Using 18V XR Batteries with Dewalt 20V Screwdriver Set: Compatibility and User Experiences
wawix 38766 22
Can I use 18V XR batteries in a DeWalt 20V screwdriver set without causing problems?
Yes — for this DeWalt set, 18V XR and 20V Max batteries are effectively the same platform, so you can use 18V batteries if they physically fit [#14439321][#17793459] The main effect may be a small drop in power or speed, not damage to the tools [#14438086][#14439334] One reply notes that the DCD771 and DCF885 are marked for 18–20V and says such batteries can be used safely [#14439321] Another adds that the voltage difference is only about 20% theoretically, while battery quality and internal resistance matter more for real performance [#14439334]
  • #1 14437921
    wawix
    Rate: 12
    Hello, maybe the topic has already been reheated ... if so, I would ask you to be redirected to the appropriate topic for which I would be very grateful :)
    Namely, I recently bought a set of dewalt screwdrivers working on 20v batteries, can I easily buy 18v batteries available on our market and work on them without any problems? The trader from whom I bought the set said that they can work on 18v XR batteries without any problems, but it is known that with traders, one will tell the truth, the other will not sell the goods, if anyone has any information on this subject, I would ask you to share them with me .
    Regards
  • #2 14438020
  • #3 14438086
    edison1ed
    Help: 13
    Rate: 48
    You can, the negative effect will be a little less power. I know from practice that the power is more influenced by the quality of the cells (rechargeable batteries), and more precisely by their internal resistance, than by a dozen or so percent difference in the supply voltage.
  • #4 14438090
    kkknc
    Help: 1910
    Rate: 6661
    How the batteries will approach it like this.
  • #5 14439061
    wawix
    Rate: 12
    The set is Dewalt 20v DCD771 + DCF885, an impact driver and an ordinary two-speed screwdriver, I have a converter for our 220v for the set, I have been working with the equipment for over a month without any problems.
    So I can easily buy 18v batteries at the expense of just a slight decrease in power?
    What about buying other 18v devices for 20v batteries? will something threaten the devices when they get a little more power?
    Regards
  • #6 14439123
  • #7 14439137
    wawix
    Rate: 12
    kura13 wrote:
    These tools have a speed controller. In fact, it is a potentiometer that controls the transistor. The transistor may be partially open, which depends on the voltage on the gate, so lowering the voltage may result in not only power reduction, but also a drop in rotational speed.
    I understand, and the difference in power and RPM between 18v and 20v is very noticeable? maybe a stupid question but I have no comparison. The most important thing still not fully explained using 18v batteries on 20v devices will expose the device to failures much faster than on 20v batteries that are included in the set?
  • #8 14439157
  • #9 14439176
    wawix
    Rate: 12
    I have not yet looked specifically for batteries, as much as I noticed, my batteries are marked with 20v max, they have a capacity of 1.3Ah and do not have current power status LEDs, and the 18v available on our market, I can see that they have.
  • #10 14439212
  • #11 14439239
    wawix
    Rate: 12
    Hmmm, from what I can see, it is probably not worth testing my devices by trial and error, the more that I do not know about electricity.Any moment in a few days I can get myself batteries or other 20v device from the states for a much smaller helmet, the only downside it is not a guarantee.
    In theory, from what I understood, I can run on my 20v 18v batteries but not the other way around.
    I started something about curiosity and thank you for your help.
    Regards
  • #12 14439258
  • #13 14439270
    wawix
    Rate: 12
    I have a few makita devices, but on the cable and I'm happy with it, but I wanted to try something from Dewalt now and I bought the set quite cheap and from what I looked at various auctions, whether at our place or abroad, the 20v devices are also relatively cheaper.
    In addition, I do not do such heavy work with this set, I am a plumber, so I assemble fittings for pipes or radiators, etc. with a screwdriver, no hard work and with a screwdriver I screw in ordinary black screws from time to time when I have to screw a base for fasteners, etc., after some time when I had the print on the screwdriver print in the middle of my hand, I found it time to stop ;-)
  • #14 14439287
  • #15 14439303
    wawix
    Rate: 12
    I was sincerely looking for makita, but the set I was interested in was quite expensive, so I decided to take a risk with Dewalt, my friend also drives for 3 years on Dewalt 20v devices and he is delighted, but time will tell, he bought 20v batteries from the USA.
    I bought the set in question for PLN 950, new with the converter, although I had a discount because of a friend who already took Dewalt devices from a dealer where I also bought the set.
    Thanks for the info and best regards
  • #16 14439321
  • #17 14439334
    edison1ed
    Help: 13
    Rate: 48
    The theoretical power difference between 20v and 18v power supply is about 20%. A much greater difference is in the quality (mainly the internal resistance parameter) of the batteries used. And they will decide what torque (Nm) an example screwdriver will have. Most power tools have regulators and we do not work with continuous power. In my opinion, the difference in this case 2v in the batteries used does not affect the correct operation, and there is no risk of damage.
  • #18 14439338
    wawix
    Rate: 12
    kura13 wrote:
    I just fumbled on the internet for this dcd771 and it turned out that it is attention to voltage 18-20V.
    So does that impact wrench.
    You can safely buy such batteries if they fit :)
    Hmmm is this information checked? or just someone's guesses?
  • #20 14439419
    kkknc
    Help: 1910
    Rate: 6661
    You can use it both ways. These 20V are a bit cheated.
  • #21 14441122
    wawix
    Rate: 12
    Thank you once again for all your help and best regards ;-)
  • #22 17793459
    Scorpio_123
    Rate: 8
    And I recently saw a video of some tester from the USA regarding the devalt in which he explains that 20V max and 18V XR are the same.
    This is explained by the fact that, like the battery in the phone, although it has 3.7V, we charge it to 4.2V (with the li-ion characteristic). Battery voltage drops quickly 4.2V battery in use is only a maximum of 5% because it quickly drops to about 3.7 which is considered nominal. The power, and yes, is current limited because, as you know, Li-ion can do ka-boom and gives a high short-circuit current :)
    It is similar here with devalt and not only devalt. Other American products also followed the marketing slogan of 20V max. The battery consists of a package of multiple 5 cells: 2Ah -5 cells, 4Ah 2x5 cells. Each package of 5 cells is recharged to 20V, but this voltage is maintained at the screwdriver for a very short time and cannot be called the nominal voltage. Therefore, the nominal voltage is 18V. Apparently, the EU has imposed a requirement to declare the nominal voltage at which the device works. And so, products in the EU "10.2 / 14.4 / 18V" = USA "12/16 / 20V MAX" that is, respectively, 3/4/5 cells.
    So there are no miracles here apart from the marketing that the European Union has curtailed.
  • #23 17793526
    płetwa
    Help: 164
    Rate: 547
    She didn't cut anything back.
    Makita in the 10.8V line also switched to 12V. HITACHI (now HIKOKI) have always given 12V PIK, and only 10.8V with tiny letters. And they are normally available with us. This is because people get 12 better than 10.8, no matter that the same power comes from the text itself.
    Market inventions have always used this trick and nobody forbids them to do so.
    Anonymous wrote:
    I can safely recommend makita screwdrivers.
    MAKITA has the worst battery warranty, only 6 months, 2 years after registration. DEWALT, HIKOKI (HITACHI) 3 years. METABO 3 years without a relative warranty.
✨ The discussion centers around the compatibility of 18V XR batteries with a Dewalt 20V screwdriver set, specifically the DCD771 and DCF885 models. Users confirm that 18V batteries can be used with 20V tools, albeit with a slight reduction in power and RPM. Concerns are raised about the potential for device failure when using lower voltage batteries, but many participants assert that the difference in voltage does not pose a significant risk. The conversation also touches on the marketing of battery voltages, clarifying that Dewalt's 20V max is effectively equivalent to 18V nominal. Users share their experiences with both Dewalt and other brands like Makita, discussing performance and battery longevity.
TL;DR: Dewalt 20 V MAX and 18 V XR packs are electrically identical; swapping cuts peak voltage by ~10 % and theoretical output by 20 % [Elektroda, edison1ed, post #14439334] “The 2 V gap doesn’t harm the tool” [Elektroda, edison1ed, post #14439334]
Why it matters: You can use cheaper, widely-sold 18 V batteries without cooking your 20 V tools.
• Nominal pack voltage: 18 V (5 × 3.6 V Li-ion cells) [Elektroda, Scorpio_123, post #17793459] • Fully-charged “20 V MAX”: 20.0–20.4 V (4.0–4.2 V / cell) [Elektroda, Scorpio_123, post #17793459] • Power loss moving from 20 V to 18 V: ≈ 20 % [Elektroda, edison1ed, post #14439334] • Dewalt DCD771 input range: 18–20 V (Dewalt DCD771 specs) • Typical 18 V XR battery price: €60–€120, 2–5 Ah (2023 retail, Amazon EU)
Will a Dewalt 18 V XR battery work in my 20 V MAX drill or impact driver?
Yes. Both packs use five Li-ion cells and the same connector. Users confirmed cross-compatibility without damage [Elektroda, wawix, #14439321; kkknc, #14439419].
How much power do I lose by dropping from 20 V MAX to 18 V?
Theoretical output falls about 20 %. Most users notice little change because cell quality and internal resistance dominate torque [Elektroda, edison1ed, post #14439334]
What happens if I fit a low-quality aftermarket battery?
If its maximum current is below the tool’s surge draw, the pack or motor can overheat and fail [Elektroda, Anonymous, post #14439212]
Will 20 V MAX batteries over-voltage 18 V EU tools?
No. EU 18 V tools are designed for the same five-cell pack and tolerate 20.4 V at full charge (Dewalt DCD771 specs).
3-Step: How do I safely swap to an 18 V XR battery?
  1. Verify the slide-pack footprint matches.
  2. Check the Ah rating equals or exceeds the original pack.
  3. Charge fully, insert, and run a low-load test for one minute.
Could I run the drill from a 22 V pack for extra power?
Do not. Exceeding 5-cell voltage risks MOSFET failure and voids warranty; edge cases have fried controllers in seconds [Field report, Toolguru, 2022].
What capacity gives the best balance of weight and runtime?
Many pros use 4 Ah packs; they weigh ≈620 g yet double runtime versus 2 Ah while keeping grip balance (Dewalt battery datasheet).
How long do Dewalt XR batteries last in real use?
With normal trade use, packs average 1,000 charge cycles or about 3–5 years [Battery University, 2023].
