Connecting a Stair Switch as a Single-Pole: Phase to Red Socket Issues
raf2 25590 19
How can I wire a stair switch as a single-pole switch so the lamp is not permanently live?
Use a normal single-pole ON/OFF switch instead; a stair/cross switch is the wrong device for the simple two-wire circuit you describe [#14518708] The two conductors you call "0" are not neutral and phase; they are phase wires, with one permanently live and the other only disconnected by a breaker, so there is no neutral at that point [#14520697] If you still want to verify the switch, use an ohmmeter to find which terminals connect to the red common when the switch is toggled [#14522166] If the lamp still stays live, the wiring in the box is probably different from what you think, so a photo of the connected breaker and wires is needed [#14518703]
  • #1 14518625
    raf2
    Rate: 40
    Hello!
    I would like to connect the stair switch as a single-pole switch, but when I connect the phase to the red socket and the 0 to the pole, I still have current in the bulb all the time, regardless of the switching of the switch. How else to connect it?
    • Connecting a Stair Switch as a Single-Pole: Phase to Red Socket Issues w____cznik.jpg (20.52 KB) You must be logged in to download this attachment.
  • #2 14518703
    D214d3k
    Help: 543
    Rate: 633
    You probably have other connections. Red plus any on the other side.
  • #3 14518708
    marek majchrzak
    Help: 25
    Rate: 117
    Your description shows that you have a cross stair switch, which should be replaced with an ordinary ON/OFF bistable switch.
  • Requesting a photo and clarification of switch terminal wiring
    #4 14518711
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    raf2 wrote:
    Hello!
    I would like to connect the stair switch as a unipolar one, but when I connect the phase to the red socket and the 0 to the pole, I still have electricity in the bulb all the time, regardless of switching the switch. How else to connect it.
    What do you think is "0" and a pole. Be glad there is no short circuit.
    It would be more useful if you took a photo of the existing circuit breaker with the wires connected.
  • #5 14518802
    raf2
    Rate: 40
    Well, when I connect an ordinary single-pole switch, everything is ok. The diagram of this switch is shown in the picture. I'm not afraid of a short circuit, the differential will always work
    • Connecting a Stair Switch as a Single-Pole: Phase to Red Socket Issues ospel_1.jpeg (7.46 KB) You must be logged in to download this attachment.
  • #6 14518814
    Łukasz-O
    Help: 654
    Rate: 4292
    Take a picture of this circuit breaker with the wires connected!
  • #7 14518847
    raf2
    Rate: 40
    Attached is my connection diagram. of course, I connect the 2 poles alternately
    • Connecting a Stair Switch as a Single-Pole: Phase to Red Socket Issues ospel_3.jpg (19.33 KB) You must be logged in to download this attachment.
  • #8 14518856
    slawekx
    Help: 53
    Rate: 198
    What does "I connect O" mean here?
  • #9 14518886
    Łukasz-O
    Help: 654
    Rate: 4292
    And don't you sometimes connect "0" (whatever it means) to two terminals at the same time?
  • #10 14520601
    raf2
    Rate: 40
    I mean "-" I have 2 wires coming out of the socket, one live and the other not
  • #11 14520697
    Łukasz-O
    Help: 654
    Rate: 4292
    There's no downside there. This is a phase wire, only disconnected by a circuit breaker.
  • #12 14520881
    raf2
    Rate: 40
    I don't understand a bit
  • #13 14520936
    marek majchrzak
    Help: 25
    Rate: 117
    By shorting both wires together (without the switch) do you get the effect you've been fighting for from the beginning?
    Otherwise, me
    and I will have to go back to my elementary school education.
  • #14 14522121
    raf2
    Rate: 40
    Yes, without a switch, a short circuit of 2 cables results in the lamp being lit, and when I connect this stair switch, I cannot get this effect
  • #15 14522166
    remik_l
    Help: 144
    Rate: 325
    Check with an ohmmeter which switch terminals open and close relative to red when switching.
  • #16 14522219
    raf2
    Rate: 40
    Everything works fine on the ohmmeter
  • #17 14524127
    Łukasz-O
    Help: 654
    Rate: 4292
    So when you turn off the switch, the resistance increases to infinity, and when you turn it on it decreases to zero?
  • #18 14524153
    marek majchrzak
    Help: 25
    Rate: 117
    Then everything works fine except your head.
    Your continued actions could lead to personal injury or ultimately to the death of others.
    PS I have one more question. Have you taken the SEP exam entitling you to modernize electrical installations?
  • #19 14524486
    remik_l
    Help: 144
    Rate: 325
    Do you have well stripped wires and are you plugging them into the switch correctly?
    You may need to press the lock to push the wire deeper into the terminal.
  • #20 14524640
    Łukasz-O
    Help: 654
    Rate: 4292
    My suggestion to the author. If you can't handle changing the purpose of the stair switch, buy a single one.
    I'm closing the topic.
The discussion revolves around connecting a stair switch as a single-pole switch, where the user experiences continuous current in the bulb regardless of the switch position. Responses suggest that the user may be using a cross stair switch instead of a standard ON/OFF bistable switch. Clarifications about wiring, including the meaning of "0" and proper connections, are provided. The user confirms that an ordinary single-pole switch works correctly, and troubleshooting steps include checking wire connections and using an ohmmeter to verify switch functionality. Ultimately, a recommendation is made to purchase a single-pole switch if the stair switch cannot be adapted.
