[Solved] - Connecting a Double Stair Switch: Wiring Diagram Explanation & Success Confirmation
Majfa1986 61971 15
Will this stair-switch wiring diagram work as shown?
It should work in principle if the switch terminals are wired exactly as marked, but the protective conductor must be added correctly [#16119473][#16129504] The yellow-green PE wire is missing from the drawing and should go to each luminaire, not to the lamp bulbs; connect PE in the box where N is joined and then separately to each fitting [#16129177][#16119581][#16129361] Do not route PE through the right fitting so it continues to the left, because if a luminaire is dismantled the protection may be lost while the circuit can still be live when the second button is on [#16129361] Keep the color code consistent: N blue, PE yellow-green, and L must not be blue [#16129504]
  • #1 16119458
    Majfa1986
    Rate: 28
    If I do it as shown in the diagram, will it work?
  • #2 16119473
    niewolno2
    Level 40  
    Help: 630
    Rate: 1260
    If the descriptions on the switches he gave, it would be great, at first glance it is correct.
  • #3 16119524
    Majfa1986
    Rate: 28
    I haven't bought any switches yet, I wanted to lay the cables first. But if they are different, maybe I will start by buying the switches. Can you recommend any?
  • #4 16119549
    niewolno2
    Level 40  
    Help: 630
    Rate: 1260
    Remember about the yellow-green protective wire.
  • #5 16119556
    Majfa1986
    Rate: 28
    should yellow green go directly to the light bulbs?
  • #6 16119581
    niewolno2
    Level 40  
    Help: 630
    Rate: 1260
    Not for light bulbs, but for the luminaire, assuming that we know the protection class of the above-mentioned luminaires.
  • #7 16129159
    Majfa1986
    Rate: 28
    Will this connection be good?
  • #8 16129177
    3301
    Help: 224
    Rate: 869
    The most important conductor - PE / green / for each luminaire, as previously suggested, is missing
  • #9 16129234
    Majfa1986
    Rate: 28
    Yes, I know, I have it in the drawing, but I didn't scan it, but is the rest correct?
  • #10 16129254
    3301
    Help: 224
    Rate: 869
    With all due respect, but what the rest, we consider the scheme as a whole
  • #11 16129269
    Majfa1986
    Rate: 28
    after all, PN flies straight into the housing, I know it was drawn with a pen that did not scan. But ok, maybe someone else has a glance
    Added after 8 [minutes]:
    I corrected the diagram
    3301
    Help: 224
    Rate: 869
    Dude, it's not PN but PE and you cannot connect it in the right fitting so that it goes further to the left, you can connect it in the box where the N wire is connected / this dot / and to each fitting separately.
    And because if the luminaire is disassembled, the luminaire will be live when the second button is turned on and the protection may not be there anymore
  • #13 16129455
    Majfa1986
    Rate: 28
    Thanks for your help, is the rest correct?
  • #14 16129504
    3301
    Help: 224
    Rate: 869
    Yes, remembering the colors N-blue, PE yellow-green, L just not blue. and f-z
  • #15 16129519
    AdamC
    Help: 140
    Rate: 246
    I will ask what the algorithm of action should be, what do you want to get?
    There is a two-way switch in the title, and you do not need cross switches and so many wires between them to control the switching off and on from 2 places.
    Unless it is about switching off / on from the 1st place and switching the lamps from the 2nd place.
  • #16 16129524
    Majfa1986
    Rate: 28
    I know about the colors. Thank you so much for help
The discussion revolves around the wiring of a double stair switch, with users seeking confirmation on the correctness of their wiring diagrams. Initial responses indicate that the proposed wiring appears correct, but emphasize the importance of including a yellow-green protective wire (PE) for safety. Users inquire about the proper connections for the protective wire and the overall wiring scheme, with clarifications provided regarding the distinction between neutral (N) and protective (PE) wires. The conversation also touches on the necessity of understanding the switching mechanism, particularly in relation to controlling lights from multiple locations. Users share updated diagrams for further validation and seek confirmation on the accuracy of their connections.
