TV Led Blaupunkt BLA-32/141 - Only standby, chassis TP.MSD309.BP85 is lit.
bodzio64 7995 1
  • #1 14562829
    bodzio64
    Help: 10
    Rate: 28
    Hello. Tv as in the subject. The standby LED is on. Damaged memory 25Q32.
    All of them, available on the net, I uploaded. Tv works but not quite correctly.
    On one softy is everything ok but the remote does not work, on another softy the picture is reversed vertically (the service menu can not be changed, or I can not find). Maybe one of my colleagues has such a Tv in the workshop and has the ability to rip the batch. The UF11 25Q32 system.
    Model TV Blaupunkt BLA-32 / 141l-GB-5B-HBKU-EU
  • #2 14642861
    bodzio64
    Help: 10
    Rate: 28
    Problem solved thanks to the kindness of colleagues from Slovakia. The TV programmed with the original soft came back to life. I close the subject
