Desktop Computer Power Consumption: Intel Core i5 2500K, Radeon 6950 XFX, OCZ StealthXStream 600W
Bandit6 56334 10
How much electricity can a desktop PC with an Intel i5-2500K and Radeon HD 6950 use at most, and could it really cost PLN 180 per month?
No, PLN 180 per month is likely exaggerated; a similar i7-2600K + XFX HD6950 platform was estimated at about 294 W at full load and about 79 W from the socket during light web use, which works out to roughly 60–90 kWh per month or about PLN 30–50 at 50–60 gr/kWh [#14560063] The 600 W PSU rating does not mean the PC draws 600 W all the time, and even delivering 600 W at about 85% efficiency would require around 705 W from the mains, which the components will not reach [#14560063] Simpler forum estimates also put the monthly cost around PLN 90–100 or about PLN 102 for a worst-case 600 W, 10 h/day scenario, but those assumptions were acknowledged as rough or overstated [#14559872] [#14559958] For an exact result, connect the PC through a wattmeter; it shows instant power and usually accumulated kWh over days or a month [#14560063] [#14561820]
  • #1 14559814
    Bandit6
    I was looking for similar threads, although they are outdated. I would like to know how much my desktop computer can use to the maximum. At the beginning I will add some information that may be useful.
    The computer is turned on every day after 10-14h. 5-7h of which is playing online games (mainly league of legends). The next 2 hours is time for movies / series. The rest is spending time on the browser (YouTube videos, social networks, watching streams on twitch).
    My equipment:
    Radeon 6950 XFX Dual Heatpipe 1GB 2xDVI & HDMI & DP (PCI-E)
    WD Caviar Blue 500 GB WD5000AAKS 16MB SATA-II cache
    GoodRam DDR3 4GB 1333MHz CL9
    Asrock P67 Pro3 (B3)
    Intel Core i5 2500K 3.30 GHz BOX
    OCZ StealthXStream 2 600W 80+ SLI 120mm
    According to a friend, the computer can consume up to PLN 180 / month.
    Is it even possible?
    If not, what maximum power, assuming the previously mentioned assumptions, can the computer draw?
  • #2 14559860
    shadow0013
    Help: 243
    Rate: 314
    You have a maximum power supply of 600W, you can assume for a simpler calculation that it consumes 500W at the maximum load, you have such a load 7-9 hours a day. Treat the rest that it uses 300W. This is estimated to be around 5kW a day x 30 days a month. You have the price per kWh + transmission costs on your energy bill. The calculations are rough and a little overstated but you have the magnitude of the problem.
  • #3 14559872
    trance123
    Help: 27
    Rate: 134
    If your computer would run all the time with the maximum efficiency of the power supply, i.e. the 600 W for 10 hours a day, at a price of PLN 0.17 per kWh per month, it would cost PLN 102.59. Here simple calculator
  • #4 14559958
    Bandit6
    So 180 PLN is a highly exaggerated result.
    It is known that the computer does not run at full speed every day.
    I think that the monthly electricity consumption of this machine is about PLN 90-100.
    It's all clear now.
  • #5 14560020
    Dra98
    Help: 1321
    Rate: 1076
    The set with the LCD monitor consumes ~ 350W under load [what monitor?] - http://pclab.pl/art44149-15.html you can also see the tests.
    Exactly \ accurately can be measured with a wattmeter.
  • #6 14560033
    safbot1st
    Help: 2719
    Rate: 1585
    @ Dra98 Recently I saw for PLN 40 in a "construction supermarket". And the topic is resolved.
  • #7 14560063
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Why make such nonsense assumptions? First, the 600W power supply will consume more than 600W at maximum load - to deliver 600W on the secondary side at 85% efficiency, it will draw about 705W from the network. The components of this computer will NEVER pull 500W off the mains. When browsing the pages, the power consumption will be much lower than 300W.
    If you go the easy way, you can use someone else's tests. XFX HD6950 1GB + I7-2600K is a fairly similar platform in terms of power consumption.
    http://www.tomshardware.com/reviews/radeon-hd-6950-1gb-benchmark,3041-16.html
    With a load of 250W, we have 67W at rest. The tests of the power supply show that it will have an efficiency of about 86% at 250W, at 100W, about 85% (for the sake of simplicity, it can be assumed that it is usually about 85%), so the platform will consume about 294W at maximum load, about 79W from the socket when loaded. when walking on the pages.
    Such calculations are best done by measuring the unit's current consumption with a wattmeter in two situations: under load (game) and without load (desktop / www). Theoretically, you can try to calculate it all roughly (assuming a certain error in these calculations).
    The hour of playing games (I incorrectly assume the maximum load all the time, so it will not work worse) is 294Wh (let's count 300Wh), i.e. 0.3kWh. You play 5-7 hours, so it will use 1.5-2.1kWh of energy.
    Walking on the pages and watching movies is a rather low load, you can count 80W rounded, i.e. after 0.08kWh it will be consumed. Let it be 0.1kWh.
    So it can be assumed that you will use 2-3kWh per computer per day. For a month, with these assumptions, it will be 60-90kWh. I do not know exactly how much electricity costs (due to the transparent pricing policy of my supplier), I estimate about 50-60gr / kWh (including all possible fees, i.e. dividing the invoice amount by the actual consumption without thinking). So a month I would shoot that it would be PLN 30-50 on the electricity bill.
  • #8 14560975
    Bandit6
    I can see that the answers differ significantly from each other.
    Tomorrow I will buy a wattmeter, which will dispel all doubts.
    It works so that after a day of computer work I disconnect it and show me the amount of energy used?
  • #9 14561820
    dt1
    Help: 7315
    Rate: 8292
    A question of the functionality of this device, but it certainly shows the instantaneous power consumption (so you will be able to estimate what power is currently being consumed by the computer, then test it with and without load). Most also have the function of counting at some time, it doesn't have to be (but can) be all day. The most common result will be given in kWh. So you can connect it on the first day after buying it and connect the computer through it, after the first day write down the result (and date), without resetting the indications after a few days, write down the next result (and date). By writing down the dates, you will be able to divide the current value by the number of days and you will also have an average daily result. After 30 days, you will have a monthly result.
  • #10 14561908
    Piotr160292
    Help: 374
    Rate: 282
    As for me, a pointless question, because for about PLN 40. You can buy a wattmeter, which is enough to connect, extend to which the computer is connected with the monitor and you have already got a reliable measurement, even converted into kilowatt hours, and knowing them is not a problem how much money you need to add to the bill through such a computer. It is impossible to estimate this, the more that each energy company has a different rate, so this amount will vary depending on the energy supplier.
  • #11 14561923
    edimander
    Rate: 82
    Motherboard: ASUS P5KPRO (current bios + all drivers)
    Processor: Intel Core 2 Duo E7200 @ 2.53Ghz
    RAM: DDR2 Kingstone 2x 2048MBytes 400 MHz CL5
    Graphics: AMD Radeon HD 7750 1024MBytes clocks: Core 830 Mhz Memory clock 1125 MHz
    Power supply: CHIEFTEC GPS-500AB A 500W
    Sound: some integrated Realtek
    Network Card :: Integrated Marvell Yukon 88E8056
    Peripherals: USB mouse / PS2 keyboard, Samsung 1TB external drive connected to the USB - there is no difference with disconnected and connected. Diskette drive (yes, I still have it) - disconnected, cd-writer connected but hardly used.
    NET 300/300 without a router, an Ethernet socket at home from a cable, connected with a network cable (and it works in practice like this http://www.speedtest.net/result/4241355357.png and does not lose packets
    Operating system: Unfortunately for games win 7 64 bits (all possible updates)
    The comp works for 8 months, 18 hours a day, and a laptop at home (6 hours a day on the charger) + 2 LCD TVs of 40 "(8 hours a day) + an electric oven fired every week (for about 80 minutes) + a kettle fired at least 6 times a day (because a lot of coffee drinks) sometimes Xbox360 = bill every 2 bellows 170 PLN -180 PLN I have never exceeded this upper limit, but I'm talking about getting to know.
    However, as a colleague pasted, cool calculators are. It's worth counting.
    so please don't overdo it and don't scare. (my computer mainly works on the 100% efficiency for about 7 hours a day) the rest is work on the desktop (movies, websites, etc.).
    Added after 6 [minutes]:
    Even from the currently purchased tariff. GSM providers are becoming energy suppliers.
    He will spend PLN 40 for a maximum of 2 months
    Added after 5 [minutes]:
    shadow0013 wrote:
    You havemax 600W power supply, you can assume for simpler counting that at the maximum load it consumes 500W, you have such a load 7-9 hours a day. Treat the rest that it uses 300W. This is estimated to be around 5kW a day x 30 days a month. You have the price per kWh + transmission costs on your energy bill. The calculations are rough and a little overstated but you have the magnitude of the problem.
    as it says +/-
    dt1 wrote:
    Why make such nonsense assumptions? First, the 600W power supply will consume more than 600W at maximum load - to deliver 600W on the secondary side with an efficiency of 85% it will consume about 705W from the network. The components of this computer will NEVER pull 500W off the mains. When browsing the pages, the power consumption will be much lower than 300W.
    I would fit in it, and rather in the middle.
The discussion revolves around estimating the power consumption of a desktop computer equipped with an Intel Core i5 2500K processor, a Radeon 6950 XFX graphics card, and an OCZ StealthXStream 600W power supply. Users provide various calculations and insights regarding the monthly electricity costs associated with the system, which is used for gaming, streaming, and browsing. Initial estimates suggest a monthly cost of PLN 180, but further analysis indicates a more realistic range of PLN 90-102 based on average usage patterns. The importance of using a wattmeter for accurate measurement is emphasized, with suggestions for monitoring power consumption over time to obtain precise data.
