Lenowo G580 BIOS Update: Facing Error 255 TDK Library Initialization Failure
Dj_Majster 29751 18
How can I fix Lenovo G580 BIOS update error 255: TDK library initialization failed?
The Lenovo BIOS flasher is meant to run from a supported 32/64-bit Windows environment, and Error 255 usually means the TDK library could not initialize in the current setup [#14510349] Use the correct package for your OS, `62cn40ww_32.exe` for 32-bit or `62cn40ww_64.exe` for 64-bit, and run it as administrator [#14510349] If it still fails, try setting the BIOS boot mode to Legacy and flashing from an older Windows installation or USB-booted older OS; one reply says this error appears on Win10 and newer, while XP through Windows 8 works [#14518289] [#21688900] If that does not help, the remaining option mentioned was reprogramming the BIOS chip with a programmer or having a service do it [#15255422]
  • #1 14510318
    Dj_Majster
    Rate: 41
    Today I wanted to update my bios, because apparently in the new one you can switch graphics cards (i.e. on which the computer is supposed to work now). Unfortunately, when you try to run the update installer, it displays something like this:
    error 255 tdk library initialization failed
    What's next?
  • #2 14510342
  • Windows BIOS update requires matching 32-bit or 64-bit package
    #3 14510349
    DriverMSG
    Help: 3984
    Rate: 4883
    Installing the package in Windows.
    1. This BIOS is only for Windows 7 32/64.
    Check your OS is x86(32bit) or x64. Locate the file 62cn40ww_32 or 62cn40ww_64 that has been downloaded.
    2. Run 62CN40WW_YY.exe as administrator .
    (62cn40ww_32.exe is for X86 system; 62cn40_64.exe is for X64 system).
    3. This program will flash new BIOS to your PC without interventions, at last PC will auto restart.
    http://download.lenovo.com/consumer/mobiles/62cn40ww.txt
  • #4 14510687
    Dj_Majster
    Rate: 41
    In bios, I have a choice of Switchable Graphics and UMA Graphics Bogdan K .
    DriverMSG I also read that note. I have Win 7 64bit, I download the bios file to my 62cn40ww_64.exe system and when I run it as admin, this error keeps popping up.
  • #5 14518084
    DriverMSG
    Help: 3984
    Rate: 4883
    Your case is not alone. Enter the exact model of your laptop - write down all the data from the sticker underneath it.
  • #6 14518248
    Dj_Majster
    Rate: 41
    Lenovo G580AH
    I5 3230M - 4GB - 1000 - DVD RW - 7HP64X - GF710M
    That's the whole sticker. Anything else needed?
  • #7 14518289
    DriverMSG
    Help: 3984
    Rate: 4883
    Switch in bios - Bios Mode to Legacy and check again.
  • #8 14518588
    Dj_Majster
    Rate: 41
    Unfortunately, I do not have such an option, the possibility of switching something like this in the bios.
  • #9 14518594
    DriverMSG
    Help: 3984
    Rate: 4883
    It should be in the BOOT tab.
  • #10 14520062
    Dj_Majster
    Rate: 41
    As I mentioned earlier, I do not have such an option in bios in this tab. The only options are:
    UEFI boot: I have it set to "off", then I have:
    Disk
    CD
    Network
  • #11 14527811
    Dj_Majster
    Rate: 41
    I understand that the problem is probably hard to solve ...
    I thought maybe UEFI had something to do with it. "I turned on" but it did not help, the error still pops up.
  • #12 14527957
    DriverMSG
    Help: 3984
    Rate: 4883
    Write to Lenovo Support - I'm curious about their answers.
  • #13 14531900
    Dj_Majster
    Rate: 41
    I wrote, as soon as they write back I will let you know.
    They wrote back nothing.
  • #14 14650090
    Dj_Majster
    Rate: 41
    "Run 62CN40WW_YY.exe as administrator.
    (62cn40ww_32.exe is for X86 system; 62cn40_64.exe is for X64 system) "
    The problem is that on the lenovo servers there is only the file ... 32.exe, and when enabling the download of the file ... 64.exe the installation instructions are displayed.
  • #16 14650655
    Dj_Majster
    Rate: 41
    :) I admit cunningly
    However, I downloaded the error, the same keeps showing ... Error 255 ...
  • #17 15255422
    xoree
    Level 30  
    Help: 129
    Rate: 174
    I had a similar problem - but I did not think about reprogramming with the programmer. However, I am curious if it can be solved differently.
    On the other hand, if you care about time, that's the only way to solve it. Unfortunately, you can only do it in a service (for a fee).
    You can buy a cheap programmer and do it yourself, but you need to have some knowledge.
  • #18 15256196
    Dj_Majster
    Rate: 41
    It sounds serious. I didn't get any reply from Lenovo.
  • #19 21688900
    petrkk79
    The problem is in OS, you need to flash the bios under WINXP-Windows8, from Win10 and higher, it throws this error. You have to download some USB Flash with older OS, as a HirensBoot, in BIOS disable the secureboot, set the booting for legay and eufi, and boot from the usb to the old one OS. Here, you can flash the bios without problems.
The discussion concerns a Lenovo G580AH BIOS update intended to enable switching between graphics modes, but the Windows flash utility fails with “Error 255: TDK library initialization failed.” The BIOS package is confirmed to be for Windows 7 32/64-bit, and the correct installer version is discussed, including direct 32-bit and 64-bit download links. The laptop’s current BIOS offers Switchable Graphics and UMA Graphics, but changing UEFI/Legacy boot settings does not resolve the flashing error. The exact machine model is identified from the sticker, and Lenovo Support is contacted without a useful reply. Later suggestions include flashing the BIOS from an older operating system such as Windows XP through Windows 8, or using a bootable USB environment with Secure Boot disabled and Legacy/UEFI boot enabled; another fallback mentioned is reprogramming the BIOS chip with an external programmer or service center.
