Choice of on-line CO control system with 800l buffer and radiators on Wi-Fi
dagny1 3246 10
How can I choose a Wi‑Fi-based heating control system for an 800 l buffer, 11 radiators, and a small underfloor heating area so I can keep the house at low temperature and preheat it before arrival?
Use wireless Z-Wave thermostats and connect them through a Z-Wave control unit that gives you Wi‑Fi/internet access for remote temperature changes [#14599081][#14602661] The suggested setup was Danfoss Z-Wave thermostats controlled by a central unit such as VERA Edge, with Fibaro mentioned as a more expensive option for larger home automation systems [#14599081][#14602661] The functional chain is: thermostats -> Z-WAVE -> control panel -> WI-FI -> Internet -> PC/smartphone, so you can raise temperatures before arriving [#14602661] Z-Wave was recommended because it is widely supported by many manufacturers and can later be expanded with sensors, a scheduler, and other automation parts [#14605544] The responder was unsure about the Conrad Max Cube system and suspected it may be a closed protocol limited to its own devices [#14605142][#14605544]
  • #1 14542263
    dagny1
    Good evening
    I am looking for support in choosing an on-line control system for a co installation based on:
    - 800l buffer storage with heater (400V) running on 2nd tariff
    - 11 radiators
    - a small area underfloor heating system (2 bathrooms, 2 bedrooms)
    The building (165m2) will be used only occasionally during the heating season. On the one hand, it is therefore sufficient to set the radiator thermostats at 5-8 degrees, but on the other hand, I want to be able to turn up the temperature to a comfortable temperature before I arrive.
    I am assuming this involves thermostat control for the whole system or thermostats for individual radiators/underfloor zones. I would prefer the latter, but not at the expense of complicating the system/increasing costs when this need arises 2-4 times a year.
    Wi-Fi only available on site
  • #2 14542280
    Setel
    Help: 76
    Rate: 141
    What would this support consist of?
  • #3 14543043
    dagny1
    support in choosing a technical solution based on practical experience rather than manufacturer/vendor marketing
  • #5 14602493
    dagny1
    Thank you very much. The thermostats are controlled by a Danfoss Link CC panel, but the instructions don't say whether the DLCC has Wi-Fi
  • Z-Wave thermostats require a gateway for Wi-Fi control
    #6 14602661
    SmartHome
    These particular thermostats that I have specified are controlled using Z-Wave wireless technology. In order to connect them via Wi-Fi, an intermediary control unit would have to be used. Depending on your intention, you should choose a control unit; if it is mainly for controlling thermostats, you can use the cheapest (does not mean inferior) solution at the moment:
    http://dom-inteligentny.pl/pl/p/Centrala-Z-Wave-VERA-EDGE/182
    There are also other control units, including the well-known Polish brand Fibaro, but they are much more expensive and intended for more extensive home automation.
    The control units in the link below:
    http://dom-inteligentny.pl/pl/c/Centralki/56/..._producer_6/1/f_producer_27/1/f_producer_12/1
    It would look like this:
    Thermostats -> Z-WAVE -> Selected control panel -> WI-FI -> Internet -> operation (in this case changing temperatures) via the Internet on a PC or smartphone
    Dom inteligentny
    Bogatki 5, Warszawa, 02-837
  • Comparing DLCC, PBX, and router with Max Cube control system
    #7 14605142
    dagny1
    That is, there are 3 elements to be put together (DLCC, PBX, router) with the option to expand with cameras, sensors, etc.
    How does this relate functionally (because the price is completely different) to the LAN Max Cube gateway + thermostats; this is sold by Conrad, I think.
    I would like to remind you that my expectations are limited to the on/off function of the heating and temperature boosting + possible camera monitoring.
  • #8 14605544
    SmartHome
    To be honest, I'm not familiar with the system from Conrad, and I don't want to lie, but at first glance it looks like some kind of closed protocol limited to devices from one (their) company.
    What I've suggested above works in our office as one of the "bits and pieces" for testing. It works very well and there are no problems.
    In combination with e.g. a motion sensor, temperature sensor, time scheduler, you can construct a suitable scenario as you wish.
    The Z-Wave protocol has the advantage that it is being widely developed and introduced by a large number of manufacturers.
    Dom inteligentny
  • #9 14620669
    dagny1
    is the "fairy" to be seen in a showroom, on display, etc.?
  • #11 16003945
    dagny1
    case solved (Arduino-based controller) unfortunately via another portal, i.e. DIY
