceed the price of a good TV . But nowadays you can do everything , why not ?
  • #4 14432479
    azibik
    Level 32  
    Help: 82
    Rate: 324
    How much insertion space do you have ?
  • #5 14432507
    panm
    I have 1.5 m in the wall and this is how much I would like the tv to slide out....
    Question: which guide to use and how to control it ?
  • #6 14432543
    DJ_Dexinter
    Help: 90
    Rate: 218
    I suspect microcontroller, stepper motors and/or IR sensors.
  • #7 14432569
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    By the way, I wonder what happens to the retracted "TV" from the film as we fire up the fireplace :D
    As for the slide-out TV solution, a game not worth the candle. A HD projector with a pull-down screen will come out cheaper.
  • #8 14582927
    Elektrobim
    Help: 10
    Rate: 66
    An electric actuator, such as the FDI series, can be used with peace of mind for this purpose.
    As far as cable problems are concerned, they can easily be solved by using cable guides from CNC machines - readily available, for example, from Allegro.
    Elektrobim
    ul. Śląska 9, Stargard Szczeciński, 73-110
  • #9 14583114
    azibik
    Level 32  
    Help: 82
    Rate: 324
    This actuator is not suitable,it must not be self-locking.In case of failure,it must be possible to move manually.
  • Manual emergency release with gas springs and FDI actuator
    #11 14709491
    Elektrobim
    Help: 10
    Rate: 66
    You can always use the option of unlocking one of the fixings (pulling the pin or key lock - whatever). This is a more secure solution in case of an emergency or power failure. For this, you can always use air springs (like in car boots) - the TV won't sink under its weight, and the actuator will also have a lighter weight with each cycle. The FDI is quiet and has few failures. Are you looking for decoupling like there is on automatic gates?
    Elektrobim
