After updating the BIOS, the system won't boot. The message System is booting appears and in a moment the laptop starts over and over again. When he wants to go into recovery, BkueScreen crashes. I want this system to work and the files and programs on it, so I do not want to reinstall the system.
Restore default settings in the BIOS. If you have the original system (you did not install the system yourself using other settings in the BIOS), turn off "legacy support" (Boot tab).
WojtasDJ I do not know how the system was installed before.
Now I just want to restart the system. So I have to choose Windows 7 and then load default settings? And should the system start? Because I have already updated to version 40.
It works. I had to select Windows 7 first. Then click SAVE. Then Load default setting and SAVE again. Then the system booted up with no problem. Thanks!
Create an account, log in here and be active on the forum — ads won't appear. Earn points for registering and replying.
After a BIOS update, a Lenovo G50-30 laptop experiences booting issues, repeatedly restarting and encountering BlueScreen crashes during recovery attempts. Suggested solutions include switching the SATA controller mode from AHCI to IDE/Compatibility, restoring default BIOS settings, and ensuring the correct operating system settings are selected. The user successfully resolved the issue by selecting Windows 7, saving the settings, and loading the default BIOS configuration, which allowed the system to boot properly. AI summary based on the discussion. May contain errors.
